Overview
This is a compendium of modifications, grouped by type. Note that some of these items are listed under Installing Accessories, and vice versa. Not all accessories require modification, and not all modifications are really an "accessory", per se. As a general rule, if it's something that just bolts to the bike, it's probably not a modification. If you have to drill, cut, hack, or otherwise mutilate the bike in some way, it probably qualifies as a modification.
Electrical Modifications
All Models
LX
LX: Installing a Stebel Nautilus Air Horn
LX150: Euro Turn Signal Kit Installation
LX150: Idle Jet Change
LX150: Installing a 12V Power Outlet
LX150: Installing a BackOFF brake light flasher
LX150: Installing a Tiny Tach
LX150: Installing heated grips
LX150: Installing an Admore Lighting Mini Light Bar
LX-150 Audicator Installation - With Pictures
LX150 Complete EVAP System Removal
GTV
GTS
GTS Variator Alternatives
GTS 300 JCosta Installation
GTS Headlight Modulator
GT/GTS CRG Barend Mirror Installation
GTS/GTV LeoVince Exhaust Installation
GTS: Crashbar Installation
Turn Signal Beeper and 12V Power Outlet on a GTS
GT/GTS: Installation of a Cupolino Flyscreen
GTS300 heated grips and power outlet - fitting
MP3
Other Modifications
EVAP Hose Removal
BV250: Evap System Removal (Procedure works for other carbureted LEADER and QUASAR motors)
BV500: Removing Charcoal Cannister
BV500: Fuel Pump Hose Clamp Installation
How To: Cut Down a Windscreen
Throttle Lock Installation
Gear tooth counts and interchangeability
Fuzzy Washer Performance Mod Explained
Common Procedures Required For Many Modifications
Last Updated Fri May 23, 2014 11:41 am
