Thu, 31 May 2012 02:07:32 +0000
2009 MP3 500
2009 MP3 500
Thu, 31 May 2012 02:07:32 +0000 quote
Hi all am new to site (joined in April)also first post. Have gotten allot of info. Off site thanks to you all. Just wanted to share how I mounted side cases in hopes of helping others that are interested in doing the same. Ordered the cheapest set of side case mounts I could find they are for a BMW F650GS (2000/2004) PL188-KL188
From Givi purchased off Ebay. Knowing I would be cutting them up anyway but to my surprise very little in fabricating had to be done. Here is a list of materials used.
2- 1" Two piece shaft collars drilled and tapped on one side to 1/4"-20
1-small piece of 1"X 1" x1/16" angle iron (only using two 1" pieces)
2- 10mm dia. X 5/8" long spacers drilled so 6mm bolt to pass thru.
1- piece of 1" X 1/8" flat iron (2' long)
2- 3/8-16 bolts 3/4" long, 2- 3/8" flat washers, 2- 3/8" acorn nuts & 2- 3/8" lock washers
2- 5/16-18 bolts 1/2" long, 2- 5/16" flat washers, 2- 5/16" nuts & 2- 5/16" lock washers
2- 1/4-20 bolts 1/2" long, 2- 1/4" flat washers, & 2- 1/4" lock washers
2- 6mmX 50mm bolts & 2- 6mm flat washers
Will reuse 2- 6mm bolts from body panel
Everything else came with side brackets.
side case mounts as they came
made brackets to fit cross bar to OME top case brackets
next found that long corner on mount crossed right over body panel bolt that is part of frame so removed bolt made a spacer , cut and flattened bracket, drilled hole and installed 6mmX50mm bolt with flat washer
next used 1" collar and angle iron to make top connection
used original body panel bolt at back of bracket to cross bar with spacer that came with side bracket .
just some of parts used note how drilled and tapped collar for angle iron attach point
how they look on scoot
how mounted to body panel
afew pictures after painting & installing both sides then adding GIVI E41 side cases
Thu, 31 May 2012 02:25:07 +0000
2007 Piaggio MP3 250 (sold) and 2009 MP3 400 (sold) 2011 CanAm Spyder RSS
Thu, 31 May 2012 02:25:07 +0000 quote
Fantastic job and pictures!
Thu, 31 May 2012 02:32:08 +0000
2009 MP3 500
2009 MP3 500
Thu, 31 May 2012 02:32:08 +0000 quote
Thanks. Found site looking for side case mounts and have gained so much information thanks to everyone else for posting there ideas, problems and solutions !
Thu, 31 May 2012 02:48:46 +0000
MP3 500 (no - longer); 2008 Victory Vision (gone), 2012 Goldwing (gone), 2019 Wee-Strom
Thu, 31 May 2012 02:48:46 +0000 quote
Nice job and pictorial! Many will take advantage of this, I am sure.
Thu, 31 May 2012 02:49:05 +0000
Bracketmeister
Bracketmeister Emeritus (retired)
Bracketmeister
Thu, 31 May 2012 02:49:05 +0000 quote
STUPENDOUS first post. Please give a little more explanation of the spacers; did you drill out the existig hole in the tupperware and the spacer fits through, or is the body panel being squeezed between the nut underneath and the spacer on top of it?
I bet you could fit one or a pair of Rotopax gas cans in there and still have plenty of room to boot. Great job!
Thu, 31 May 2012 02:50:00 +0000
NC700XD
NC700XD
Thu, 31 May 2012 02:50:00 +0000 quote
That looks good. It's a much snugger fit to the sides than I've seen on previous attempts. Those side cases are HUGE!
I'd love to hear some longer term reports on how it holds up.
Thu, 31 May 2012 02:57:35 +0000
2009 MP3 500
2009 MP3 500
Thu, 31 May 2012 02:57:35 +0000 quote
Yes body panel is being squeezed between spacer and nut just like original
bolt was doing made spacer same diam. as bolt head. will give updated report later as just started riding with them on monday.
Thu, 31 May 2012 13:39:05 +0000
'Sophia' - Demon Black MP3 500
Thu, 31 May 2012 13:39:05 +0000 quote
I am envious. Really phenomenal work. Inspiring, really. If I freed up the funds, I could see doing this as well. Thank you, from a less talented modder!
Thu, 31 May 2012 13:53:23 +0000
'09 Mp3-500 - Gone Now
Thu, 31 May 2012 13:53:23 +0000 quote
Nice, very, very nice! Well done effort and pictorial! How is the ride with the extra wind resistance now?
Thu, 31 May 2012 13:54:02 +0000
Red MP3 500 RUBY DRAGON
Thu, 31 May 2012 13:54:02 +0000 quote
Awesome.
Love how the supports are vertical and parallel. Very clean and tucked in as much as you can go.
Thu, 31 May 2012 14:15:21 +0000
2009 MP3 400
2009 MP3 400
Thu, 31 May 2012 14:15:21 +0000 quote
Nice work, Minimag123, thanks for sharing.
Where did you source that 1" collar, and how is the bracket bolted to it? Does the collar have some kind of tab on it?
Thu, 31 May 2012 14:31:37 +0000
Moderatus Rana
MP3 250 and 2 MP3 500s
Moderatus Rana
Thu, 31 May 2012 14:31:37 +0000 quote
I agree with Jeff. Great first post and very nice job on the install and the write up. Will come in handy if you come down to the gathering in September.
Thu, 31 May 2012 14:49:28 +0000
MP3 500, Lambretta GP TS1 225
Thu, 31 May 2012 14:49:28 +0000 quote
Really a nice job. If you ever want to make this a kit to sell, you should have no problems having a few buyers here.
Cheers,
Tross
Thu, 31 May 2012 17:54:46 +0000
Honda CTX 700D
Honda CTX 700D
Thu, 31 May 2012 17:54:46 +0000 quote
It would be great if there was a setup like that for the 400/250's. Has anyone seen one or done that?
Thu, 31 May 2012 19:12:54 +0000
Piaggio mp3 500
Piaggio mp3 500
Thu, 31 May 2012 19:12:54 +0000 quote
Do they interfere with putting bike on the stand?
Fri, 01 Jun 2012 00:18:28 +0000
2009 MP3 500
2009 MP3 500
Fri, 01 Jun 2012 00:18:28 +0000 quote
1. As far as wind resistance I haven't noticed them at all. Will see what effect they have on gas milage?
2. The 1" collars are availible from Fastenal, Grainger ,Mcmaster carr & Enco.
3. I drilled and tapped collars to 1/4-20. Used small piece of 1' X 1" angle iron drilled on one side for 1/4" bolt and other side 5/16" bolt then anle iron goes from collar to bracket.
4. It is alittle more difficult to put scoot on stand but mainly because top bracket connection is where I would normally grab side rails to do it.
Also boxes can be taken off or reinstalled very easily. After testing I will only use them when running around with wife on weekends or traveling.
Fri, 01 Jun 2012 00:35:56 +0000
2009 MP3 500
2009 MP3 500
Fri, 01 Jun 2012 00:35:56 +0000 quote
A better view of collar to bracket connection
Fri, 01 Jun 2012 01:04:43 +0000
MP3 500 (2) MotoGuzzi California 1400
Fri, 01 Jun 2012 01:04:43 +0000 quote
I like your work, as it looks factory. One side note I haven't seen brought up is, this looks like it would do pretty well in a slow/no speed tip over to help protect the tupperware.
I wish there was more protection available for the scooter in the event that gravity takes over, and perhaps an exoskeleton of tubing and spacers may be feasible afterall.
Congrats on such a remarkable entry into the group. I only had jokes..
Steve
Fri, 01 Jun 2012 05:42:00 +0000
Fri, 01 Jun 2012 05:42:00 +0000 quote
Recommend replacing that nut with a nylock nut.
Fri, 01 Jun 2012 06:50:20 +0000
MP3 500
MP3 500
Fri, 01 Jun 2012 06:50:20 +0000 quote
thanks for posting this MOD, look forward to how it holds up after a few months of hard riding.
And gas mileage you had before and after the cases were added.
FM
Fri, 01 Jun 2012 12:31:48 +0000
2009 MP3 500
2009 MP3 500
Fri, 01 Jun 2012 12:31:48 +0000 quote
Wasn't enough room for nylock nut so used locktite to keep it tight but thanks for suggestion.
Fri, 01 Jun 2012 14:24:58 +0000
Fri, 01 Jun 2012 14:24:58 +0000 quote
There is enough room if you put the bolt up from the bottom and have the nylock on top. You can cap it off with an acorn nut for a smooth finish. Great job either way.
Sat, 02 Jun 2012 16:00:56 +0000
2009 MP3 500
2009 MP3 500
Sat, 02 Jun 2012 16:00:56 +0000 quote
mjm50cal.you are 100% right. had not thought about putting bolt up through. I may do that wife would like cup holders on both side about that location. Im working on pillion foot rest now like you made for yours thanks alot.
Sun, 03 Jun 2012 01:04:28 +0000
Piaggio mp3 500
Piaggio mp3 500
Sun, 03 Jun 2012 01:04:28 +0000 quote
Do they interfere with putting down the stand??
Sun, 03 Jun 2012 01:59:37 +0000
2009 MP3 500
2009 MP3 500
Sun, 03 Jun 2012 01:59:37 +0000 quote
Sun, 03 Jun 2012 18:41:37 +0000
Piaggio mp3 500
Piaggio mp3 500
Sun, 03 Jun 2012 18:41:37 +0000 quote
I instaled Firstgear Silver stream? bags to my 500 and I have to use put mine up pullingfro the rear!!
Sun, 03 Jun 2012 23:50:09 +0000
MP3 500 08
MP3 500 08
Sun, 03 Jun 2012 23:50:09 +0000 quote
My small cases will drop about 5 mpg, but low speeds I cannot vouche for. Would guess below 40 mph they are not as bad ? Gratz on the nice mod !
Mon, 04 Jun 2012 05:15:35 +0000
MP3 500
MP3 500
Mon, 04 Jun 2012 05:15:35 +0000 quote
Can you take a trip up to 100 miles with them on riding highways and see what your gas mileage is?
thx
Mon, 04 Jun 2012 17:13:52 +0000
MP3 500
MP3 500
Mon, 04 Jun 2012 17:13:52 +0000 quote
Very well done. Though I whiteline enough here in CA that side
cases like yours would put a end to that. I don't know if that's legal in PA.
Keep up the good work.
Tue, 05 Jun 2012 00:36:36 +0000
2009 MP3 500
2009 MP3 500
Tue, 05 Jun 2012 00:36:36 +0000 quote
thx
Will be taking a trip in July and I'll Pm you with results.
Wed, 06 Jun 2012 01:30:55 +0000
2009 MP3 500
2009 MP3 500
Wed, 06 Jun 2012 01:30:55 +0000 quote
First full tank of gas with side cases. A mix of driving back and forth to work, two up riding with wife with a mix of in town & highway. Speeds ranging between 25-60mph but vast majority between 45-55mph. Before cases was getting between 52-55mpg most being close to 55mpg. with cases I got 53mpg I know you cant tell from first tank but looking promising! Just finished second tank 6-9-2012 same driving conditions but all of tank two up riding with wife 53.3mpg.
6-11-2012 finished third tank with about 2/3rds of tank in 55-70 mph range all two up riding at 56mpg. so far not noticing any drawback to cases at all.6-17-2012 Final tank of fuel for testing 54.8 mpg will now only use cases when with wife or traveling.
⬆️    About 31w elapsed between posts    ⬇️
Sat, 12 Jan 2013 09:34:53 +0000
2008 Piaggio MP3 500ie
Sat, 12 Jan 2013 09:34:53 +0000 quote
Over half a year now. How are those mounts working?
Sat, 12 Jan 2013 14:11:58 +0000
Sat, 12 Jan 2013 14:11:58 +0000 quote
nice job, The side bag mounts look great.
how did I miss this when it first got posted ?
Sat, 12 Jan 2013 15:37:21 +0000
MP3 500 - GTV250
MP3 500 - GTV250
Sat, 12 Jan 2013 15:37:21 +0000 quote
Minimag123 kinda slid in here, had his say, and hasn't been heard from since last August. I thought this was quite an addition to MP3 styling and mods.
Sat, 12 Jan 2013 17:33:47 +0000
MP3 400 / BV250
MP3 400 / BV250
Tue, 15 Jan 2013 02:52:06 +0000
2009 MP3 500
2009 MP3 500
Tue, 15 Jan 2013 02:52:06 +0000 quote
I still visit now and then sorry I havent posted for some. After half a years riding they have been by far the best mod. I have done to scoot wife loves them. they havent had any real effect on my gas milage but i dont do much highway riding. You can carry quite a load with them. I have done more mods to scoot borrowing a few ideas from the sight right now just looking for any chance to ride during winter months.
Thu, 17 Jan 2013 22:55:51 +0000
Fuoco 500ie - 2007, Benelli Adiva 150 - 2003
Thu, 17 Jan 2013 22:55:51 +0000 quote
Nice Job!
I wonder if these marine grade pipe clamps might work well for a job like this? And look very nice in polished stainless steel too!
25mm Sliding Clamp Over with Fork
To take End with Eye except the HD
Made to clamp around without the need to slide-on.
Polished 316 Stainless Tube Fitting
(Reference #4697810)
https://www.seascrew.com/browse.cfm?25MM-STAINLESS-TUBE-FITTINGS--MARINE-GRADE&l=0000000175
⬆️    About 34w elapsed between posts    ⬇️
Tue, 10 Sep 2013 01:41:18 +0000
MP3 500
MP3 500
Tue, 10 Sep 2013 01:41:18 +0000 quote
so is this all there is of the saddlebag bracket mounts?
I got some nice large saddlebags, which I need to fabricate some brackets. But some of these links have died.
How did that gas mileage work over time with the saddlebags?
FM
⬆️    About 8y elapsed between posts    ⬇️
Wed, 15 Sep 2021 20:24:01 +0000
Florida Man
MP3 500 HPE Sport Advanced
Florida Man
Wed, 15 Sep 2021 20:24:01 +0000 quote
Me too !!!
What a great project and Awesome pictures WITHOUT "Photobucket" watermarks !!!
[ Time: 0.0446s ][ Queries: 6 (0.0193s) ][ Debug on ][ 276 ][ Thing Two ]
