Won't Start!
The main checks required are to establish whether your scooter is getting enough fuel, and whether there is a spark present. Click on the links below for more detailed procedures and common problems.
"Won't start" diagnosis for beginners
Fuel System | Ignition System | Battery | Immobilizer LED codes | Brake Switches | Kill switch | Starter Relay | Getting your 2 stroke to run properly | Sticky Bendix Gear
Fluid Leaks
Coolant loss | Oil leaks | Fuel loss
Noises
Strange Noises | Braking Noise | Engine/Transmission Noise
Exhaust Problems
GTS/GT Exhaust Leaks | Rusting Exhausts
Last Updated Wed Aug 31, 2011 4:40 pm
