Is the body SN located anywhere else but behind the top of the "carb" door?
On the VS5 I just bought, the paint is so pretty at that location it is a shame to buff a slot.
![]() '60 Allstate VNB1, '60 GS150 VS5, '61 Cushman VBB1, '62 GS160 Mk1 VSB1, '64 GL VLA1, '74 Rally VSE1 200 Euro, '78 P200e VSX, '06 LX150
Posts: 814 Location: Half Moon Bay, CA |
Tue, 16 Aug 2011 14:57:53 +0000
quote
On the VS5 I just bought, the paint is so pretty at that location it is a shame to buff a slot. |
Tue, 16 Aug 2011 15:38:41 +0000
1952 Allstate, 1955 VL1, 1953 VM1, Sprint Veloce, 1966 SF Blue Badge
Posts: 184 |
Posts: 184 |
quote
The VIN# on my VS5 is on the frame lip just under the glovebox cowl. I think they moved it here with this version.
Tue, 16 Aug 2011 17:11:48 +0000
Posts: 1916 |
Wed, 17 Aug 2011 19:56:40 +0000
quote
On my VS5 (early) the VIN is written on the carb door, not on the frame under the glovebox cowl.
![]() 74 Rally 200 - 70 Sprint Veloce - 68ish Bajaj VBA - wifes 1970 V90 - 77 NYPD Sprint Veloce
Posts: 340 Location: Atlanta |
![]() '60 VS5, '63 Li 150 Special, '07 PX125
Posts: 837 Location: Seoul |
Thu, 18 Aug 2011 01:19:44 +0000
quote
IIRC the they changed the VIN location for VS5s mid-series, so early will have it behind the "carb door", later will have it under the glovebox cowl.
![]() 946
Posts: 6165 Location: Acworth, GA |
Thu, 18 Aug 2011 03:28:15 +0000
quote
Re: GS 150 VS5 - Location of SN
jwilliams wrote: On the VS5 I just bought... |
![]() Thu, 18 Aug 2011 05:56:41 +0000
Posts: 5794 Location: Indo |
![]() a not so normal vbb2 '64, a weirdo vbx '86, a not so normal pts100 '82 and a yellow sunshine '74 sprint
Thu, 18 Aug 2011 06:38:51 +0000
quote
Around late 60' they moved the numbers from the door frame to under the G.Box cowl on the frame. Photos are of the GS I just finished.
Positive
![]() 946
Fri, 19 Aug 2011 08:51:09 +0000
Posts: 1916 |
Fri, 06 May 2022 12:48:19 +0000
Several vespa's
Posts: 6 Location: Amersfoort |
Several vespa's
quote
Hi,
Really old topic but hope someone is able to help me;-) Just bought a GS 150 (VS5) which has been standing still for 52 years but I can't find the framenumber anywhere (not even a single letter or anyrhing. I have only seen VS5 where the framenumber is behind the carb door. I have the first original papers from the scoot and this documents says: framenumber under the glovebox. Happy that you guys confirmed this that VS5 switched the location of the framenumber during production. I attached 3 pictures : -1 from behind the carb door - 1 under the glovebox - 1 from under the glovebox where the IGM number is cleary visible. Had GL's before where the number was almost completely gone under the glovebox because of rust and mud in the years of the sparewheel but it seems strange to me that the IGM number is in perfect shape and then the framenumber will completely be gone? Do you guys knows VS5 where the framenumber was on a different location? Even checked the engine side (location of large after '65) but nothing. Best, Peter ![]() |
Fri, 06 May 2022 12:49:39 +0000
Several vespa's
Several vespa's
Fri, 06 May 2022 12:50:41 +0000
Several vespa's
Several vespa's
Fri, 06 May 2022 12:52:06 +0000
Several vespa's
Several vespa's
![]() GL, PK, PE200 with hack, Sears Rust Badge
Posts: 1342 Location: Deep in the heart of Texas |
Fri, 06 May 2022 13:46:32 +0000
quote
Look on the backside of frame under the IGN number. Should have the stamp impression of the numbers. Prob can use some paper with black chalk/mark to get a better impressions of numbers.
Try other locations behind the frame near the carb door, too if not in the back of scooter. If not under those location could be replacement frame. |
Sat, 07 May 2022 12:09:05 +0000
Several vespa's
Several vespa's
quote
Thanks for your tips! Will going to check this tomorrow.. otherwise have to go the road registration and hope they will stamp in the same new number.
Peter |
Wed, 11 May 2022 00:44:42 +0000
quote
I thought only the GS vs5 for Cushman have frame # under the glovebox cowl?
@Peter Is your GS a Cushman? |
Wed, 11 May 2022 06:09:07 +0000
Several vespa's
Several vespa's
