GTS 250ie Lambda Sensor
Vespa GTS 250
Mon Oct 03, 2011 6:31 am quote
Afternoon all,
I need to get a replacement lambda sensor for my GTS250ie. I understand there are a few different types (2 wire, 3 wire, 4 wire). Mine's an '05. Does anyone know which specific sensor I require and also where to source one from?
I believe the part is made by Bosch although with a Piaggio label it doubles in price.
Any words of wisdom out there?
Cheers
GTS250 GTS300 MP3 500
Mon Oct 03, 2011 6:41 am quote
I was under the impression (though I'm prepared to be wrong about this) that the connector on the end of the sensor was specific to the application.
Again, I could very well be mistaken.
gts300
Vespa GTS 250
Mon Oct 03, 2011 7:54 am quote
Hi, yes thanks I've seen that thread. Unfortunately it isn't clear exactly which part I need for my bike. As I say, there appear to be multiple wiring options so one needs to get the choice right.
Vespa GTS 250
Mon Oct 03, 2011 7:55 am quote
Is there a way to tell given the year of manufacturer which is required?
gts300
Mon Oct 03, 2011 8:15 am quote
sorry I'm not sure, why not ask cheeky on the gts forum.
Vespa GTS 250
Mon Oct 03, 2011 8:39 am quote
I wish I could but I can't get a log in. I've registered a couple of times on that forum but haven't been sent the activation email. ..
gts300
Mon Oct 03, 2011 11:00 am quote
I've posted a link to this page and your problem ,up on gts forum .Hopefully someone will reply
Fran
Mon Oct 03, 2011 11:06 am quote
There's only 2 types on the current range, 2 wire or 4 wire.... Yours should be 4 wire easiest way to check is just look at the multiplug.
gts300
Mon Oct 03, 2011 9:28 pm quote
jonny can you follow this linkhttp://www.gtsownersclub.co.uk/forum/viewtopic.php?f=14&t=6482
It looks like it should be the 4 wire one
Vespa GTS 250
Tue Oct 04, 2011 1:35 am quote
Thanks for your help everyone.
I'm convinced I do need the 4 wire. I'm also sure the part number is 584344. The question is, is 584344 uniquely the 4 wire version. i.e if I order that part online am I guaranteed to get the 4 wire version?
Looks like cheeky thomas on the other forum has the answers. Shame I can't chat him directly.
Cheers
Vespa GTS 250
Tue Oct 04, 2011 2:24 am quote
I've emailed cheeky thomas directly.
Thanks again everyone.
Tue Oct 04, 2011 10:02 am quote
Yes that part number is the 4 wire version only...
NGK do a replacement, but you have to swap the multiplug over as it just comes with the 4 wires... Theres also various cheap replacements again with just wires for you to adapt, universal fitment things.
Resident Grump
Location: Lower Lumpa, the heart of the tropical Hiawatha Valley
Tue Oct 04, 2011 2:26 pm quote
If you have a minute could you share the NGK part number?
New York Scooter BlockParty 8   Maroon Powersports LLC DBA Scooter Centrale   Caribou Luggage Systems
[ Time: 0.1058s ][ Queries: 33 (0.0497s) ][ Debug on ]
