Loading the bad boy up from Motoretta,not really digging the decal kit so its going to come off
Spoiler Alert Updated Mods Listed Below
Vespa OEM Mods:
Vespa OEM S rear rack/handrail
Vespa OEM S top Case
Vespa OEM black Top Case seat backing
Vespa OEM S Crash Bars
Vespa OEM Tinted Flyscreen
Vespa OEM 2013+ Rubber Center Floorboard mat ("Vespa"Script)
Malossi +Engine/Transmission Mods:
Malossi 78.8cc Cylinder kit (Main Jet:80 ,Idle Jet:38 )
Malossi Power cam
Malossi Intake
Malossi Digitronic Variable Advance Digital Electronic Controller (CDI)
Malossi Multivar Variator kit (Green Contra Spring +60% rigidity,6.1g weights)
Malossi Delta Clutch+Bell MHR. (White Sport clutch springs)
Malossi Torsion Controller Spring Slider 50cc
Malossi Torque Driver
Malossi "Special"Belt
Malossi Secondary Gears
Malossi Pinwheel Shaft
Malossi "Whoop" Disc Brake
Malossi MHR Red Brake Pads
Malossi "Power" Rear Brake Shoe
Malossi RS24 Front Shock
Malossi RS24 Rear Shock
Malossi tire valve stem caps
K&N Cylinder Breather port Filter
Miscellaneous Parts&Accessories:
AF1 Racing Super Magnetic Oil Filter Drain Bolt
Bell Recon Helmet
Buzzetti Passenger Foot Pegs
Bontrager Bottle Cage Cup Holder
Cheeky Seats custom Leather seat cover and top case backing
Dimple Magnetic Gear Oil Drain Bolt
DIY front reflector removal plugs
EBC Anti Squeal Brake Shims
Givi 3/4 windscreen
Koso Mini Tachometer
LSL bar end mirror
LSL bar end mount
PM Tuning Sport Brake Lever Set
RAM X-Phone Mount
Scooterwest foot peg decorative fasteners
Shinko SR-723 Whitewall Tires
SIP S Headlight Bezel
SIP S mirror hole plug
Superbrightleds.com Gauge Cluster Amber LEDs
SBLEDs F.Runners, Rear Turn signals, Tail lights
Super Spots High Performance Xenon Boost Headlamp Bulb
Yoshimura TRC Exhaust
Zelioni Handle bar grips
Zelioni Fuel Cap
Zelioni Oil Filler Plug
Zelioni Bag Hook
Taking a pic after getting it oiled and fueled up in Macon
Last edited by colemillerkills on Tue, 19 Oct 2021 02:15:51 +0000; edited 75 times
