Tue, 21 Dec 2010 19:39:20 +0000
09 190s taormina
09 190s taormina
Tue, 21 Dec 2010 19:39:20 +0000 quote
Ambitious plans. Stay tuned to see how much I manage to pull off.
Cosmetics:
total dechrome -- everything removed, black, or bodycolor
bodywork -- filled mirror holes and horn cover trim
blackout -- wheels and trans cover satin black
Motor/trans:
190 kit + upgear
Chassis:
urethane motor and shock top mounts
Running gear:
GT/S brakes and 12"wheels with low profile rubber
Exhaust:
custom exhaust -- Yosh? Leo Vince? Akra?
Tue, 21 Dec 2010 19:43:40 +0000
09 190s taormina
09 190s taormina
Tue, 21 Dec 2010 19:43:40 +0000 quote
Couple weeks in a vat of acid and your chrome parts look like this.
In theory chrome plating is a reversible process, but didn't have any luck finding a shop willing to do it with plastic parts.
Plan B: Muratic(hydrochloric) acid. Available at your local hardware. Takes a couple weeks because Vespa chrome is quality "triple-plated" stuff. Use only in a well ventilated area(outside) and dispose of properly.
Tue, 21 Dec 2010 22:26:52 +0000
T5s
T5s
Tue, 21 Dec 2010 22:26:52 +0000 quote
ha
airfix
Tue, 28 Dec 2010 06:04:51 +0000
lx125s GTS300
lx125s GTS300
Tue, 28 Dec 2010 06:04:51 +0000 quote
Hi guys
Looks like lxs very interested as I have a 125 and am wondering what to do next year , leaving her original looking as poss but thinking malossi 190, pipe and other performance up grade as needed.
New member and 1st post
Fri, 31 Dec 2010 00:18:41 +0000
S 190. Custom VNB 150
Fri, 31 Dec 2010 00:18:41 +0000 quote
cool .. let me post some pics to help inspire you. i love the idea!
i have the rims being painted black, going to get them back friday. also have a performance pipe on it. love the look.
i tinted the blinkers i love the look, kinda hard to tell with the flash but it looks sharp. also have the euro light kit in.
this is a hole closure i can paint in the orange if you would like one for your scoot, the ones from scooterwest don't fit the S so you would need a different size. drop me a line and i can send some out to you.
Fri, 31 Dec 2010 19:11:51 +0000
09 190s taormina
09 190s taormina
Fri, 31 Dec 2010 19:11:51 +0000 quote
Yeah, that's the idea.
I'm taking it a bit further and filling the the holes with plastic. Will post details when done.
Fri, 31 Dec 2010 21:53:59 +0000
Fri, 31 Dec 2010 21:53:59 +0000 quote
cool, i wanted to do something like that, but just never did. if i ever had to have it repainted i would though.
Sun, 02 Jan 2011 19:00:50 +0000
GT-200
GT-200
Sun, 02 Jan 2011 19:00:50 +0000 quote
Here is my question for all about this project. Will the hub of a GT go on the front frok of an LX or S? I am thinking about doing the same to an LX front end but didn't know if the hub would bolt on or what. I have the caliper, shock and master because I may try to fit the LX front end on a GT with some lengthening in the tube section. Straught front ends are hard to find and quite spendy.
Sun, 02 Jan 2011 20:42:05 +0000
Sun, 02 Jan 2011 20:42:05 +0000 quote
The brakes and hubs can be mixed and matched for some improvements on the on the LX but the forks need to be correct to the bike they are going on for the ride height to be correct.
http://modernvespa.com/forum/topic61069?highlight=brake#860646
Sun, 02 Jan 2011 21:03:41 +0000
GT-200
GT-200
Sun, 02 Jan 2011 21:03:41 +0000 quote
O.K. Thanks
Does anyone know how much difference there is in the lower section of an lX front verses a GT fork. How much of a ride height difference are we talking about and what would the pro's and con's be of said change? The GT shock bolts right on and the GT fender fits. I have the fork on the bike the clearances around the fender look right. The tube is just a little too short and I can't get the bars on with the shrouding and head light.
Mon, 03 Jan 2011 02:02:28 +0000
Mon, 03 Jan 2011 02:02:28 +0000 quote
read this thread. this gut did what you want to do. Vespa LX - New and improved!
Mon, 03 Jan 2011 07:02:37 +0000
09 190s taormina
09 190s taormina
Mon, 03 Jan 2011 07:02:37 +0000 quote
scootermarc69 wrote:
this guy did what you want to do.
Yeah, got the idea from that thread and this one:
Rosebud LX200 Super Special
Sat, 22 Jan 2011 20:04:37 +0000
09 190s taormina
09 190s taormina
Sat, 22 Jan 2011 20:04:37 +0000 quote
Update: bodywork pics.
Liquid ABS. http://www.oatey.com/Plumber/Shared/ProductGroupDetail/167/ABS+Medium+Black+Cement.html
Simply tape up one side of the hole and fill. Multiple thin layers to prevent voids.
Pros:
= original material
solvent "welds " to original material
sands easily to shape
Cons:
voids/pinholes as it skins over then outgasses as it cures.
Sat, 22 Jan 2011 20:13:30 +0000
09 190s taormina
09 190s taormina
Sat, 22 Jan 2011 20:13:30 +0000 quote
Update: tires finally arrived from the Netherlands.
Key piece to making this project work -- 12" low profile rubber. Diameter same as OE 10/11"s
110/60-12 Maxxis. Upmarket Cheng Shins.
Sat, 22 Jan 2011 23:55:35 +0000
ET2
ET2
Sat, 22 Jan 2011 23:55:35 +0000 quote
But wouldn't a low profile tyre mess up your handling due to not being the correct shape? Its all good on a car as they don't have a curved profile on the tyres, i cant see it working well on a bike....
Sun, 23 Jan 2011 00:31:46 +0000
09 190s taormina
09 190s taormina
Sun, 23 Jan 2011 00:31:46 +0000 quote
Correct shape?
These will be sportbike tires on a scooter.
Sun, 23 Jan 2011 01:05:45 +0000
Sun, 23 Jan 2011 01:05:45 +0000 quote
i will say to go through all the mess of ordering the tires and all you probally know that they will performe just fine, but it also to me seems like you need the curve of the tire to get the proper performance out of motorcycle tires. but like i said you must have done your homework.
let me know how it goes with the tires. they look great!
Sun, 23 Jan 2011 01:19:52 +0000
Sun, 23 Jan 2011 01:19:52 +0000 quote
And then tell that to those who run on the 'darkside'.
You can get used to almost any tyre's profile. Which is why many don't notice theirs are shagged... (including me on a couple of occasions).
Sun, 23 Jan 2011 03:07:27 +0000
ET2
ET2
Sun, 23 Jan 2011 03:07:27 +0000 quote
bluecloud wrote:
Correct shape?
Well on the standard 12" rim you will have the normal tyre and that makes a roughly semi-circular shape right?
If you reduce the overall diameter without reducing the rim then surely you have to make the profile less curved and more flat right? which in turn means that when you lean the bike over in a corner, your running on the edge of the tyre and the contact patch is smaller.
Or maybe i'm talking shite, i'm not really sure
If you could post a pic of the tyre when you have it fitted that would be great, i am really interested to see this.
Sun, 23 Jan 2011 03:26:21 +0000
Sun, 23 Jan 2011 03:26:21 +0000 quote
I suspect yes.
Mon, 24 Jan 2011 08:41:34 +0000
Mon, 24 Jan 2011 08:41:34 +0000 quote
I'm right there with you on this project but powder-coat the stock wheels (size)and leave them. If you want more tire choices than the 11 inch rims can offer throw an ET 10 rim on and you can get whatever size 10 inch tire you want, they make a ton of 10 inch tires.
Mon, 24 Jan 2011 16:50:47 +0000
09 190s taormina
09 190s taormina
Mon, 24 Jan 2011 16:50:47 +0000 quote
Wheels are the the whole point of the project. Want the GT brakes.
Mon, 24 Jan 2011 19:19:48 +0000
LX50/150
LX50/150
Mon, 24 Jan 2011 19:19:48 +0000 quote
I own the black LX with the MP3 wheel and Brembo setup on the front that was mentioned earlier in the thread.
I have quite a few thousands miles on my new setup and there have been no problems whatsoever with the swap. I have a lot of experience with both the stock size and the low profile 12" size and the handling is very nice and the bike never wants to just lose grip when leaned over in the corners.
Good luck with the project and try not to grab the lever too much and go over the handlebars when you get those big brakes (relatively speaking of course) installed!
If you have any questions feel free to ask.
Wed, 26 Jan 2011 02:43:40 +0000
Wed, 26 Jan 2011 02:43:40 +0000 quote
it will look bad ass... can't wait to see the outcome
Wed, 26 Jan 2011 11:44:00 +0000
'09 S50, '79 V50
'09 S50, '79 V50
Wed, 26 Jan 2011 11:44:00 +0000 quote
Yep, liking this! 8)
Wed, 26 Jan 2011 18:17:27 +0000
09 190s taormina
09 190s taormina
Wed, 26 Jan 2011 18:17:27 +0000 quote
Yeah,me too.
Getting close. Wheels are out for powdercoat. Axle is at the welders. Still missing a key part though -- anybody got a GT final drive idler gear they don't need? Might have to break down and buy new.
Sat, 29 Jan 2011 21:39:41 +0000
09 190s taormina
09 190s taormina
Sat, 29 Jan 2011 21:39:41 +0000 quote
Update: modified GT axle, cut and welded. Only piece of the project that's not "parts bin."
GT vs LX/S bearings = different size but similar specs -- longevity shouldn't be an issue.
Sat, 29 Jan 2011 21:45:07 +0000
09 190s taormina
09 190s taormina
Sat, 29 Jan 2011 21:45:07 +0000 quote
Update: partially assembled pics. A long way from running yet, but this is what it's gonna look like.
Really looks stuffed in there at the back, fender will definitely require modification.
Sun, 30 Jan 2011 18:26:50 +0000
Sun, 30 Jan 2011 18:26:50 +0000 quote
hot damn. i like.
Mon, 31 Jan 2011 03:25:18 +0000
GT-200
GT-200
Mon, 31 Jan 2011 03:25:18 +0000 quote
That does look great are the wheels painted? I will be interested to here how it rides. I bought a project GT to build just so I could get 12 inch wheels, well the the liquid 200 was also a big pull. But after reading about the steering shake that comes with the bigger bike I have been having second thoughts.
Mon, 31 Jan 2011 16:35:11 +0000
09 190s taormina
09 190s taormina
Mon, 31 Jan 2011 16:35:11 +0000 quote
ctl73 wrote:
will be interested to hear how it rides
Yeah, that's the big unknown. Either will be the greatest modern Vespa known to man, or an expensive exercise in futility. Somebody had to do it, was it possible?
If this works, suspect it will be the first of many. Pretty much a simple parts swap. So far looks like the only pieces that have to be modified are the axle and rear fender.
It's all down to form and function. Looks? Handling?
And it's all reversible if it doesn't work.
Tue, 01 Feb 2011 22:23:25 +0000
2006 LX150 and 2006 GTS
Tue, 01 Feb 2011 22:23:25 +0000 quote
I'm looking forward to seeing more of your progress and the finished product. Great work!!!
Sun, 06 Feb 2011 10:02:15 +0000
vespa s50 4t 4v
vespa s50 4t 4v
Sun, 06 Feb 2011 10:02:15 +0000 quote
Hi
what a good project
I have a vespa S 50cc with a mp3 12 inch frontwheel.
and I like the rear end 12 inch conversion.
I am wondering if its possible to use a 12 inch rearwheel,
from a piaggio fly.
my only worry is the drumbrake, is it the same size,
I don't need a discbrake on the rear, my scoot is only 50cc
Sun, 06 Feb 2011 16:13:28 +0000
09 190s taormina
09 190s taormina
Sun, 06 Feb 2011 16:13:28 +0000 quote
svendevries wrote:
I am wondering if its possible to use a 12 inch rearwheel from a piaggio fly. my only worry is the drumbrake, is it the same size?I
Fly 50 maybe.
Quick check of parts book looks like it might work. Need to stop by your dealer and take some measurements. Definitely will need low profile rubber to fit. Get the tires here: http://www.daxdodo.com/catalog/index.php
Sun, 06 Feb 2011 16:36:56 +0000
vespa s50 4t 4v
vespa s50 4t 4v
Sun, 06 Feb 2011 16:36:56 +0000 quote
I have a 110/60-12 fronttyre, on the rear I want the same size.
www.4strokeparts.be is cheaper than daxdodo.com
next week I will visit some dealers
Mon, 14 Feb 2011 15:22:38 +0000
09 190s taormina
09 190s taormina
Mon, 14 Feb 2011 15:22:38 +0000 quote
Update: it runs.
No big brake up front yet, but able to get a feel for the handling. Rear axle position is approx 2" rearward and 0.5" lower than stock -- combined with heavier wheel/tire/hub assys seems to slow things down a bit. Turn-in not as twitchy and a bit more stable at speed, feels like a bigger bike. Pretty much as expected.
Rear disc not significantly more powerful, but hydraulic modulation is huge improvement.
Rear fender cut and moved approx 0.75" rearward and angled 15 deg.
Issues:
1) rear master won't fit the bar cover without modification -- interference with signal switch. Fix is countersunk screw on bar clamp.
2) centerstand is short -- works but rear wheel touches ground. Fix -- GT stand or weld additional length.
3) rear wheel is offset approx 0.25" to right -- had to add spacer washers at exhaust bracket for clearance. Think this may be due to difference in wheel offset as front appears same.
Mon, 14 Feb 2011 15:57:02 +0000
Mon, 14 Feb 2011 15:57:02 +0000 quote
Man that is so cool.
Sat, 19 Feb 2011 21:56:15 +0000
pitbike
pitbike
Sat, 19 Feb 2011 21:56:15 +0000 quote
lovin the tyres!
what size wheels do u have on that bike?
Mon, 21 Mar 2011 18:55:14 +0000
'80 p200, '76 150 super, '66 125
Mon, 21 Mar 2011 18:55:14 +0000 quote
Great work. You should make a new pipe to hug that cowl. The stock pipe looks like ass.
BTW - did you weld that shaft in a jig on a lathe? or how did you keep it true?
Mon, 21 Mar 2011 20:50:39 +0000
LX150 Darling Plum; GTS 250 Dragon Red; Honda Big Ruckus Demented Bastard
Mon, 21 Mar 2011 20:50:39 +0000 quote
Hope all is going well on this project, and at this point it might be done?? From the last pictures this looks very nice, and you will have a very unique scoot...
Please update pics as soon as you can.. Would love to see this when finished!!!
[ Time: 0.0528s ][ Queries: 6 (0.0276s) ][ Debug on ][ 276 ][ Thing Two ]
