MSRP*: $8899
ENGINE TYPE: Single-cylinder, MASTER, 4-stroke, 4-valve
CYLINDER CAPACITY: 492.7 cc
BORE X STROKE: 2.8" x 2.4"
MAX POWER AT SHAFT: 40 hp
MAX TORQUE: 42.23 Nm at 5,550 rpm
MAX SPEED: 89 mph
FUEL TANK CAPACITY: 3.2
GAS MILEAGE: 55-57 mpg
DISTRIBUTION: n/a
COOLING SYSTEM: Liquid
LUBRICATION: n/a
IGNITION: Electronic inductive discharge
GEARS: 'Twist 'n go' automatic CVT
CLUTCH: n/a
CHASSIS: Double cradle trellis made of high strength steel
FRONT SUSPENSION: Parallelogram supporting two steering tubes
REAR SUSPENSION: Oscillating engine fixed to frame with swingarm
FRONT BRAKE: Stainless steel double disc, 240 mm
REAR BRAKE: Stainless steel disc, 280 mm
FRONT TIRE: 120/70, 12"
REAR TIRE: 140/70, 14"
LENGTH: 85"
WIDTH: 30.5"
WHEELBASE: 61"
SEAT HEIGHT: 30.9"
DRY WEIGHT: 538
TYPE APPROVAL: EPA and CARB
COLORS: Dragon Red, Black
Capacity
Engine oil: 1.7 l
Transmission oil: 250 cm³
Cooling system fluid: ~ 2 l
Fuel tank (reserve): ~ 12 l (~2 l)
Related Wiki Articles
Oil change for the MP3 400, 500/Fuoco
Standard Roller Weights
Tie down points for the MP3/Fuoco
MP3 Valve Adjustment Procedure
Mp3 500 / Fuoco Engine Coolant and Hose Clamp Replacement
Painting your MP3 500 body panels
MP3 - Short term fix for "the notch"
Marc Parnes Wheel Balance Video Demonstration
Fuzzy Washer Performance Mod Explained
How to use a MULTIMETER to diagnose electrical problems.
Belt Change Procedure for MP3 400
Piaggio MP3 Rear Wheel and Hub Oil Change
Alternative signal indicators
Corrected MP3 400 and 500 driving pulley diagram w part numb
MP3 500 Removal of the front end plastics
Adjusting Brake Light Sensitivity
MP3 Front Tire Alignment
Related Forum Topics
Documentation
Parts Suppliers
Belts:
PSN Tuning 832738 UK
AF1 Racing 832738 US
2wheelpros.com 832738 US
AF1 Racing 849090 US
HID Kits:
DDM Tuning 35W & 55W Dual Motorcycle HID Kit Use Bulb Type H8 (35W and 5000K or 6000K Color recommended) US
Switches:
Tilt Lock Switch 641347 Scooter West US
Brake Light Switch 583575 AF1 Racing US
Brake Light Switch 583575 Scooter West US
Brake Light Switch 583575 PSN Tuning UK
Batteries:
MotoBatt AGM MBTX16U Amazon
Sliders / Rollers:
17 gram weight most recommended by MV members Buggy Parts NW
HID Kits:
Switches:
Batteries:
Sliders / Rollers:
Last Updated Sat Aug 31, 2019 10:45 am
