Tue Aug 16, 2011 6:57 am
'60 Allstate VNB1, '60 GS150 VS5, '61 Cushman VBB1, '62 GS160 Mk1 VSB1, '64 GL VLA1, '74 Rally VSE1 200 Euro, '78 P200e VSX, '06 LX150
Tue Aug 16, 2011 6:57 am linkquote
Is the body SN located anywhere else but behind the top of the "carb" door?
On the VS5 I just bought, the paint is so pretty at that location it is a shame to buff a slot.
Tue Aug 16, 2011 7:38 am
1952 Allstate, 1955 VL1, 1953 VM1, Sprint Veloce, 1966 SF Blue Badge
Tue Aug 16, 2011 7:38 am linkquote
The VIN# on my VS5 is on the frame lip just under the glovebox cowl. I think they moved it here with this version.
Tue Aug 16, 2011 9:11 am
Tue Aug 16, 2011 9:11 am linkquote
Should be here
http://www.flickr.com/photos/31186920@N03/5416815930/
Wed Aug 17, 2011 11:56 am
Wed Aug 17, 2011 11:56 am linkquote
On my VS5 (early) the VIN is written on the carb door, not on the frame under the glovebox cowl.
Wed Aug 17, 2011 3:14 pm
74 Rally 200 - 70 Sprint Veloce - 68ish Bajaj VBA - wifes 1970 V90 - 77 NYPD Sprint Veloce
Wed Aug 17, 2011 3:14 pm linkquote
Screw you guy's, I want a GS 150.
Wed Aug 17, 2011 5:19 pm
'60 VS5, '63 Li 150 Special, '07 PX125
Wed Aug 17, 2011 5:19 pm linkquote
IIRC the they changed the VIN location for VS5s mid-series, so early will have it behind the "carb door", later will have it under the glovebox cowl.
Wed Aug 17, 2011 7:28 pm
Wed Aug 17, 2011 7:28 pm linkquote
Re: GS 150 VS5 - Location of SN
jwilliams wrote:
On the VS5 I just bought...
Pics?
Wed Aug 17, 2011 9:56 pm
Wed Aug 17, 2011 9:56 pm linkquote
+1 i always like seeing Jim pics
Wed Aug 17, 2011 10:38 pm
Wed Aug 17, 2011 10:38 pm linkquote
Around late 60' they moved the numbers from the door frame to under the G.Box cowl on the frame. Photos are of the GS I just finished.
Thu Aug 18, 2011 8:44 pm
Thu Aug 18, 2011 8:44 pm linkquote
:drool:
Fri Aug 19, 2011 12:51 am
Fri Aug 19, 2011 12:51 am linkquote
Indeed, that GS looks amazing !
⬆️    About 11 years elapsed between posts    ⬇️
Fri May 06, 2022 4:48 am
Several vespa's
Several vespa's
Fri May 06, 2022 4:48 am linkquote
Hi,
Really old topic but hope someone is able to help me;-)
Just bought a GS 150 (VS5) which has been standing still for 52 years but I can't find the framenumber anywhere (not even a single letter or anyrhing.
I have only seen VS5 where the framenumber is behind the carb door. I have the first original papers from the scoot and this documents says: framenumber under the glovebox. Happy that you guys confirmed this that VS5 switched the location of the framenumber during production.
I attached 3 pictures :
-1 from behind the carb door
- 1 under the glovebox
- 1 from under the glovebox where the IGM number is cleary visible.
Had GL's before where the number was almost completely gone under the glovebox because of rust and mud in the years of the sparewheel but it seems strange to me that the IGM number is in perfect shape and then the framenumber will completely be gone? Do you guys knows VS5 where the framenumber was on a different location? Even checked the engine side (location of large after '65) but nothing.
Best,
Peter
Fri May 06, 2022 4:49 am
Several vespa's
Several vespa's
Fri May 06, 2022 4:49 am linkquote
Next pic
Fri May 06, 2022 4:50 am
Several vespa's
Several vespa's
Fri May 06, 2022 4:50 am linkquote
And last
Fri May 06, 2022 4:52 am
Several vespa's
Several vespa's
Fri May 06, 2022 4:52 am linkquote
1 overview pic
Fri May 06, 2022 5:46 am
Fri May 06, 2022 5:46 am linkquote
Look on the backside of frame under the IGN number. Should have the stamp impression of the numbers. Prob can use some paper with black chalk/mark to get a better impressions of numbers.
Try other locations behind the frame near the carb door, too if not in the back of scooter.
If not under those location could be replacement frame.
Sat May 07, 2022 4:09 am
Several vespa's
Several vespa's
Sat May 07, 2022 4:09 am linkquote
Thanks for your tips! Will going to check this tomorrow.. otherwise have to go the road registration and hope they will stamp in the same new number.
Peter
Tue May 10, 2022 4:44 pm
Vespa
Vespa
Tue May 10, 2022 4:44 pm linkquote
I thought only the GS vs5 for Cushman have frame # under the glovebox cowl?
@Peter
Is your GS a Cushman?
Tue May 10, 2022 10:09 pm
Several vespa's
Several vespa's
Tue May 10, 2022 10:09 pm linkquote
Hi,
No it is a MISA!
Haven't found it yet..
Peter
[ Time: 0.0374s ][ Queries: 7 (0.0144s) ][ Debug on ][ 211 ][ Thing One ]
