Main Page
Recently Added
Recently Edited
Added By Me
Edited By Me
All Articles
Discussion Forum
Primavera
Overview
Announced at the 2013 EICMA motorcycle exhibition, the 2014 Primavera is the next in Vespa's line of modern smallframes that began with the ET series. The Primavera succeeds the popular LX and LX/S lines, which are expected to be discontinued in 2014. The original line of Vespa Primaveras was built from 1968-1978.
Differences from LX Series
The new model borrows many styling elements from the limited edition Vespa 946 and integrates them into the existing LX platform. Unlike the 946, the Primavera has underseat storage, with more capacity than the LX (thanks to the relocation of the battery).
While the Primavera retains the engines in the 946 and most recent LX models (including the 3V 125/150cc engine which never appeared in a N. American LX), it also introduces a new transmission and clutch. Though the 3V has better fuel economy than the engines that preceded it, the fuel tank capacity on the Primavera is less than the LX, 8 litres (2.1 US gallons) versus the previous 8.6 litres (2.3 US gallons).
Additional changes include a 120/70-11 rear tire size, an inch taller than the LX's. This is an uncommon size (at the time of the Primavera's launch). As with the 11" front tire on the LX and Primavera, there will likely be limited options for non-stock tires. The larger tire does allow for a larger rear drum brake. The rear suspension is upgraded as well.
A full comparison of the Primavera 125/150 with the last LX models is available here
Colors and Variations
2014
The 2014 Primavera will come in the following colors: MonteBianco White, Blue Midnight, Dragon Red, Crete Senesi Brown, Marechiaro Light Blue and Vulcan Black.
Official Specifications
MODEL 2014 Primavera 125 / 150 3V
FRAME TYPE 2-arm engine mount with vibration dampeners
ENGINE TYPE 4 stroke single cylinder with electronic injection
BORE X STROKE 52 x 58.6 mm (125) / 58 x 58.6 mm
DISPLACEMENT 124.5cc / 154.8cc
MAX POWER AT SHAFT 7.9 kW at 7,700 rpm (125) / 9.5 kW at 7,750 rpm (150)
MAX TORQUE 10.4 Nm at 6,000 rpm (125) / 12.8 Nm at 6,500 rpm (150)
MAX SPEED [not stated]61mph (est.)*
FUEL/TANK CAPACITY 8 litres (2.1 US gallons)
GAS MILEAGE [not stated] 100+ MPG (est.)*
DISTRIBUTION SOHC (single overhead cam), 3 valves per cylinder
COOLING SYSTEM Forced Air Circulation
LUBRICATION Wet Sump
IGNITION Electric only (new freewheel starter)
GEARS CVT with torque server (new system unique to this model at time of launch)
CLUTCH Automatic dry centrifugal clutch with vibration dampers
EMISSIONS COMPLIANCE Euro 3, EPA, CARB
SEAT HEIGHT 780mm (30.7 in)
DRY WEIGHT [not stated]
UNDERSEAT STORAGE VOLUME 16.6 litres
LENGTH/WIDTH/WHEELBASE 1,860mm (73.23 in) / 735 mm (28.94 in) / 1340 mm (52.76 in)
FRONT TIRE/REAR TIRE Tubeless 110/70-11/ Tubeless 120/70-11
FRONT SUSPENSION Single arm with coil spring and dual action monoshock absorber - axial stroke 78 mm
REAR SUSPENSION Hydraulic monoshock - axial stroke 69 mm
FRONT BRAKE 7.87 (200 mm) steel disc with hydraulic command
REAR BRAKE 5.51 (140 mm) drum with mechanical command
*Some specs are unavailable for the Primavera at this time; Vespa's estimates for the Piaggio Fly 3V are used as rough figures until more specific ones are released.
MODEL 2014 Primavera 50 cc 2-stroke 2014 Primavera 50 cc 4-stroke 4V
Engine Single cylinder Hi-Per2: 2-stroke with 3-way catalytic converter and secondary air system SAS Single cylinder Hi-Per4: 4-stroke with 3-way catalytic converter and secondary air system SAS
Bore/stroke 40/39.3 mm 39/41.8 mm
Engine Capacity 49 cc 49.9 cc
Induction system Reed valve in crankcase 4 valves, single overhead camshaft
Starter Electric and kick starter Electric and kick starter
Lubrication Automatic mixer Wet sump
Clutch Automatic dry centrifugal clutch with vibration dampers Automatic dry centrifugal clutch with vibration dampers
Gearbox CVT with torque server CVT with torque server
Load bearing structure Sheet steel body with welded reinforcements Sheet steel body with welded reinforcements
Front suspension Single arm with coil spring and dual action monoshock absorber - axial stroke 78 mm Single arm with coil spring and dual action monoshock absorber - axial stroke 78 mm
Rear suspension Hydraulic monoshock - axial stroke 69 mm Hydraulic monoshock - axial stroke 69 mm
Front wheel rim Die-cast aluminium alloy 2.50x11 Die-cast aluminium alloy 2.50x11
Rear wheel rim Alloy 3.00x11 Alloy 2.75x11
Front tyre Tubeless 110/70-11 Tubeless 110/70-11
Rear tyre Tubeless 120/70-11" Tubeless 120/70-11"
Front brake Hydraulically operated 200 mm stainless steel disc Hydraulically operated 200 mm stainless steel disc
Rear brake 110 mm drum 140 mm drum
Length/ width 1,860/735 1,860/735
Saddle height 780 mm 780 mm
Wheelbase 1,340 1,340
Fuel tank capacity 7 litres 7 litres
Emissions compliance Euro2 Euro2
Last Updated Mon Nov 18, 2013 5:04 pm
[ Time: 0.1759s ][ Queries: 21 (0.0459s) ][ Debug on ]
