GTS250
Post Reply    Forum -> Project Reports 12Next
2008 GTS250, 2009 S150, 2017 GTS300Super, 2006 GT200
Fri Sep 20, 2019 7:11 pm quote
Taking a page out of oopsclunkthudís book and reserving a space to document the progression of my project GTS250.
Current status: Have had it since 8/23 so almost a month. Title came last Saturday 9/24 and on the 17th I ordered a bunch of parts.
Here it is on the day I picked it up
Fri Sep 20, 2019 7:16 pm quote
Itís in pretty darn good shape with the only problems being a DIY repair job on the left side, a broken brake cylinder cover on the right, mismatched tires (Bridgestone on the back and City Grip on the front), and it looks like something ate the finish off a small section of the exhaust (right under the water pump)
Hereís where it came to rest on day 1
Fri Sep 20, 2019 7:17 pm quote
Busted brake cylinder cover...
Fri Sep 20, 2019 7:19 pm quote
Funky spot on the exhaust..
Fri Sep 20, 2019 7:23 pm quote
And the DIY repair...
Fri Sep 20, 2019 7:28 pm quote
I really wish I knew how to or if itís possible to post more than one picture at a time. I see the question asked all the time but itís never answered. I only use my phone for the convenience but maybe things work differently on a PC???
Anyway, what spurred me to start all this was my boxes started arriving today. Amazingly the ones that came from Germany beat the local orders. If anyone has concerns about ordering from SIP donít worry. My order got here in 3 days...and would have been here yesterday if it werenít for TS Imelda dumping feet of rain here.
Thu Sep 26, 2019 5:16 pm quote
Time to start the mods on this bike. Wheels and tires came so I will get them swapped out with the stock ones today
Thu Sep 26, 2019 5:18 pm quote
The black wheel changed this bikes whole personality.
Next the rear...
Thu Sep 26, 2019 5:19 pm quote
And itís on.
Thu Sep 26, 2019 5:20 pm quote
Old stock exhaust meet your replacement!
Thu Sep 26, 2019 5:23 pm quote
The stock exhaust weighs over 14 pounds and thatís the weight without the header. I havenít removed that from the bike yet
Thu Sep 26, 2019 5:27 pm quote
And the PM68 weighs 7.6 pounds WITH the long curved header attached. I may weigh it again without the header when I have time to get back and finish this part of the project. Busy weekend ahead so I wonít get much more done for a bit.
Thu Sep 26, 2019 5:34 pm quote
Happy with the progress so far. Still waiting on one order that contains the:
black mirrors
black brake levers
black leg shield trim
black passenger pegs
grips
solo seat
4v head and big bore cylinder kit
GTS 250
Mon Sep 30, 2019 9:38 am quote
When you get your 4V head, be sure to do a test fit with the PM exhaust before everything is mounted. I had issues with the PM-80 and OEM exhaust nuts not having enough clearance.
Mon Sep 30, 2019 11:32 am quote
Thanks AnnDee444. I followed your story and picked these items up.
I spent the better part of an hour last night trying to get the header attached to the original head. Thereís so little space itís killing me to get the nuts started on the studs. Do you have a trick? Iím trying to be patient but my next idea is to just take the engine out to get this thing bolted on.
I wonít put on the head for a bit more time. Itís going off to AF1 for some work.
GTS 250
Mon Sep 30, 2019 12:21 pm quote
When I am able to finally get them started by hand, I am able to use a 1/4" drive with a 6" extension, and a 1" extension. The 1" extension goes closer to the socket, and allows for just enough mis-alignment to get the nuts tightened properly. (This is with the ARP 12-point nuts also).
The best tip I can give is to loosely bolt the header to the motor while the engine is out of the bike, then tighten everything when the motor is in. Installing the motor with the exhaust attached is not much harder, but does require the body to be lowered over the motor (I use a transmission jack). Hell, it's almost easier to pull the motor just for the header than it is to get the PM header attached with the motor in the bike.
Also, check your exhaust port diameter on the V4 head vs. the header. I ended up port matching both the head and header to the diameter of the copper gasket. There is a slight taper on the header that is could be restriction, even with the unmodified V4 head.
Mon Sep 30, 2019 12:56 pm quote
I was afraid of that. Iíll try a little longer and then itís OUT with the motor!
I was trying to only pull it once but my head wonít be going out until November and I MUST hear this pipe now.
Tue Oct 01, 2019 9:04 pm quote
Yep. The frustration level peaked trying to get that header on. Engines gonna have to come out. Time to build a stand to make working on this project a bit easier.
Aprilia Scarabeo 500
Thu Oct 03, 2019 5:40 am quote
Very cool project. I just joined the forums and haven't gone through much as of yet, but I am also curious about your other scooters. Do you have a thread for each one? Definitely following progress of this thread to see the before/after progress with the cylinder kit.
Thu Oct 03, 2019 5:54 am quote
I fully intend to keep this thread running until Iíve completely gotten this bike to where I want it. By the time Iím finished it will have a more powerful motor and it will be sporting a new color. Iím not fond of red. My very personal opinion is that red is for girls and firemen.
So hereís the plan. Iíve got the head and cylinder kit in-hand but after following a thread over on another site I want to mod the head before I install it and the guy doing the cleaning up/porting/polishing canít accommodate me until next month.
I do not have threads for my other bikes. The 150 I donít mess with. The new GTS I donít mess with. I did a lot of cosmetic things to the GT 200 and took lots of pictures so if youíre interested in before/after cosmetic shots I can start a thread to show that. The GT turned out really nice after blacking all the controls, legshield trim, mirrors, and wheels. I added stripes and stickers and it has a ďfastĒ look now.
This GTS250 is intended to be my hot rod and I want it to be stunning when finished. The engine work will be completed and dialed in before I strip everything and do a frame up color change. Stick around, this will not happen quickly!!
Vespa GTS 250ie
Fri Oct 04, 2019 1:10 am quote
This thread looks the goods to me! Can't wait to see what you do. My old Beo 250 destroyed the drive shaft, I'm in the middle of deciding to just replace the drive shaft or do I do the Malossi 275cc and V4 head upgrade too on it.
In the mean time I'm riding around on a 250GTS which has made me want to keep the Vespa. So maybe I'll fix the driveshaft on the Scarabeo - then sell it, and do the engine upgrades to my Vespa! Hmmm decisions - but your plans look very very exciting!
Mon Oct 07, 2019 7:17 pm quote
Platform is complete.
Tue Oct 08, 2019 11:18 am quote
I am definitely interested in seeing progress from the other scoot. I will keep my eyes on this thread as well to see progress unfold. If you don't mind me asking, do you already have a color in mind that you plan on? Will it be a factory Vespa color or something custom?
Tue Oct 08, 2019 1:37 pm quote
Iíve had my mind set on some shade of orange. Not a light one but darker. Like this.
Tue Oct 08, 2019 1:44 pm quote
But I also like deep blood reds like this Brandywine Iím showing here. Itís all up in the air though because Iím really digging the colors Iím seeing on the newer Vespas and I saw a Porsche the other day and the color was amazing. I looked it up and almost positive itís called Chalk.
Paints a ways off with the engine work Iíve yet to start on so I have time to decide. Hereís the Brandywine. It would kick off awesome with everything blacked out.
Tue Oct 08, 2019 5:07 pm quote
With everything obtained and my workstand built, today was the day to install the exhaust. Working with the bike elevated and also jacked up I had enough room to get my head under there and see. It also helped that this time I took the side skirts off. That made a huge difference. Instead of 15 minutes X a few tries of frustration and failure this time I had both nuts on in less than 10 minutes.
Tue Oct 08, 2019 5:25 pm quote
Hereís the finished job so for those following this thread Iím halfway finished with Phase 1 with the wheel/tires, seat, and exhaust on. The rest will be new grips and bar end weights, black mirrors, black foot rests, and black leg shield trim. Iíll also replace that broken brake reservoir cover. At some point I must lose that chrome rack on the back but I havenít decided what to replace it with.
Phase 2 will be the engine work and I have no idea how long thatís gonna take.
I learned something that I can maybe pass along. When you jack these bike up there is no way to get the jack back far enough so that you only life the rear. To keep the front from coming up youíve got to tie it down somehow. I put 2 u-bolts lateral to my 2x4 homemade wheel chock. A strap through the wheel and u-bolts held the front end down nicely.
Thu Oct 17, 2019 5:50 pm quote
A little farther along and at a stopping point now before moving onto the engine mods. Mirrors and controls as well as leg shield trim all black now and the horn cover was updated to the current decade
2006 GT200L "Lone Star"
Thu Oct 17, 2019 5:54 pm quote
Platform
Your carpentry kung fu is better than mine...
Also took that chrome springy rack off the back and added something a little more retro and sporty
Thu Oct 17, 2019 5:57 pm quote
Whatíre you talkin about? I think your platform is great!
Wish Iíd built this thing a year ago. Makes a huge difference not having to get down on the ground.
Thu Oct 17, 2019 6:03 pm quote
Thanks.
Yeah, I hear ya on getting down on the floor. Concrete is not getting any softer, and my inner ear tumbles when I'm at odd angles these days. I put wheels on it because I have to tuck it in against the side of the garage to get everything to fit. Two cars and two bikes (three if you count the Schwinn) in a smallish garage is a squeeze, but I don't like leaving anything outside any more.
Thu Oct 17, 2019 6:12 pm quote
Those wheels are awesome. Wheels would be a nice addition but if I do that I might have to cut the legs a bit.
Thu Oct 17, 2019 6:17 pm quote
I made it a little lower than the plans called for so I could put the wheels on (Harbor Freight, by the way) but it's still a bit too tall to reach over the side and pull the carburetor. I have to use a step stool. Everything else is easier, though.
Fri Oct 18, 2019 6:25 am quote
That is a transformation! Looks awesome! Black looks so much better than the chrome! Nicely done.
Fri Oct 18, 2019 8:28 am quote
is that the alibaba rack?
Fri Oct 18, 2019 8:35 am quote
Thanks! I like it a lot better and Iím less put off by the red now.
Fri Oct 18, 2019 8:40 am quote
No not alibaba. I actually got from SIP. Itís number MV655829MB there. ScooterPartsCo also sells it here locally but since I was already getting something I could only get from Germany I just added it to the order.
300 super sport Full Malossi and carbon Edition
Fri Oct 18, 2019 9:43 am quote
Nice job Rob
Team Scooter Trash for Petfinder Foundation   Vespa Wasp Pin Badges   Cool Ass scooter seat cover
[ Time: 0.2222s ][ Queries: 28 (0.0612s) ][ Debug on ]
