Introduction
Many traffic signals in the United States are triggered by various types of sensors in the ground. There are varying designs and types of these sensors, but almost universally they have difficulty sensing anything smaller than a car. Scooterists, bicyclists and motorcyclists often find themselves waiting through several cycles of a light without getting a green.
Fortunately, there are steps you can take to help trigger the lights. And, in some states, it's even legal to run them in some circumstances.
How Triggers Work
Sensors that detect vehicles in order to maximize the efficiency of traffic lights are called "demand-actuated" triggers. These take a number of forms including lasers, video cameras and various rollover sensors in the street. The most common ones are inductive loop sensors. Without getting into too much of the science behind this, inductive loops are essentially metal coils (wrapped around a metal core) under the street with inductance meters that detect changes in the loops' electromagnetic fields. Positioning a mass of conductive (usually metal) material over the loops or passing a similar mass over the loops alters the inductance. This change is measured by the meter and used to trigger a change in the light.
This is essentially the same technology as most metal detectors, just widened. Note that what the inductive loops detect is metal, not electromagnetic fields. This is important for the discussion of magnets, below.
If you want to read up on the science behind these, see the Links section below.
Triggering the Sensors
Positioning
The easiest way to trigger sensors is to adjust the position of your scooter on the sensors. You'll have to check out the cutouts in the road and try to determine which type of sensor you're dealing with.
The most common are Dipole and Quadropole Loops. These will usually look like circles or rectangles. A Quadropole Loop will usually be bisected by another cut or look like a side-by-side pair of cuts.
Dipole Loops:
Quadropole Loop:
Best positions:
To maximize the likelihood that an inductive loop sensor will detect your scooter, it is important to position yourself over the most sensitive portion of the loop. There are several common shapes of inductive loop sensors, each with a different "sweet spot" for bicycles and powered two wheelers as shown in Figure 1. The two most common shapes are the dipole loop (Figure 1(a)) and the quadrupole loop (Figure 1(b)). For either of these two loop patterns, position both wheels directly over the sawcut for the wire, choosing either side for the dipole loop and using the center sawcut for the quadrupole loop. (The center sawcut of the quadrupole has twice as many wires in it as the outer sawcuts and is a more sensitive location.) If the signal does not detect you, you may wish to try leaning the bike over toward the center of the dipole loop, or to either side for the quadrupole loop. Newer traffic signal installations usually feature quadrupole loops, which are better at detecting bicycles than the older dipole loops. The third type of sensor loop, the diagonal quadrupole (Figure 1(c)), is designed to provide better detection of small vehicles such as scooters positioned anywhere over the sensor.
(Source)
Dipole Loops:
Quadropole Loop:
Best positions:
(Source)
Tap the Stand
In addition to positioning, you may have some success by placing your scooter in the recommended position then tapping your center stand on the asphalt. This basically moves a mass of metal closer to the inductive loop, which may be enough to trigger the meter.
Scoot Up
If you're unable to trigger a light and there's a car waiting behind you, sometimes the best thing to do is scoot up and let the car trigger the light. Watch out for pedestrians and (of course) don;t ride out too far into the intersection.
(Legally) Run the Light
The following states have laws which permit 2-wheelers to run a light if they're not being detected and if passage is safe (no cross traffic):
North Carolina
Wisconsin
Idaho
Arkansas
Tennessee
Minnesota
Missouri
Virgina
Oklahoma
Illinois (as of Jan. 2012)
The circumstances in which you can run the light varies from state to state, so please consult each states vehicle codes. In some, you have to wait for a certain number of "full cycles"; others have time limits, etc.
North Carolina
Wisconsin
Idaho
Arkansas
Tennessee
Minnesota
Missouri
Virgina
Oklahoma
California
Because CA has to do everything differently, the state has a law (California AB 1581, signed into law in 2008) requiring cities to make their triggers sensitive enough to detect all vehicles. Each city has their own means for reporting lights that won't trigger, and the city is required to send someone out to to make the adjustment. (This program is state funded by AB1581.)
AB 1581 (excerpt): Traffic-actuated signals: bicycles: motorcycles.
(1) Existing law provides for official traffic control devices.
This bill would include as an official traffic control device a traffic-actuated signal that displays one or more of its indications in response to the presence of traffic detected by mechanical, visual, electrical, or other means. Upon the first placement of a traffic-actuated signal or replacement of the loop detector of a traffic-actuated signal, the signal would have to be installed and maintained, to the extent feasible and in conformance with professional engineering practices, so as to detect lawful bicycle or motorcycle traffic on the roadway. Cities and counties would not be required to comply with those requirements until the Department of Transportation has established uniform standards, specifications, and guidelines for the detection of bicycles and motorcycles by traffic-actuated signals and related signal timing. The Commission on State Mandates would be required to consult with the Department of Transportation regarding mandate claims relating to these provisions. This bill would provide that its provisions would remain in effect until January 1, 2018, and would be repealed on that date.
Oldest Trick in the Book
Place your scooter on the center stand. Hop off. Run over to the pedestrian crosswalk button. Hit it. Run back to scooter.
Unsurprisingly, there's a lot of debate over whether crosswalk buttons work. We'll set that aside for our purposes.
The Magnet Debate
There are a number of magnets on the market which claim to assist in triggering lights. These are usually neodynium or "rare earth" magnets that can be purchased for as much as $40. The problem with the magnet debate is that these may work, but not because they're magnets.
If you'll recall, induction loops detect metal, not other electromagnetic fields. The traffic light magnets are big, often heavy masses of metal that you affix to the bottom of your scooter. If they work at triggering lights, it has nothing to do with the fact that they're magnetized. Any similarly conductive mass of metal would have the same result.
There are a number of patent applications for devices to trigger inductive loops (links below). None of these use magnets as primary trigger. (Some use magnets or electromagnetism as part of a larger apparatus.)
So do magnets help trip lights? Not really.
Will placing a large mass of metal under your scooter help? Maybe.
It may be best to try some of the other solutions before going out and buying something that may or may not work. (Caveat: All this may differ with electromagnetic sensors, but those are rare in the US and have largely been replaced by inductive loops.)
Finally…
Something to keep in mind when gauging the efficacy of these solutions is that just because a sensor is triggered it may not change the light immediately. Even cars and trucks have to wait at lights.
Also, further confusing things, in some intersections, in-road triggers may not be working at all. Cities are constantly changing and upgrading their traffic technology and in some places, triggers may have been replaced by timers, optical devices, etc. Find out if there's a city department to handle questions and concerns about lights and try to contact them, alerting them to problematic intersections.
Links
How to position a bike (or scooter):
http://www.humantransport.org/bicycledriving/library/signals/green.htm
Snopes.com discussion:
http://message.snopes.com/showthread.php?p=330814
Patents:
http://www.patentstorm.us/patents/5652577/description.html
http://www.plan-bravo.com/lefty.html
Further reading:
http://www.humantransport.org/bicycledriving/library/signals/detection.htm
http://www.howstuffworks.com/question234.htm
http://draco.acs.uci.edu/rbfaq/FAQ/8i.2.html
http://www.tfhrc.gov/pubrds/septoct98/loop.htm
Patents:
Further reading:
Last Updated Sun Apr 15, 2012 8:00 pm
