Engine: Single cylinder 4-stroke, 4 valve
Capactiy: 278cc
Bore x stroke: 75mm x 63mm
Max Power: 16.5kW - 22.5 HP at 7500 rpm
Max Torque: 23.2 Nm at 6500 rpm
Fueling System: Electronic injection with Ride by Wire technology
Cooling: Liquid
Lubrication: Wet sump
Starter: Electric
Transmission: CVT with torque server
Clutch: Automatic centrifugal dry clutch
Chassis: Double cradle in high strength tubular steel
Front Suspension: Articulated quadrilateral
Rear Suspension: Double dual-action hydraulic shock absorber
Front Brake: Hydraulically operated double 240mm disc
Rear Brake: Hydraulically operated 240mm disc
Front Tyre: Tubeless 120/70 - 12”
Rear Tyre: Tubeless 140/60 - 14”
Length/Width/Wheelbase: 2130mm / 745mm / 1490mm
Seat height: 780mm
Fuel tank capacity: 12 litres
Emissions: EURO 2
Related Wiki Articles
MP3: Installing a Fabbri Windscreen 250 and 400 models
MP3 250: Removal of the evap canister and roll over valve
MP3 250: Removal of the voltage regulator
Tie down points for the MP3/Fuoco
MP3 Valve Adjustment Procedure
Marc Parnes Wheel Balance Video Demonstration
Standard Roller Weights
Fuzzy Washer Performance Mod Explained
Related Forum Topics
Topic Spreadsheet
Fuel door fix
How to remove the steering tapered bearings
A modification to increment the live of the bearings sistem
Short term fix for "notch"? - It works...
Tire Change Pictures
How I reinstalled the rear wheel on my 250
Variator & Belt change - Pictures from MV workshop
HiD install on my 250! With Pictures!!
Fuel door fix
Part Numbers
Coming
Documentation
Parts Suppliers
Belts:
HID Kits:
HID Kits:
Last Updated Wed Jan 30, 2013 10:45 am
