Tue, 01 Jan 2013 22:13:13 +0000
Vespa GTS 250ie
Vespa GTS 250ie
Tue, 01 Jan 2013 22:13:13 +0000 quote
Hey all,
I got the akrapovic exhaust for my Vespa gts250 and just after 5 min of riding with it the carbon fiber started to melt (see photo). And it started to move to the metal part as well. Has anyone experienced anything like this?
Tue, 01 Jan 2013 22:14:57 +0000
The Host with the Toast
Tue, 01 Jan 2013 22:14:57 +0000 quote
wow that must be one hot pipe, I guess any after market exhaust is prone to fail.
Tue, 01 Jan 2013 22:16:18 +0000
Tue, 01 Jan 2013 22:16:18 +0000 quote
Re: Akrapovic carbon fiber melting
nellycopta wrote:
Hey all,
that exhaust has been damaged. you can tell from the metal strap being ground away.
Tue, 01 Jan 2013 22:20:41 +0000
Vespa GTS 250ie
Vespa GTS 250ie
Tue, 01 Jan 2013 22:20:41 +0000 quote
I bought it brand new out the box and it had no damage at all.
Tue, 01 Jan 2013 22:26:03 +0000
Tue, 01 Jan 2013 22:26:03 +0000 quote
something has caused this scratching damage. Did you install it?
Do you have anything that was tied down near it like a bungee cord or something? Maybe a boot buckle rubbing against it?
Tue, 01 Jan 2013 22:28:37 +0000
Tue, 01 Jan 2013 22:28:37 +0000 quote
Do you have crash bars?
Tue, 01 Jan 2013 22:29:24 +0000
GTS 300ie
GTS 300ie
Tue, 01 Jan 2013 22:29:24 +0000 quote
when i first got my akra it kept banging against the vespa when going over bumpy ground at speed,until i upgraded to malossi shocks and its ok now.
Tue, 01 Jan 2013 23:00:26 +0000
Vespa GTS 250ie
Vespa GTS 250ie
Tue, 01 Jan 2013 23:00:26 +0000 quote
Yes I do have crash bars. Do you think they are banging agains the exhaust?
I did install them and there was nothing hanging hear the exsaust
Tue, 01 Jan 2013 23:38:19 +0000
Vespa GTS 250ie
Vespa GTS 250ie
Tue, 01 Jan 2013 23:38:19 +0000 quote
Yes I do. Do you think they are hitting against the exsaust?
Tue, 01 Jan 2013 23:40:25 +0000
Vespa GTS 250ie
Vespa GTS 250ie
Tue, 01 Jan 2013 23:40:25 +0000 quote
Yes, I installed it myself. Nothing was/is near the exhaust.
Tue, 01 Jan 2013 23:47:00 +0000
0:7 And counting
0:7 And counting
Tue, 01 Jan 2013 23:47:00 +0000 quote
That looks like crash bar damage to me as well. Definitely not melting.
Wed, 02 Jan 2013 00:01:54 +0000
Vespa GTS 250ie
Vespa GTS 250ie
Wed, 02 Jan 2013 00:01:54 +0000 quote
I see, what can I do to prevent this? Would Raising the back shocks help?
Wed, 02 Jan 2013 00:06:03 +0000
Wed, 02 Jan 2013 00:06:03 +0000 quote
While nothing may be close to the pipe as it sits on the stand the engine does swing quite a ways up as you are riding. If you take a look directly above where the abrasion is by about 6in you will find the cause.
After finding what's rubbing on it you can sort out how to stop it.
Wed, 02 Jan 2013 07:23:41 +0000
GTS 125 I.E.
GTS 125 I.E.
Wed, 02 Jan 2013 07:23:41 +0000 quote
+1 definatly NOT melting, i call crash bar damage to !
the manual and on the site of akrapovic it states that this exhaust can not be used with crash bars(!!!).
Wed, 02 Jan 2013 13:58:21 +0000
Vespa GTS 250ie
Vespa GTS 250ie
Wed, 02 Jan 2013 13:58:21 +0000 quote
Would raising the rear shocks help?
Wed, 02 Jan 2013 14:10:59 +0000
GTS 125 I.E.
GTS 125 I.E.
Wed, 02 Jan 2013 14:10:59 +0000 quote
That can help...
Or fitting some better/stronger aftermarket shocks because the stock ones are crap.
Wed, 02 Jan 2013 14:34:24 +0000
Vespa GTS 250ie
Vespa GTS 250ie
Wed, 02 Jan 2013 14:34:24 +0000 quote
That can help...
Awesome! I'll look into it. Any recommendation for replacement shocks?
Wed, 02 Jan 2013 14:37:22 +0000
Reprehensible Misinformant
Wed, 02 Jan 2013 14:37:22 +0000 quote
nellycopta wrote:
That can help...
Some urethane upper shock bushings mounted on the OEM shocks stopped mine from bottoming out. They also crisped-up the handling a bit.
That and I maxed out the pre-load adjustment.
All good now.
Wed, 02 Jan 2013 15:40:47 +0000
Wed, 02 Jan 2013 15:40:47 +0000 quote
I have Mallossi shocks with Jettin bushings along with crash bars and an Akrapovic exhaust and haven't experienced this, even while riding 2 up. Are you sure you've got your exhaust mount spacers in the correct position? seems like there was a thread sometime ago about someone installing an Akrapovic and having their spacers in the wrong place?
Wed, 02 Jan 2013 15:49:53 +0000
Wed, 02 Jan 2013 15:49:53 +0000 quote
gogogordy
Could you elaborate on the "urethane upper shock bushing", ie what ones etc.
Wed, 02 Jan 2013 15:59:07 +0000
Vespa GTS 250ie
Vespa GTS 250ie
Wed, 02 Jan 2013 15:59:07 +0000 quote
I followed the instructions as they sent. Big spacer in the back and small towards the front.
Wed, 02 Jan 2013 16:30:44 +0000
Wed, 02 Jan 2013 16:30:44 +0000 quote
Sounds as if you've installed it properly. After inspecting mine, I have a hard tome seeing that the crash bars would actually come in contact with the end of the exhaust can. I made this observation by sighting the 2. It looks close, but should be adequate room unless there were some sort of side to side motion. How many miles on your scoot?
Wed, 02 Jan 2013 16:43:21 +0000
Vespa GTS 250ie
Vespa GTS 250ie
Wed, 02 Jan 2013 16:43:21 +0000 quote
I have 7400 on it. It s a 07. My crash bars are diff. They might be original which has a bolt right above the exhaust about 6-8 inches.
Wed, 02 Jan 2013 17:03:19 +0000
Wed, 02 Jan 2013 17:03:19 +0000 quote
post some pics of a little father away so folks can get the whole pic to see whats different in yours
Wed, 02 Jan 2013 17:09:45 +0000
Wed, 02 Jan 2013 17:09:45 +0000 quote
That's your culprit then. Modify it.
Wed, 02 Jan 2013 17:21:53 +0000
Wed, 02 Jan 2013 17:21:53 +0000 quote
I looked on McMaster-Carr trying to find a flush headed bolt to give you clearance but could only find a stainless carriage bolt that might work (page 3020). I've seen bolts with an almost flush head but I'm not certain what they're called? A sex bolt may also work if your bolt is only securing a slip joint? These generally are made of aluminum or brass and have flush heads and may be a better alternative for the exhaust side of your bike. Go to www.mcmaster.com and type sex bolt in search.
Wed, 02 Jan 2013 17:29:08 +0000
Grievance Farmer
Grievance Farmer
Wed, 02 Jan 2013 17:29:08 +0000 quote
McMaster is a fantastic resource. But when I'm stuck and unsure about what I want or need I head out to a Fastenal store. They're everywhere these days.
http://www.fastenal.com/web/locations.ex
Wed, 02 Jan 2013 17:42:35 +0000
Moderatrice Strega
Moderatrice Strega
Wed, 02 Jan 2013 17:42:35 +0000 quote
Willie B: You have the Vespa bars. Those don't conflict with anything at all, that I'm aware of. They stick out farther beyond the body than other bars in that same area. I have the same ones. Love 'em.
Nelly likely has the Piaggio bars. Those have been noted to conflict with a few things, including some aftermarket exhausts. Tweaking/replacing the shocks and/or sometimes modifying the bar mounts usually solves the issue.
Wed, 02 Jan 2013 20:04:15 +0000
Vespa GTS 250ie
Vespa GTS 250ie
Wed, 02 Jan 2013 20:04:15 +0000 quote
So, I think that the shocks might need replacing because they are at the highest setting already. And I changes the placement if the screw. Take a look at the photos. I'll see what happens today and will report back.
Wed, 02 Jan 2013 20:05:08 +0000
Vespa GTS 250ie
Vespa GTS 250ie
Wed, 02 Jan 2013 20:05:08 +0000 quote
Thank you all for your help!
Wed, 02 Jan 2013 20:20:19 +0000
Moderatrice Strega
Moderatrice Strega
Wed, 02 Jan 2013 20:20:19 +0000 quote
Ouch... yeah, definately the mounting for the bars bottoming out on the exhaust. That's a bummer. It's not my style at all, but that's a totally cool exhaust.
Another possible solution would be to switch to the Vespa branded bars. There's no mounting bracket anywhere near anything that would conflict with the exhaust. They bolt on under the floorboard, and under the seat. It would be a less invasive fix, anyway. Might require just as many curse words.
Wed, 02 Jan 2013 20:20:27 +0000
Wed, 02 Jan 2013 20:20:27 +0000 quote
You've obviously got a differing set of crash bars. The affixing bolt is in a horrible spot considering the action of the rear suspension and exhaust location. My stock shocks were junk and I replaced them with Mallossis. Try having someone sit on the bike and bounce the rear up and down to see how close the crash bars are coming to the exhaust. Replacement shocks might help, but not sure they're going to completely alleviate your problem considering a pot hole or something that upsets the rear suspension. You may consider selling your crash bars and picking up a set of the Vespa ones. That sucks!
Wed, 02 Jan 2013 21:05:12 +0000
Wed, 02 Jan 2013 21:05:12 +0000 quote
First you have way too much shock travel. replace the shocks with a decent set, I like the Bitubos they have a great preload adjustment and they also have a rebound adjustment. Also consider the Malosi, alot of folks like them as well.
Next I would try and come up with a different spot for that pesky bolt some how. Like bend the bracket and fab some kind of connector plate that allows the bolt to be above the crash bar like a U upside down. Something.
[ Time: 0.0535s ][ Queries: 6 (0.0177s) ][ Debug on ][ 276 ][ Thing Two ]
