Main Page
Recently Added
Recently Edited
Added By Me
Edited By Me
All Articles
Discussion Forum
MP3 125
Specifications
Engine: Single-cylinder, 4-stroke, 4-valve Piaggio LEADER with
SAS and two-stage catalytic converter
Cylinder Capacity: 124 cc
Bore / Stroke: 57 mm / 48.6 mm
Compression ratio: 12.0 : 1
Max. power output: 15 bhp (11 KW) at 9250 rpm
Max. torque: 12 Nm at 8500 rpm
Cooling: Liquid
Transmission: CVT automatic transmission with centrifugal clutch
Ignition: Electronic with capacitive discharge (CDI) and advance
mapping
Carburetation: 29 CVT carburettor with throttle position sensor
Starter: Electric (Bendix) with automatic decompressor and
automatic choke
Frame: High-strength tubular steel twin cradle
Front suspension: Parallelogram consisting of four aluminium arms
supporting two steering tubes, cantilever suspension
system - Travel: 85mm
Rear suspension: Two double-acting hydraulic shocks and adjustable spring
preload - Travel: 110mm
Front brake: Two 240mm stainless steel discs and floating calliper
with two pistons 30mm
Rear brake: 240mm stainless steel disc and calliper with 30mm
opposed pistons
Front wheel rim: Die cast aluminium alloy 12" x 3.00
Rear wheel rim Die cast aluminium alloy 12" x 3.50
Front tyre: Tubeless 120/70-12" 51P
Rear tyre: Tubeless 130/70-12" 62P
Length / width: 2130mm / 745mm
Height: 1490mm
Seat height: 780mm
Dry weight: 199kg
Fuel capacity: 12 litres (including 1.8 litre reserve)
Related Forum Topics
Documentation
Last Updated Thu Feb 20, 2014 11:20 am
[ Time: 0.2074s ][ Queries: 25 (0.0891s) ][ Debug on ]
