Main Page
Recently Added
Recently Edited
Added By Me
Edited By Me
All Articles
Discussion Forum
GT/GTS: Installation of a Cupolino Flyscreen
Here to follow is the English translation (from the original Italian instructions sheet) on how to mount the flyscreen on the Vespa GT and GTS (courtesy of Salima, and Windbreaker provided the original Italian sheet with instructions -- thanks, Windbreaker!).
INSTRUCTIONS FOR MOUNTING THE FLYSCREEN "CUPOLINO" ON THE VESPA GT and GTS
(for the screen assembly)
FLYSCREEN "CUPOLINO" VESPA GT/GTS
The above drawing shows the correct sequence for mounting the parts onto the flyscreen which will then be mounted to the bar.
________________________
(for the assembly of the two bars, and installation on the vespa)
1) Screw the nut A in the threaded end of the bar, all the way, hollow end first.
2) Insert the cone-shaped object B
3) Insert the plastic tube C
4) Add the cone-shaped object D
5) Insert to follow the washer E, the spring washer F, and the bolt G. Tighten the whole thing.
6) Insert the end of the bar that you have so far (#s 1 through 5) into the tubes behind the oval openings, situated underneath the handlebar. Push until it fits all the way to the end, and with a wrench # 17 mm tighten nut A.
Moped and I hope that this translation will facilitate the mounting of the flyscreen for the Vespa GT and GTS.
Originally posted by Salima Draghetta & Moped
Last Updated Fri Jun 04, 2010 8:44 pm
[ Time: 0.1478s ][ Queries: 21 (0.0446s) ][ Debug on ]
