Main Page
Recently Added
Recently Edited
Added By Me
Edited By Me
All Articles
Discussion Forum
Air Filter Cleaning
Overview
It is important to clean your air filter(s) as indicated in maintenance schedule for your model. Some models have a secondary air filter which should be cleaned along with the primary air filter.
Video Tutorial
You can also watch this video on blogger.
Tools
Required
  • #2 x 1-1/2 in. Phillips Head Screwdriver
  • #2 x 4 in. (or longer) Phillips Head Screwdriver
  • Mild dish detergent
  • Either a spray-on foam air filter treatment OR 50:50 mixture of gasoline/AGIP filter oil OR 50:50 mixture of gasoline/recommended engine oil.
  • Vinyl or Latex gloves
Nice to have
  • Magnetic Tool
  • Magnetic Tray
  • Pliers
  • Shop Light
Tips
  • Recommended Foam Air Filter Oils: Maxima Fab-1 Spray-On Filter Treatment or UNI foam filter oil (following the manufacturers directions).
  • For the 50:50 mix, it's preferred for better air filtration to use gas & AGIP Filter Oil. If you don't have AGIP, you can use engine oil, Piaggio recommends using Selenia HI Scooter 4 Tech. However, this may not always be available, so you may use the same Full Synthetic 4T scooter oil used in your. engine oil change.
  • Time is approximately 45 minutes-2 hours depending on skill level (not counting filter drying time).
* Check your model's manual for specifics.
Contributed by MV user Frank with the help of his daughter Maureen.
Last Updated Mon Apr 19, 2010 11:38 am
[ Time: 0.1705s ][ Queries: 19 (0.0426s) ][ Debug on ]
