Main Page
Recently Added
Recently Edited
Added By Me
Edited By Me
All Articles
Discussion Forum
GT200L Torque Specs...
GT200L, Tightening Torques listed in the GT200 Workshop Manual
All units are listed in lbs-ft and N-m Values.
Steering Unit
Steering, upper ring nut (1ea) 22.1-29.5 lbs-ft , 30-40 N-m
Steering lower ring nut (1ea) 5.9-7.4 lbs-ft , 8-10 N-m
Handelbar clamping screw (1ea) 33.1-36.8 lbs-ft , 45-50 N-m
Handelbar Control unit U-Bolt fixing screws (2ea) 5.1-7.4 lbs-ft , 7-10 N-m
Frame
Swing arm-engine pivot nut (1ea) 47.1-53.0 lbs-ft , 64-72 N-m
Swing arm-frame pivot nut (1ea) 56.0-61.1 lbs-ft , 76-83 N-m
Frame-Engine link nut (1ea) 24.3-30.2 lbs-ft , 33-41 N-m
Silent Block support plate bolt (2ea) 30.9-38.3 lbs-ft , 42-52 N-m
Center Stand bolt (1ea) 18.4-22.1 lbs-ft , 25-30 N-m
Front Suspension
Shock absorber plate-Caliper fixing screw (2ea) 14.7-19.9 lbs-ft , 20-27 N-m
Wheel axel nut (1ea) 55.2-66.3 lbs ft , 75-90 N-m
Wheel screw (5ea) 14.7-18.4 lbs-ft , 20-25 N-m
Mudguard-fork fixing screw (3ea) 3.7-4.8 lbs-ft , 5-6.5 N-m
Front Brake
Pump-Oil Tube connection (1ea) 13.7-18.4 lbs-ft , 20-25 N-m
Caliper-Oil tube connection (1ea) 13.7-18.4 lbs-ft , 20-25 N-m
Caliper-Shock absorber plate fixing screw (2ea) 13.7-18.4 lbs-ft , 20-25 N-m
Disk clamping screw (6ea) 4.4 lbs-ft , 6 N-m
Oil bleeder screw (1ea) 8.8-11.8 lbs-ft , 12-16 N-m
Pad clamping pin (2ea) 13.6-18.4 lbs-ft , 19.6-25 N-m
Brake pump basin screw (2ea) 9.6-13.7 lbs-ft , 15-20 N-m
Rear Brake
Pipe-Oil tube connection (1ea) 13.7-18.4 lbs-ft , 20-25 N-m
Caliper-Oil tube connection (2ea) 13.7-18.4 lbs-ft , 20-25 N-m
Rear disc clamping screw (6ea) 8.1-9.6 lbs-ft , 11-13 N-m
Caliper-Engine fixing screw (2ea) 13.7-18.4 lbs-ft , 20-25 N-m
Brake pump basin screw (2ea) 11.0-14.7 lbs-ft , 15-20 N-m
Caliper coupling screw (2ea) 22.1-24.3 lbs-ft , 30-33 N-m
Rear Suspension
L.H. side shock support plate-crankcase fixing screw (2ea) 13.7-18.4 lbs-ft , 20-25 N-m
Shock absorber top fastening (2ea) 13.7-18.4 lbs-ft , 20-25 N-m
Shock absorber bottom fastening (2ea) 24.3-30.2 lbs-ft , 33-41 N-m
Rear wheel axel (1ea) 76.5-92.6 lbs-ft , 104-126 N-m
Wheel hub fixing screw (5ea) 13.7-18.4 lbs-ft , 20-25 N-m
Muffler-Shock absorber support arm screws on engine (2ea) 13.7-18.4 lbs-ft , 20-25 N-m
Silencer
Silencer Heat shield fixing screws (4ea) 3.7-4.4 lbs-ft , 5-6 N-m
Exhaust Gas inlet screw (1ea) 9.6-11.0 lbs-ft , 13-15 N-m
Muffler support arm fixing screw (3ea) 13.7-18.4 lbs-ft , 20-25 N-m
Hydraulic Components
Hub oil bleeder cap (1ea) 11.0-12.5 lbs-ft , 15-17 N-m
Oil filter-Crankcase fixing screw (1EA) 19.9-24.3 lbs-ft , 27-33 N-m
Engine oil-net filter bleeder cap (1ea) 17.7-22.1 lbs-ft , 24-30 N-m
Oil Filter - 5.9-7.4 lbs-ft , 8-10 N-m ( I usually tighten it by hand )
Oil pump over screw (2ea) 5.2-6.6 lbs-ft , 7-9 N-m
Oil pump crankcase fixing screw (2ea) 3.7-4.4 lbs-ft , 5-6 N-m
Oil pump control rim screw (1ea) ( that doesn't sound right! ) 7.4-10.3 lbs-ft , 10-14 N-m
Oil pump cover plate screws (2ea) 2.9-4.4 lbs-ft , 4-6 N-m
Oil sump screw (7ea) 7.4-10.3 lbs-ft , 10-14 N-m
Minimum oil pressure sensor (1ea) 8.8-10.3 lbs-ft , 12-14 N-m
Cylinder Head
Spark plug - 8.8-10.3 lbs-ft , 12-14 N-m
Head cover screw (5ea) 4.4-5.2 lbs-ft , 6-7 N-m
Cylinder Head Fixing Nut (*) (4ea) 5.2+/-0.7 +half rotation , 7+/- +180 deg Rotation. ???
Head fixing side screw (2ea) 8.1-9.6 lbs-ft , 11-13 N-m
Startup mass screw? (1ea) 5.2-6.3 lbs-ft , 7-8.5 N-m
Adjustment, Tappet lock nut (2ea) 4.4-5.9 lbs-ft , 6-8 N-m
Intake manifold screw (2ea) 8.1-9.6 lbs-ft , 11-13 N-m
Timing chain, tightening sliding block screw (1ea) 7.4-10.3 lbs-ft , 10-14 N-m
Startup mass bell screw? (1ea) 8.1-11.0 lbs-ft , 11-15 N-m
Timing belt tightening support screw (2ea) 8.1-9.6 lbs-ft , 11-13 N-m
Timing belt tightening central screw (1ea) 3.7-4.4 lbs-ft , 5-6 N-m
Camshaft retaining plate screw (2ea) 2.9-4.4 lbs-ft , 4-6 N-m
Transmission
Belt support roller screw/bolt (1ea) 8.1-9.6 lbs-ft , 11-13 N-m
Clutch assembly nut (1ea) 40.5-44.2 lbs-ft , 55-60 N-m
Driven Pulley Axel nut - 39.8-44.4 lbs-ft , 54-60 N-m
Variator assembly nut, (Drive Pulley) 55.2-61.1 lbs-ft , 75-83 N-m
(Note you must replace this nut EVERYTIME you remove it, failure to do so may lead to Crankshaft and /or Variator Damage)
Transmission cover screws (13ea) 8.1-9.6 lbs-ft , 11-13 N-m
Rear hub cover screws (7ea) 17.7-19.9 lbs-ft , 24-27 N-m
to be continued......[/b]
Last Updated Thu Dec 04, 2008 5:12 pm
[ Time: 0.1570s ][ Queries: 20 (0.0342s) ][ Debug on ]
