Main Page
Recently Added
Recently Edited
Added By Me
Edited By Me
All Articles
Discussion Forum
Vespa S (LXS)
Overview
The second expansion of the Vespa LX, the S (also known as the LXS) was introduced in 2008 in 150cc (North America), 125cc and 50cc versions. Though the S is cosmetically different from the LX, the 150cc and 2-stroke 50cc versions are identical under the hood.
In November 2008, Vespa unveiled the Vespa S50 4v, which features a 4-stroke, 4-valve engine. Vespa claims that, with 4.25bhp, it's the most powerful 4-stroke 50cc. It has more power than the 2-stroke model but fuel consumption and emissions benefits of a 4-stroke.
The LXS ie models became available in Europe in early 2010 in the US in mid-2010. The 2010 LXs came in both carbureted and injected versions. The injected models fully replaced the carbureted models in the 2011 model year.
Comparison to LX
The S features sportier trim than the LX, a different gauge cluster, a tapered, more angular horncast with a chrome piece down the center, and rectangular mirrors. The rear fairings are curved, as is the front fender which also has a chrome crest similar to the one on the GTS. In place of the LX's glovebox, the S has two open trays on either side of the steering column. The rear brakelight is also redesigned. The most striking difference, however, is the trapezoidal headlight inspired by the vintage Vespa sport models and smallframes.
OEM vinyl graphics kits are available featuring an Italian flag roundel, '60s-style flowers, and the Union Jack.
The S has two seating configurations. The stock seat (left image) is a one-person sport version with a curved back. A longer, flat, two-person touring seat is also available as an option. Both seats are black with white piping. To further slim down the look of the S, there is no chrome grab rail behind the seat.
The final difference, and the one functional difference between the two, is that the S does not have the ignition immobilizer (with programmed keys) that the other modern Vespas all have.
Colors
The original S colors comprised Montebianco White, Dragon Red, Shiny Black (aka Nero Lucido) and Toarmina Orange. (In the UK, the orange was available only as the Zafferano, a special edition of 200 with black racing stripes.)
In 2010, two-tone "college" editions were introduced in white/red and white/blue.
Official Specifications
MODEL LXS 50 (4T) LXS 150 LXS 125 LXS 125ie & LXS 150ie
CHASSIS
FRAME TYPE Load-bearing steel chassis with welded structural supports
ENGINE 124cm sq. and 151cm sq.
TYPE Single cylinder, four-stroke catalytic Hi-PER4 Single cylinder, four-stroke catalytic LEADER Single cylinder, four-stroke catalytic LEADER Single cylinder 4 stroke – Fuel Injected
CYLINDER CAPACITY 49.4cc 150cc 124cc
BORE X STROKE 1.54" x 1.63" (39 mm x 41.8 mm) 2.46" x 1.91" (62.8 mm x 48.6 mm) 2.2" x 1.9" or (57.0 x 48.6 mm) 57 x 48.6 mm (125) - 62.8 x 48.6 mm (150)
MAX POWER AT SHAFT 3.1 kW at 8,750 rpm 8.7 kW at 7,750 rpm (11.7 CV) 7.65 kW at 8250 RPM7.9 kW at 8250 rpm (125) - 8.9 kW at 8000 rpm (150)
MAX TORQUE 3.5 Nm at 6,500 rpm 11.5 Nm at 6,000 rpm 9.60 Nm (1.0 kgf-m or 7.1 ft.lbs) at 6000 RPM 9.6 Nm at 6500 rpm (125) – 11.8 Nm at 6250 rpm (150)
MAX SPEED 39 mph (62 km/h) 59 mph (95 km/h) 56.5 mph (91 km/h) 59mph (95km/hr)
FUEL/TANK CAPACITY Unleaded 91 min octane / 2.3 gallons (8.6 liters)
GAS MILEAGE 70-80 mpg** 72 mpg** (unspecified) 70-75mpg
DISTRIBUTION Cam head single shaft-SOHC (2 valves)
COOLING SYSTEM Ram air with sound proof cover Ram air with sound proof cover and integrated SAS (Secondary Air System) Ram air with sound proof cover and integrated SAS (Secondary Air System) Forced Air Circulation
LUBRICATION Wet sump, 850cc capacity; chain-driven lobe pump; intake and delivery filters Wet sump, 1,000cc capacity; chain-driven lobe pump; intake and delivery filters
IGNITION Electric and kick start Electric only
GEARS CVT transformer with torque slave
CLUTCH Automatic dry centrifuge with damper buffers
TYPE APPROVAL EPA and CARB EURO 3
WEIGHT AND DIMENSIONS
SEAT HEIGHT 30.5" (775 mm) 29.1338” or (740 mm)
DRY WEIGHT 225 lbs (102 kg) 250.8 lbs or (114 kg) – Unladen Mass 243lbs (110kg)
LENGTH/WIDTH/WHEELBASE 69.1" (1,755 mm) / 29.1" (740 mm) / 50.4" (1,280 mm)
WHEELS AND TIRES
FRONT TIRE/REAR TIRE Tubeless 110/70-11"/ Tubeless 120/70-10"
SUSPENSIONS AND BRAKES
FRONT SUSPENSION Single arm with helical spring and dual effect hydraulic single shock absorber
REAR SUSPENSION Coil spring and dual effect single shock absorber
FRONT BRAKE 7.87" (200 mm) ø steel disc with hydraulic command
REAR BRAKE 4.33" (110 mm) ø drum with mechanical command
Maintenance, Modifications and Other info
Tutorials, technical information and other info is in the article for the Vespa LX. Any items specific to the LXS will be added here.
Last Updated Mon Nov 29, 2010 7:27 pm
[ Time: 0.2100s ][ Queries: 25 (0.0847s) ][ Debug on ]
