CONTINUOUS RUNNING LOADS | POWER (WATTS) | CURRENT (AMPS @ 12V) |
Headlight (high beam) | 60 | 5.0 |
Running lights (5w x 4) | 20 | 1.67 |
Headlight relay | 2 | 0.16 |
Injection loads relay | 2 | 0.16 |
Injection loads (fuel pump, fuel injector, ignition coil) | 60 (estimate) | 5.0 |
ECU | 10 (estimate) | 0.83 |
Instrument cluster | 5 (estimate) | 0.42 |
Immobilizer antenna | 1 (estimate) | 0.08 |
Voltage regulator | 10 (estimate) | 0.83 |
Total | 170 | 14 |
INTERMITTANT RUNNING LOADS | ||
Lambda probe heater | 5 (estimate) | 0.42 |
Radiator fan (including relay coil) | 62 | 5.16 |
Horn | 15 | 1.25 |
Turn signals (10w x 2, per side) | 20 | 1.67 |
ALTERNATOR MAX OUTPUT | ||
Cold | 312 | 26 |
Hot | 265 | 22 |
AVAILABLE FOR ACCESSORIES | ||
Cold | 142 | 12 |
Hot | 95 | 8 |
Last Updated UTC
