Mon, 16 May 2011 22:17:47 +0000
Scooter Pimp
Scooter Pimp
Mon, 16 May 2011 22:17:47 +0000 quote
Created article CVT Principles - How it works, how to improve it....
Mon, 16 May 2011 22:55:43 +0000
Mon, 16 May 2011 22:55:43 +0000 quote
Edited to change:
To optimise the scooter's performance the engine needs to be running at its maximum horsepower output consistently while accelerating
to:
'To optimise the scooter's performance the engine needs to be running at its maximum torque output consistently while accelerating '
It might be worth adding that top speed is achieved when the maximum horsepower hits the limits of drag (friction and air resistance).
Tue, 17 May 2011 11:23:02 +0000
Scooter Pimp
Scooter Pimp
Tue, 17 May 2011 11:23:02 +0000 quote
Edited, to make changes to the terminology/wording after receiving suggestions from several Mvers.
Thank you all!!!
Fabio
Tue, 17 May 2011 11:52:14 +0000
Tue, 17 May 2011 11:52:14 +0000 quote
Have you edited the main index page to point to it? I note a few others of your excellent articles also can't be reached from the main page...
Tue, 17 May 2011 11:55:27 +0000
Scooter Pimp
Scooter Pimp
Tue, 17 May 2011 11:55:27 +0000 quote
Jim
I must admit I don't know how to do that??
I tried before but struggled a touch - I think its because the main index page is locked to me.
Can you point me in the right direction please if you would be so kind.
Fabio
Tue, 17 May 2011 12:12:07 +0000
Tue, 17 May 2011 12:12:07 +0000 quote
Edit the most likely pages where folk would look for such an article from the main menu, perhaps in the New User Frequently Asked Questions , and also in the Glossary of Terms (there is already a mention of Variator there).
If you think a new category needs to be added to the main page, just contact one of the Wiki Moderators - they should be able to help.
Tue, 17 May 2011 12:44:43 +0000
Scooter Pimp
Scooter Pimp
Tue, 17 May 2011 12:44:43 +0000 quote
I've had a look at the Wiki and I must admit that I find it hard to navigate (the layout of the sections and their contents I don't find too intuitive - I also find the search function hard to use - It produces many results but hides what you're really looking for in the masses of results that it generates - both of these are probably fine and the problem is more just down to how my brain works but I do recall reading threads where other users were saying similar things)
I was thinking that a new section could be created in the Wiki perhaps called "How to", would that be useful maybe? What do you think?
Fabio
Tue, 17 May 2011 12:54:24 +0000
Tue, 17 May 2011 12:54:24 +0000 quote
Perhaps a 'Tutorials' section as well - the problem is that many articles would be searched for by people coming from all sorts of positions - newbies looking for background stuff, oldies looking for an article to reference in some other post, or just looking for procedures or projects.
Perhaps the whole Wiki menu needs a re-think on the categories. Organisation isn't one of my strong points, so I'm stepping aside on this one!
Tue, 17 May 2011 13:58:14 +0000
Scooter Pimp
Scooter Pimp
Tue, 17 May 2011 13:58:14 +0000 quote
Yes I understand...
If a Wiki Moderator reads this then perhaps they can create for me a "How to/Tutorials" section, and then i can post my articles into that?
Fabio.
Tue, 17 May 2011 15:51:34 +0000
Wiki Moderator
Wiki Moderator
Tue, 17 May 2011 15:51:34 +0000 quote
There are some pretty tough navigation/organization issues with the Wiki that probably continue to prohibit its use.
Your (excellent) article is so comprehensive, it fits into many places: Modifications, Routine Maintenance and some categories that don't yet exist.
I think many people just go to the "All Articles" page and look for what they need there. This is how I use the Wiki.
Personally, I'm not sure a "How To" section is right for this, because it's not a step-by-step tutorial as much as an explainer of what all these things are and what they do.
I'm wondering if we can create another category that may suit it better and encourage more articles like this. A "How Scooters Work" (or some such) category, maybe?
Tue, 17 May 2011 16:06:00 +0000
Scooter Pimp
Scooter Pimp
Tue, 17 May 2011 16:06:00 +0000 quote
Hi Eric
Yes this is the problem, when I'm trying to find articles on the wiki (or when using the site's search function for that matter) I never know where to start looking...
Of the articles I've written, I think most of them are based around a "How to" or "How it works", or the theory/principles of such.....
> Getting Your 2-Stroke to Run Properly
> 2-Stroke Carburetor Set-up Technique
> How to use a MULTIMETER to diagnose electrical problems.
Perhaps we can have a category called "Theory/How it works/How to..." , or the such like?
Fabio
Fri, 20 May 2011 21:39:05 +0000
Scooter Pimp
Scooter Pimp
Fri, 20 May 2011 21:39:05 +0000 quote
I'm trying to add a new section to the wiki main page, but its locked??
How do I do unlock this??.... so that I can set up a section titled "Theory/How it works/How to..." , or the such like?
Fabio
Fri, 20 May 2011 21:46:54 +0000
Wiki Moderator
Wiki Moderator
Fri, 20 May 2011 21:46:54 +0000 quote
It's locked to prevent people from adding sections as they will.
The problem is, adding "Theory/How it works/How to..." will necessitate a lot of reorganization! I'm going to discuss with other Wiki mods and see if there's any agreement on a solution.
Fri, 20 May 2011 22:15:29 +0000
Scooter Pimp
Scooter Pimp
Fri, 20 May 2011 22:15:29 +0000 quote
That will be so brilliant of you!!
Thank you Eric.
Fabio
Wed, 08 Jun 2011 15:25:56 +0000
Scooter Pimp
Scooter Pimp
Wed, 08 Jun 2011 15:25:56 +0000 quote
Any further thoughts here?
Fabio
Wed, 08 Jun 2011 18:20:28 +0000
Wiki Moderator
Wiki Moderator
Wed, 08 Jun 2011 18:20:28 +0000 quote
It's been discussed but has sort of inspired a re-examination of the organization of that main page.
I think maybe a section called "Technical Reference and Fundamentals" might cover it.
I'll propose this and get back to you soon as I hear something. Thanks for your patience!
Wed, 08 Jun 2011 18:37:17 +0000
Scooter Pimp
Scooter Pimp
Wed, 08 Jun 2011 18:37:17 +0000 quote
Hi Eric,
"Technical Reference and Fundamentals" sounds fairly spot on to me!!
If you would like some ideas/thoughts/input into the re-organisation of the main page please shout up... I'd be glad to help!
Thanks once again
Fabio
Wed, 08 Jun 2011 21:42:56 +0000
Wiki Moderator
Wiki Moderator
Wed, 08 Jun 2011 21:42:56 +0000 quote
Okay, for now...
As there's already a Reference section, the article was placed there. We don't have enough of these encyclopedic "explainer" type of articles to create a separate section-yet. I would love to see more of these things, but understanding the workings of the CVT helped me immensely when I started doing maintenance on it.
I've got a 4T vs. 2T post I did elsewhere that will work well for this section. Articles on carbs and fuel injection, the electric system, etc. would be great, too.
So, keep up the good work. I'm going to add some of these to the Wiki wish list.
Also, one suggestion/request: Shorter slugs! We can't change them after the fact without causing havoc.
Sun, 19 Jun 2011 17:41:40 +0000
Scooter Pimp
Scooter Pimp
Sun, 19 Jun 2011 17:41:40 +0000 quote
Edited to include a Video link to youtube.
Sat, 25 Jun 2011 09:11:10 +0000
Scooter Pimp
Scooter Pimp
Sat, 25 Jun 2011 09:11:10 +0000 quote
Amended........ to explain about going too light with rollers weights, and the problem that it may lead to.
⬆️    About 33w elapsed between posts    ⬇️
Fri, 10 Feb 2012 17:07:35 +0000
Vespa 150 . Tuned Chinese electric scooter! Honda 600 Silverwing powered reverse trike.
Fri, 10 Feb 2012 17:07:35 +0000 quote
No one has mentioned (I don't think) another reason for the "angled grooves" on which the rear pulley moves, Sometimes the rear pulley is refered to as a "torque drive". When you close the throttle the engine braking applies a pulling force to the bottom run of the drive belt. This pulls one side of the rear pulley along the angled grooves effectively forcing the pulley halves together. This reduces the effective "gear ratio", which stops the motor from bogging down when you want to pull away again.
Fri, 10 Feb 2012 18:02:30 +0000
Wiki Moderator
Wiki Moderator
Fri, 10 Feb 2012 18:02:30 +0000 quote
Anyone can edit the articles, you know.
Mon, 28 Jul 2014 12:05:59 +0000
Aprilia Sportcity one
Mon, 28 Jul 2014 12:05:59 +0000 quote
I have a question on this:
I think I understand how the whole thing works, BUT however one thing seems strange to me:
On main aim of the CVT is to keep the motor RPM constant at the best point.
but it need changes in rpm to alter the variator, right?
This means the front puley rpm remains constant (more or less), right?
But then I don't get how the weights are driven outwards.
Or is the front pulley rpm not equal to the engines rpm?
I thought rpm only changes at the rear pulley/ rear wheel.
Sorry for the confusion.
⬆️    About 27d elapsed between posts    ⬇️
Sun, 24 Aug 2014 19:10:19 +0000
Scooter Pimp
Scooter Pimp
Sun, 24 Aug 2014 19:10:19 +0000 quote
Amended...changed confusing terminology that I'd used between belt width and belt thickness
Sun, 24 Aug 2014 19:51:37 +0000
Scooter Pimp
Scooter Pimp
Sun, 24 Aug 2014 19:51:37 +0000 quote
Amended....added a clarification note regarding removing the restrictor washer
Tue, 23 Sep 2014 05:18:31 +0000
250 GT
250 GT
Tue, 23 Sep 2014 05:18:31 +0000 quote
What are the stock rollers in a Vespa 250 GTS made of? I presume all, including Dr. Pulleys, are synthetic... is that correct?
Also, are replacement "sliders", as opposed to rollers, more effective because they tend not to flatten out because the have the flat sides to begin with, so they simply stay in the trajectory of travel smoothly?
It is time to replace my rollers and I'd like to get a little more performance so Dr. Pulleys seem to be the answer, but... I am not quite sure why they add the performance, unless my assumption is correct. With mechanical things, I try not to act on my assumptions so an explanation would be greatly appreciated!...
Thanks for the awesome tutorial!
Sun, 28 Sep 2014 19:56:27 +0000
Scooter Pimp
Scooter Pimp
Sun, 28 Sep 2014 19:56:27 +0000 quote
Most rollers that I've come across are made of a central "ring" of metal encased in a resin/plastic sleeve......
Like this--->
Sliders have more resin and are shaped like this--->
Watch here to see a good explanation...........
Sat, 04 Oct 2014 16:31:48 +0000
GTS300ss
GTS300ss
Sat, 04 Oct 2014 16:31:48 +0000 quote
Excellent article clear and concise enjoyed reading the article and watching the video. I knew the basics of bike mechanics but was not sure how CVT worked now I know, really simple idea .I know its a few years old but just read it today.
Thanks for taking the time to post it.
Sun, 05 Oct 2014 08:49:18 +0000
Scooter Pimp
Scooter Pimp
Sun, 05 Oct 2014 08:49:18 +0000 quote
You're very welcome.....
Sun, 05 Oct 2014 09:21:28 +0000
Scooter Pimp
Scooter Pimp
Sun, 05 Oct 2014 09:21:28 +0000 quote
Edited the Wiki article to include information on Dr Pulley Sliders..............
Sun, 25 Jun 2017 01:18:18 +0000
2017 Vespa GTS 300ie
Sun, 25 Jun 2017 01:18:18 +0000 quote
Thank you, Fabio!
I really enjoyed reading your article and find it very informative.
Although I'm an old timer with regards to performance vehicles, I'm new to the Vespa world and CVT/fuel injected scooters! My new '16 Primavera is awesome and although I only have 700 miles on it, I've done a few mods . I did the LED and turn signal pod removal mods (like Euro models) and some cosmetic mods and add-ons. Now, I'm ready for the Variator hop-up mod.
I already bought the tool, the Malossi 12.5g roller weights as well as the 9.5g Dr. Pulley sliders. I'm not quite sure on what to use but most write ups seem to favor the sliders instead of the rollers.
I also have not seen anything about dry hand-polishing the channels that the sliders move in. That, to me would make sense, wouldn't it? ...or is it a worthless effort for not much gain? I also read about the pros and cons of dry-lubricating the channels with some powder teflon stuff. They're on one side of an enclosed variator; away from the drive belt channel, so it should be OK?
Thanks again for all your informative help!
⬆️    About 4y elapsed between posts    ⬇️
Tue, 24 Aug 2021 16:34:51 +0000
0:7 And counting
0:7 And counting
Tue, 24 Aug 2021 16:34:51 +0000 quote
I've done some re-formatting of the article to use section tags instead of list tags, which are being phased out.
Tue, 24 Aug 2021 17:48:15 +0000
0:7 And counting
0:7 And counting
Tue, 24 Aug 2021 17:48:15 +0000 quote
I've also updated the locations of several of the uploaded images, as they were being redirected from older locations.
[ Time: 0.0304s ][ Queries: 4 (0.0025s) ][ Debug on ][ 276 ][ Thing Two ]
