Scooter stand
LX150
Fri Apr 08, 2011 11:47 am quote
I wanted to build a table lift / stand that is not expensive and take almost no space in my garage when not in use. I looked on the net and found this one: http://www.eurospares.com/bikestnd.htm
It is cheap to build but not compact, so I modified the plans to use cross halving joints (http://www.technologystudent.com/joints/crsh1.htm) for the supporting box. Will make a wheel chock later as here: http://modernvespa.com/forum/topic8548?highlight=wheel+chock
Happy with the result, was easy to change oil on it.
Cheers.
1979 Vespa P200E
Fri Apr 08, 2011 1:34 pm quote
Nicely done, I like the way it can be dismantled and stored out of the way. How do you get the scooter onto it? Do you push it up or drive it up?
LX150
Fri Apr 08, 2011 1:40 pm quote
I pushed it up. Some care is required. Once it is up, the top board went horizontal and the end board closed into the boxed supporting position. It is better to have a second person around, of course, but I managed to do it alone just fine.
125GT-S
Fri Apr 08, 2011 3:44 pm quote
Neat idea, well done, the increased height certainly makes working on the scooter less of a chore.
Small point though - in the close up photo of the hinge (photo 7) why did you not just fit the hinge the other way around with the round bit away from the corner? Most standard hinges will fold back on themselves so I can't see a negative for the change.
Similarly on the ramp hinge, you could use a piano hinge underneath over the entire width fitted in the same way. I appreciate that this would load the hinge in compression with the ramp up but you could affix a suitable stay if you doubted the strength of the hinge.
Hopefully you'll find my comments useful & constructive (pun intended)? Thanks for bringing your design to the forum, it's a great idea.
LX150
Fri Apr 08, 2011 3:55 pm quote
Thank you, Ninemeister. You are correct about the photo #7 and I indeed turned them around as I disassembled the table - it did not fold correctly otherwise
For the ramp hinge I just did not want to drive to the store again to get better hinges and these were not to be trusted with the weight of a scooter, hence I did it this way.
Thank you for your comments again!
'09 BV250, '02 ET2 '07 LX150
Fri Apr 08, 2011 7:20 pm quote
Very nice!!! One question though...how did you get your garage so clean??? Also, your cocker looks a lot like mine, except yours appears more calm.... Thanks for posting this....gives me a new plan to try!
GRAPHITE LX 150
Fri Apr 08, 2011 9:49 pm quote
Pushed it up yourself, OK. how'd you get the bike stand down, and the dismount from the bike stand and the wooden stand ? Thanks
LX150
Sat Apr 09, 2011 4:18 am quote
The top platform is wide enough for me to stand on next to the scoot. I took it off the center stand and just kicked the end board off the vertical supporting position. I guess it's a balancing act when you do it alone and the second person could be handy. Standing next to the scooter, moved it a little back and the boards tilted into the ramp position. I was just holding scoot steady while coming back down.
Reprehensible Misinformant
Sat Apr 09, 2011 1:00 pm quote
Nicely done. As an ongoing refinement, a 2"x3" "rib" could be screwed and glued to the underside length of the main sheet to reinforce it and keep it from flexing.
Would require a corresponding notch in the center and forward upright, and would make a "bit" bulkier to store, but would also make a bit sturdier.
Just a thought...a nice project in any event! You'll never work on the "floor" again!
'05 Vespa Granturismo
Sat Apr 09, 2011 8:38 pm quote
I do not believe that I would be able to push and balance my GT 200 up a ramp that steep.
Just too heavy.
GTV300 2011
Sat Apr 23, 2011 7:45 am quote
sorry - an accident waiting to happen.....
Sun Apr 24, 2011 4:33 am quote
I agree if only one person is doing it but definitely ok with two.
T5s
Sun Apr 24, 2011 10:40 am quote
timber
is that how you got the ding in the first piccy
2013 GTS300ie
Wed Jan 29, 2020 9:34 pm quote
Put the rib on the TOP of the main sheet. That will avoid the cutouts and stop tools from rolling off the edge.
Alternatively, fit a rib to the sides of the top sheet.
Team Scooter Trash for Petfinder Foundation   vespa scooterwest scooter west Motorsport Scooters   Scooter Parts Company
[ Time: 0.1658s ][ Queries: 27 (0.0453s) ][ Debug on ]
