COLOR(S) | ASSIGNMENT(S) |
BLK | Ground |
BRN | Headlight low beam, Engine rev sensor (-) |
RED | Starter motor, Battery positive to fuses, Radiator fan, Engine rev sensor (+), +12V to brake light switches |
ORG | Key positive to fuses |
YEL | Alternator AC out, ECU to cluster - engine speed |
VLT | Headlight high-beam |
GRY | Headlight & fan relays |
WHT | Key positive to cluster and alarm connector |
PNK | Left turn signal |
BLK-GRN | Injection loads |
BLK-VLT | Injection load relay enable |
BRN-BLK | ECU to cluster - engine fault indicator |
RED-BLK | Battery positive to key switch and fuses |
RED-YEL | Fuel injector enable |
RED-GRN | ECU to cluster - code indicator |
RED-BLU | Battery positive to cluster and alarm connector |
RED-WHT | Key positive to ECU, +12V to immobilizer antenna, +12V to radiator fan and injection loads relay coils |
ORG-BLK | Battery positive to ECU |
ORG-BLU | Starter relay enable |
ORG-WHT | Immobilizer antenna serial data, starter relay coil power |
YEL-BLK | Key positive to cluster, +12V to running lights |
YEL-RED | +12V to horn switch, +12V to headlight relay coil |
YEL-BLU | Air temp sensor (+) |
YEL-GRY | Saddle unlatch power |
YEL-PNK | Horn power |
GRN-BLK | Engine kill switch |
GRN-YEL | Lambda probe heater enable, Water temp switch to cluster |
BLU-BLK | Turn signal power, alarm pushbutton return |
BLU-YEL | Cooling fan relay coil enable |
VLT-WHT | Diagnostic port serial data |
GRY-BLK | +12V to injection loads relay, fuel level sender (-) |
GRY-RED | +12V to headlight high/low beam switch |
GRY-GRN | Water temp sensor to ECU, engine kill switch to ECU |
WHT-BLK | Brake light power, starter switch power, +12V to saddle unlatch switch |
WHT-YEL | Air temp sensor (-) |
WHT-GRN | Lambda probe sensor (-), Fuel level sender (+) |
WHT-BLU | Right turn signal |
PNK-BLK | CDI enable |
PNK-WHT | Low oil pressure switch |
LBU-BLK | Lambda probe sensor (+) |
LBU-GRN | Water temp sensor to ECU |
ABBREVIATION | COLOR |
BLK | Black |
BRN | Brown |
RED | Red |
ORG | Orange |
YEL | Yellow |
GRN | Green |
BLU | Blue |
VLT | Violet |
GRY | Gray |
WHT | White |
PNK | Pink |
LBU | Light blue |
Last Updated UTC
