Update: it runs.
No big brake up front yet, but able to get a feel for the handling. Rear axle position is approx 2" rearward and 0.5" lower than stock -- combined with heavier wheel/tire/hub assys seems to slow things down a bit. Turn-in not as twitchy and a bit more stable at speed, feels like a bigger bike. Pretty much as expected.
Rear disc not significantly more powerful, but hydraulic modulation is huge improvement.
Rear fender cut and moved approx 0.75" rearward and angled 15 deg.
Issues:
1) rear master won't fit the bar cover without modification -- interference with signal switch. Fix is countersunk screw on bar clamp.
2) centerstand is short -- works but rear wheel touches ground. Fix -- GT stand or weld additional length.
3) rear wheel is offset approx 0.25" to right -- had to add spacer washers at exhaust bracket for clearance. Think this may be due to difference in wheel offset as front appears same.
