Thu, 27 Oct 2011 17:21:58 +0000
Moderatus Rana
MP3 250 and 2 MP3 500s
Moderatus Rana
Thu, 27 Oct 2011 17:21:58 +0000 quote
Yep looks like my 500 has the same issue. Didn't feel any abrading but there is a slight dent in the hose. The bike has just over 4000 miles. Will be taking care of this tonight. Thanks for the heads up Rob to check this invisible sticky thread.
Mon, 31 Oct 2011 03:37:28 +0000
Mp3 500
Mp3 500
Mon, 31 Oct 2011 03:37:28 +0000 quote
mine still has the washer I stuck between the hise and the fan 18000 miles ago. Truly a simple fix.
Mon, 31 Oct 2011 13:00:18 +0000
Moderatus Rana
Moderatus Rana
Mon, 31 Oct 2011 13:00:18 +0000 quote
I used a couple of tie wraps to pull the hose a little more than 1/4 in away from the fan housing. At least that is my temp fix until I can get more time to mess with it. Oh and there was abrading going on. The thin sleeve was worn through and a slight rub on the hose itself. Couldn't see it before.
Wed, 23 Nov 2011 16:29:26 +0000
MP3 500 - Yamaha Vino
Wed, 23 Nov 2011 16:29:26 +0000 quote
Even with only 400 miles on my 500
I made the repair and with under 500 miles on my MP3 - I could already see signs that I would soon be riding an air cooled MP3... Happy Thanksgiving.
Regards,
Glenn Barnett
convertassets@gmail.com
www.convertassets.com/wanted.aspx
(713) CELL 416- HOUSTON 4660
Tue, 24 Jan 2012 21:04:47 +0000
MP3 500
MP3 500
Tue, 24 Jan 2012 21:04:47 +0000 quote
Radiator Hose
Just checked mine and sure enough ... just has been said ... my 2008 with 9000 miles has the problem described. Now I'll have to decide whether just a fix or a replace and fix is required. THANKS SO MUCH for you guys and this forum. I'll definitely continue to lurk and learn!!!!!!!
Wed, 25 Jan 2012 00:24:08 +0000
Wed, 25 Jan 2012 00:24:08 +0000 quote
Just 'a fix' is fine.
Wed, 01 Feb 2012 20:16:15 +0000
MP3 500
MP3 500
Wed, 01 Feb 2012 20:16:15 +0000 quote
I used the Rob in Denver fix (large washer) and seems to be working well. Thanks!!!!
⬆️    About 17w elapsed between posts    ⬇️
Mon, 28 May 2012 22:01:41 +0000
09' MP3 500
09' MP3 500
Mon, 28 May 2012 22:01:41 +0000 quote
done
two zip ties to pull 'er away from the offending/abrading piece
and reinforced the hose with some heavy rubber hose I had on hand
from a kayak cart project...
⬆️    About 27w elapsed between posts    ⬇️
Sat, 01 Dec 2012 03:48:48 +0000
Sat, 01 Dec 2012 03:48:48 +0000 quote
Radiator hose fix
Well I appreciate the info on the radiator hose fix but unfortunately it wore half way through on mine at 7000 miles. $200 to get it replaced. Mostly man hours but I ride 110 miles and I can't afford a blown hose. My dealer was clueless on this and never inspected for it, now they do. Piaggio sucks in providing technical service bulletins.
Sat, 01 Dec 2012 12:20:24 +0000
Sat, 01 Dec 2012 12:20:24 +0000 quote
Re: Radiator hose fix
Tech bulletin was sent out on this issue. If your dealer didn't read it, that's not Piaggio's fault.
Sat, 01 Dec 2012 14:57:13 +0000
Sat, 01 Dec 2012 14:57:13 +0000 quote
Well I guess that narrows it down. My Dealership Mechanics don't know how to read or get the Tech Bulletins. LOL! I got to fix it because it bugs the crap out of me being worn half way through.
Does any one have the Technical service bulletin or kow where to get it. I wrote Piaggio a email on this. Anyway thanks for the pics and info guys, peace out and safe riding.
Sat, 01 Dec 2012 19:53:48 +0000
Sat, 01 Dec 2012 19:53:48 +0000 quote
ead the thread from the first page you can see the various fixes folks have done.
⬆️    About 7w elapsed between posts    ⬇️
Tue, 22 Jan 2013 17:44:11 +0000
mp3 lt 400
mp3 lt 400
Tue, 22 Jan 2013 17:44:11 +0000 quote
happy birthday rob
friendship has no boundary, she no language . rob, you are a perfect example for me.
thank you for being my best friend, young man.
loulou =)
Mon, 25 Feb 2013 01:34:18 +0000
Mp3 500
Mp3 500
Mon, 25 Feb 2013 01:34:18 +0000 quote
This is how my hose was. I used 2 zip-ties to hold it back and black Sugru to repair the damage.
Before repair
After, Sugru applied
Fri, 30 Aug 2013 09:46:48 +0000
2009 piaggio mp3 500 2013 Kawasaki Versys
Fri, 30 Aug 2013 09:46:48 +0000 quote
About a quarter of an inch away
I checked mine last night and saw that it wasn't touching at all, while the wheels are locked... will take photos to post later. Thanks for the warning post.
⬆️    About 14w elapsed between posts    ⬇️
Mon, 09 Dec 2013 00:34:08 +0000
2010 Piaggio MP3 500
Mon, 09 Dec 2013 00:34:08 +0000 quote
Still a problem on 2010 models
Just picked up a used (barely: 250 miles) 2010 and after reading this forum thread (while looking for information on a more serious problem ) I checked and found the hose had a shrink wrap sleeve (not very substantial) but was definitely making contact with the fan housing. Some marking, but no indentation that I could feel.
Zip-ties to the rescue.
By the way, for those having trouble getting the zip-ties around the frame: Bend the tie almost into a loop, then thread it under the hose, up behind it, over the frame tube and out. Quite easy if you get the right curve on the zip-tie.
Tue, 17 Dec 2013 14:46:27 +0000
MP3 500
MP3 500
Tue, 17 Dec 2013 14:46:27 +0000 quote
Rob in Denver washer fix
Rob, would you post a pic of exactly where you place the washer. In one of your posts, you stated "between the tire......."
Fri, 20 Dec 2013 12:44:05 +0000
MP3 500
MP3 500
Fri, 20 Dec 2013 12:44:05 +0000 quote
my '09 MP3 500 has the shrink wrap protection and someone had zip-tied around the frame and both hoses with a zip-tie with a sleeve around it, but had not tightened it enough and the tie had slipped down. This scoot has only 79 miles on it and there was already a wear mark in the protective sleeve. Tightened it up and will monitor
Thu, 26 Dec 2013 04:02:20 +0000
'09 Red MP3 500
'09 Red MP3 500
Thu, 26 Dec 2013 04:02:20 +0000 quote
My 09 500 has significant space between the fan and the hose. I will however place a zip-tie around the hose as a precautionary measure.
Mon, 24 Feb 2014 10:20:56 +0000
MP3 500 LT Sport
MP3 500 LT Sport
Mon, 24 Feb 2014 10:20:56 +0000 quote
European MP3 500?
hey all,
I'm in the UK with an MP3 500 (the European spec, not the US Fuoco-esque version) and I checked to see if I had this problem.
But the fan housing on my bike is considerably different to the photos (see my photo).
Can anyone say whether the hose rubbing is an issue on the Euro spec version anyway? If it is, then I guess I'm going to have to dismantle the fan housing to enable the OP's fix, but any input before I do this would be happly received!
Mon, 24 Feb 2014 16:11:13 +0000
Mon, 24 Feb 2014 16:11:13 +0000 quote
This is just a Fuoco issue.
Mon, 24 Feb 2014 17:05:00 +0000
MP3 500 LT Sport
MP3 500 LT Sport
Mon, 24 Feb 2014 17:05:00 +0000 quote
thanks Jim
Mon, 24 Feb 2014 18:33:44 +0000
Mon, 24 Feb 2014 18:33:44 +0000 quote
pbw wrote:
thanks Jim
please size your pics so they fit on the thread and we don't have to scroll side to side and up and down to get what your showing.
Mon, 24 Feb 2014 18:45:59 +0000
Moderatus Rana
Moderatus Rana
Mon, 24 Feb 2014 18:45:59 +0000 quote
old as dirt wrote:
pbw wrote:
thanks Jim
Yeah that is a good note. Linked pictures like yours are not re-sized automatically like pictures uploaded directly to MV. 800X600 pix is a good max size to shoot for. Just for future reference.
Welcome to MV.
Mon, 24 Feb 2014 18:47:47 +0000
MP3 500 LT Sport
MP3 500 LT Sport
Mon, 24 Feb 2014 18:47:47 +0000 quote
apologies folks... resized accordingly...
Mon, 24 Feb 2014 18:52:48 +0000
Mon, 24 Feb 2014 18:52:48 +0000 quote
looks great , thanks
Sat, 29 Mar 2014 21:05:27 +0000
Sat, 29 Mar 2014 21:05:27 +0000 quote
Another big thanks
Bought a new-old-stock MP3 500 last weekend, and just checked for this issue. Sure enough, coolant hose dented by fan housing. Seems either factory or dealer had attempted repair with hose-wrapped zip tie, but unfortunately was not tight enough. Simples.
Props to the forum, and all who contribute.
Tue, 22 Apr 2014 20:14:43 +0000
Piaggio mp3 300lt
Piaggio mp3 300lt
Tue, 22 Apr 2014 20:14:43 +0000 quote
Piaggio 300LT MP3 fan
Hi Guy, I have the 300LT with the foot brake (European version)
I don't seam to have the problem as the fan is encased in the front coachwork. I have also posted the workshop manuals picture[img][/img]
hopes this helps the 300cc European guys.
Mon, 19 May 2014 18:38:09 +0000
MP3 500ie
MP3 500ie
Mon, 19 May 2014 18:38:09 +0000 quote
Thank you for the special check note on this forum
Greetings!
Wow! This pipe issued I founded in forum is awesome! Yes now I have 1000 on OD mater and yes there is dimple on the pipe sleeve.
I went to The Home Depot and got Gray Flex Tubing 1'x5ft(-40-276f) $2.98 + Tax and Military Spec 8" Zip tie $6.47 (100pk) + Tax
I covered both cooling pipe left and right since pipe were touching sharpy edge plastic flange so now look sleek and clean.
Thanks again you all are superve! Cheers!
The left side pipe. Cover all the way since the cooling pipe was touching sharpy plastic flange.
Since Flex Tubing has ditch, easy to bite by Zip tie. And importantly now there is adequate space between the motor body and the cooling pipe.
The right side cooling pipe before attach the Zip tight on the left side cooling pipe.
Sat, 22 Aug 2015 00:37:37 +0000
New 300 GTS
New 300 GTS
Sat, 22 Aug 2015 00:37:37 +0000 quote
I am assuming this has been fixed on the 2016 model. Anyone checked. I am about to purchase an MP-3
⬆️    About 15w elapsed between posts    ⬇️
Sat, 05 Dec 2015 07:17:16 +0000
2016 Piaggio MP3 500ie Sport
Sat, 05 Dec 2015 07:17:16 +0000 quote
Great info in this thread, thank you for sharing it.
Sun, 06 Dec 2015 04:34:20 +0000
bv350 (sold) and now,'14 honda ctx700 dct
Sun, 06 Dec 2015 04:34:20 +0000 quote
howdy, i'm gonna get in this with a suggestion that the same problem exists with the bv500. I had the same wear and clearance issue with mine and solved it with the added protector like shown in several of those pics.
ken
⬆️    About 26w elapsed between posts    ⬇️
Tue, 07 Jun 2016 21:59:21 +0000
Piaggio MP3 500 LT Sport ABS
Tue, 07 Jun 2016 21:59:21 +0000 quote
Thanks for this thread. I get my 2016 MP3 very soon and I will try to check for this once I have it.
Tue, 19 Sep 2017 01:35:44 +0000
MP3 500ie, 500hpe
MP3 500ie, 500hpe
Tue, 19 Sep 2017 01:35:44 +0000 quote
ok, but look at the bottom of that tunnel too. Both hoses make a sharp turn to go around the tank and frame in the trip back to the engine.
Mon, 29 Jun 2020 16:08:17 +0000
Mon, 29 Jun 2020 16:08:17 +0000 quote
Hi guys.i m new on the website,I have a Piaggio MP3 500 from 2018 and i would like to ask what can i do to reduce the rpm versus speed.i mean if I'm driving with 140 km/h i have 7000 rpm.i would like to reduce the rpm.it s possible to do it??!!
Mon, 29 Jun 2020 22:27:33 +0000
Mon, 29 Jun 2020 22:27:33 +0000 quote
gabby - please start your own topic - this one is an informational one about hoses that rub through to the point of failure (long since addressed by the factory).
[ Time: 0.1402s ][ Queries: 6 (0.1116s) ][ Debug on ][ 276 ][ Thing Two ]
