Wed, 24 Sep 2014 07:55:53 +0000
Wed, 24 Sep 2014 07:55:53 +0000 quote
Spotted on the modern side, but he's also got a nice old Super and that new Sharpie so hopefully that'll soon get some tire love as well.
Syntagma wrote:
The white lettering idea I got from the folks on the NSM side. I was a bit nervous doing it on a modern but the white lettering really helps offset the black on black rims/tires.
Just grab a white, medium point, oil based Sharpie. It was really simple - with the tire off; I just took my time and carefully followed the raised (in)sides of the lettering. When the tire was back on the bike I only had to do a touch up as I rubbed some of the lettering off while installing the tire.
I looked around locally at some supply stores and there were none in stock so I just ended up ordering from here.
http://www.amazon.com/Sharpie-Paint-Marker-Medium-SN35558/dp/B001PLKRZQ/ref=sr_1_2?ie=UTF8&qid=1411522629&sr=8-2&keywords=oil+based+sharpie+white+medium
Wed, 24 Sep 2014 08:42:46 +0000
Wed, 24 Sep 2014 08:42:46 +0000 quote
Custom cable bend
scootermarc69 wrote:
I just went to the hardware store and bought a foot of 1/4" copper tubing and coupler, bent it around a screwdriver handle for the 90 turn, cut off with a tubing cutter. Coupler makes a nice stop for the cable housing. I drilled out the threads on the slide cover and loc tited the bend in place
V oodoo wrote:
Nice one Marc.
I did the same thing to make a 180° bend for the PHBL25 in this 1974 Primavera...
Sat, 27 Sep 2014 14:08:26 +0000
Sat, 27 Sep 2014 14:08:26 +0000 quote
Oil dispenser
If you have auto lube, you know how tricky it can be to top up the reservoir without overfilling it.
No more fumbling around with funnels. One-way squirt valve allows precise dispensing and eliminates drips. Holds 1 qt. of your favorite nectar, clear bottle lets you see how much you have left.
Sat, 27 Sep 2014 14:29:03 +0000
Sat, 27 Sep 2014 14:29:03 +0000 quote
Socalguy you magnificent bastard
Sat, 27 Sep 2014 15:00:19 +0000
2005 PX150 In a Part-time Relationship with a 2-Stroke Vespa Since 2007
Sat, 27 Sep 2014 15:00:19 +0000 quote
You must not be using Motul. The bottles have a fill spout that pulls up out of the bottle.
But the ketchup bottle is still brilliant.
Sat, 27 Sep 2014 16:32:09 +0000
Sat, 27 Sep 2014 16:32:09 +0000 quote
Thanks jim. We're Royal Purple fans. We buy it by the gallon.
Back at ya jackson.
Mon, 13 Oct 2014 17:41:58 +0000
Mon, 13 Oct 2014 17:41:58 +0000 quote
split the motor in the scoot
(SoCal, the ketchup bottle w/ valve - that's sweet!)
I've seen this being done, but never done it. Now when I wanna try, I know where to find a nice list of what to do.
Thanks, Gary.
GLscoot wrote:
You can still split the casings with a side stand and the engine still in the scooter, if you are changing the gear cogs or cruciform.
leave scooter in 4th gear
drain engine oil
remove exhaust
remove cylinder & flywheel cover
remove flywheel & stator (mark position of stator) & woodruff key
remove both near side cylinder studs
wiggle barrel up about 20mm
remove gear selector unit, with cables attached, must be in 4th gear
loosen all M7 nuts, don't forget the one thats underneath the oil drain bolt
using the kickstart remove the flywheel side casing, no doubt the kickstart spring & cog will fall out
you will also need to loosen the carb bolts
it can be tricky but can be done & I always do it when I have to change my cruciform.
remember to keep the cogs in the correct order, i use a plastic cable tie for this.
I would replace the engine gasket and cruciform, unless your cruciform is only a few miles old and buy the best one.
If I have forgotten anything please feel free to add.
Gary
Tue, 14 Oct 2014 11:39:16 +0000
Vespa GS150, Messerschmitt GS150
Tue, 14 Oct 2014 11:39:16 +0000 quote
Engine oil, fill with a 50ml syringe X 5
Tightening clutch cable, similar idea can be used on front drum brake.
IMG_3634 by GLscoot, on Flickr
Tue, 21 Oct 2014 02:13:16 +0000
Tue, 21 Oct 2014 02:13:16 +0000 quote
Cushy garden mat (~$20) provides comfy alternative to lying/kneeling on hard concrete when working on scoot.
Courtesy of most thoughtful SoCalWife.
Note color match
Tue, 21 Oct 2014 03:00:45 +0000
Tue, 21 Oct 2014 03:00:45 +0000 quote
The closet my wife ever comes to being thoughtful towards me and scooters is not asking how much the latest round of parts cost.
Tue, 21 Oct 2014 04:32:50 +0000
Tue, 21 Oct 2014 04:32:50 +0000 quote
They cost "a lot less than I initially estimated"
Mon, 03 Nov 2014 18:03:03 +0000
'61 GS150Cushman '63 GS160, '74 Primavera, '77 Rally 200,'80 P200E '05 PX150,'13 946,'64 Vyatka VP150,'77 Vyatka-Elektron,'07 GTS250, '63Tula200M
Mon, 03 Nov 2014 18:03:03 +0000 quote
Re: SI Carb Air Mix Screw "EZ Adjust"
Vader19 wrote:
This is neither new nor revolutionary, However! it has come up many times in the past and I thought it a good tip for a new SI carb user!
So.. SI carb user... you'll quickly notice that the air mix screw in the back of the carb is in a rather tricky place to be adjusted. It's possible to get in there with a Micro ratchet wrench, but that's still not all that great...
So.. EASY tip, is to simply cut in a slot for a flathead screwdriver.... this way you can pull the plug from the back of the carb box (if you have one) or just go in through the hole with a long skinny flathead and Wha-la! Adjust until your mix is correct and your heart's content!
*this may not work with every version of SI carb (I'm not familiar with every year, make and model, but it's good for a heck of a lot of them)
I found a very simple way to get to the mixture screw: take the wrench in your left hand and reach to the screw from the rear wheel side.
Mon, 03 Nov 2014 22:41:35 +0000
1974 V90
1974 V90
Mon, 03 Nov 2014 22:41:35 +0000 quote
Great idea. I'm getting one tomorrow, the cardboard isn't doing it anymore. Not sure I can get one in Henna Red though.
Tue, 04 Nov 2014 18:10:47 +0000
Rally 200, SS 180, ET3
Tue, 04 Nov 2014 18:10:47 +0000 quote
How to lever off a stuck clutch using a large spanner...!
How to split stuck together cases without a mallet using the flywheel holder....!
Wed, 05 Nov 2014 15:55:22 +0000
Vespa PX125 Kitted 'n stuff. Lambretta GP150.
Wed, 05 Nov 2014 15:55:22 +0000 quote
After a mind-numbing coma-inducing 20 minutes trying to start my PX the other day I stumbled across this BRILLIANT tip.....
Put the fucking key in the ignition first.
No need to thank me folks - you can have that one for free
Wed, 05 Nov 2014 17:21:41 +0000
Wed, 05 Nov 2014 17:21:41 +0000 quote
^^^ Key was in, and I found after 10 or 20 kicks that the key must be in the ON position
Wed, 05 Nov 2014 19:09:23 +0000
vespa 125 vnb1t
vespa 125 vnb1t
Wed, 05 Nov 2014 19:09:23 +0000 quote
ah good it's not just me
i hope nobody was watching +
Sun, 09 Nov 2014 02:34:19 +0000
Sun, 09 Nov 2014 02:34:19 +0000 quote
I did this little description of my new bar ends and put it up in Project Reports - Bar end indicators - how I fitted mine
Sun, 09 Nov 2014 03:06:09 +0000
Sun, 09 Nov 2014 03:06:09 +0000 quote
I lost track of how many times I did this when I first started riding the Stella again after a few years of the VBB, where the key is just a steering lock.
Worst time was when I realized the key was off after a dozen attempts at bump starting it. Good exercise, though.
Sun, 09 Nov 2014 22:24:47 +0000
2 - Many
2 - Many
Sun, 09 Nov 2014 22:24:47 +0000 quote
Need to throw a few extra zip ties in the tool pouch!
GLscoot wrote:
chandlerman wrote:
I work with the motor in the bike less about the difficulty of getting it out and back in. It's more getting the clutch & rear brake cables set to my liking again.
easiest way to tighten clutch cable, can be done for rear brake as well.
Gary
Tue, 18 Nov 2014 13:53:17 +0000
Tue, 18 Nov 2014 13:53:17 +0000 quote
Paint Protector
Piece of clear vinyl tubing over cowl pin keeps it from scratching paint when removing and replacing cowl.
Tue, 18 Nov 2014 13:55:38 +0000
Tue, 18 Nov 2014 13:55:38 +0000 quote
I use a cutting from my fuel line.
Tue, 18 Nov 2014 14:48:00 +0000
Tue, 18 Nov 2014 14:48:00 +0000 quote
Another way to keep cables from fraying
Heat shrink tubing.
And no, don't use an open flame, use a heat gun or hair dryer.
Tue, 18 Nov 2014 21:20:53 +0000
Tue, 18 Nov 2014 21:20:53 +0000 quote
How to check if your points flywheel will work with
... electronic ignition. Thanks Mr10.
[/quote]
Fri, 21 Nov 2014 07:54:43 +0000
Fri, 21 Nov 2014 07:54:43 +0000 quote
One man's comparison of different kits
It's not really a tip or a trick but this is a handy place to keep it visible. I wanted to put this up as a bit of a resource, it makes very interesting reading. Thanks to Subetherbass for pointing it out. It's been translated from Italian. Some of the images were dead so don't appear here either. * 1st Place: QUATTRINI M1XL
the absolute best so far: turn at will, is made ​​of aluminum and has a capacity of 171, not 177 as the dr, Pinasco, PARMAKIT, and Polini, but it is the strongest, because in addition to be of aluminum has the very thin bands, the suction laminated directly to the cylinder and inside seems a colander for the quantity and the size of the transfer ports. this is his portmap: 2 * Rank: QUATTRINI M1X identical to the larger brother L, but does not have the suction cylinder, here is the portmap:
3 * Rank: Malossi 166 Bifascia (the single ring is nowhere to be found but would be better) the little brother I think compared all'm1x ... is pretty much the M1X the poor or who wants to be on a M1X but has only spent about EUR 160 ... shall have the same speed or a little bit less of the money, it can be corrected with less money, he also has thin straps, and a piston which is a work of art ... I think most of the money and also lighter ... but still does not compare with the M1X that is ahead of course The piston is 1mm bore in less dell'm1x, and are therefore less than 2 Polini and company to 177cc ...
4 * Place: PARMAKIT TSV (IS CAST ALUMINUM is ANOTHER THING AS THE PINASCO) and This is the place I wanted after the Malossi because in my opinion is nothing more than a copy of the Polini cast iron but have the same shape and the same piston transfer ports, except that here is a little more fragile (but lighter) the Polini and also has the very thin strips 1 3 above ... which makes it also very thirsty speed, it would be the best choice to make on ebay
is located at 235 Euros and it would be a successful union of economical performance and reliability if it were not for that damn piston, which everybody talks about bad .... according to someone besides the finish would not be at the top ... but I like anyway, and what I would like my vespa it would be the best (because you can mount the race without heating as the Polini 60) one of the photo is the version with the new liquid graphite piston, but there are also other versions Candle central and lateral run 60, and an unprecedented new version with forged piston even inootre all versions have various head and base gaskets, which are used to sew the cylinder to suit your needs without killing calculate squish and squosh and buy whiskers or company beautiful
5 * Place: Polini 177 (bands 2 mm - 177 cc) The best-selling, most popular, the most noble, the most bought, most famous, the most videato and framed, the dream also, the most seized ... it's him! the Polini 177, everybody talks about good and evil everyone is talking about, everyone says that it has less torque than a dr, but then everyone says that a couple from fear, everyone says that seizes easily, but then everyone says that is not properly adjusted Binds, all the changes as they believe best cutting "L" or not cutting them ... everyone says that senior fantastic, but fell five minutes before his Vespa 125 seized half of his father and then he feels a missile ... in short, is the most famous of all and the most sold ... but in the end it's just a cylinder, I would take it with my eyes closed but if I do it just because it is the same for 20 years, our beloved Polini did and since that day there has never put his hand ... he left them all and continue to buy seize it, and buy it back, sell it used, rectify enlarge it ... well .. buy it all just to not have concussions and go on the safe side, maybe because they are afraid to experiment with some nice malossi or some nice PARMAKIT ... but it would be too risky, better a nice Polini is known and go! portmap here is different, each one different, as amended respectively by: typaco (a Kraut I think) and worb, the third I think is originally published these various portmap are just to show everyone that he does what he wants and makes it come out beautiful things, there's a video on youtube of a MP that if PRTA on the track and it runs great, certainly after he took a M1X and found himself better, but even with 177 polinone not joking
6 * place: Pinasco 177 Aluminum: (ranges from 2mm 177cc) attention, I speak of the aluminum version, for those who should read, there is also cast iron but it is another world ... The cylinder better reliability as a relatively cheap ... in the end with 190 200 takes home .... but almost all describe it as a original cylinder displacement increased with the only ... do not expect to wheelie acceleration taken and edited ... because it is not so ... even some people who go for it broadens the discharge of 3mm unthinkable for another cylinder listed above ... you rezlizzerebbe like a proto Rotax for small air hahaha (but not lower) the fact is that those who raised the discharge of 3 mm believes that gained even at low ... then this shows that the people 'designed ... he planned to sell to travelers and some old man who restores the wasp and wants to give it that extra sparkle ... and maybe we need to do some giterella not seize it ... also because I'm sure seizes not miss if you go without oil is so calm that is the portmap racking my original lml are wider (personal opinion: look at the picture above and you will see that the transfer frontescarico is narrow at the base and wide top is a ... something very wrong as fluid because it is said that if the mixture meets a larger space tend to lose pressure ... and this should not happen ... but Pinasco aluminum is so ... well ....) also that picture is the version 2 transfers to low ... one for has 3 px then decanted and a second side opposite the exhaust ... the photo is for guidance .... also this cylinder is the best to assemble in the race 60. .. just because of the other more relaxed and more reliable for long distance
7 * place: DR 177 - 177 OLYMPIA - PINASCO -PARMAKIT CAST IRON 177 177: ranges from 2 mm 177 cc THE MOST loved and sold by all after the Polini, all the best geeks love it, but no one takes it (always prefer the Polini) all the mechanics would recommend .... all have the fear of scratches in the barrel of the cylinder but is said to be the most reliable of all those cast iron .... everyone says it has a couple scary at low but then measure the squish and is 3 mm but why? everyone says it's a loose and if you work as a polini but goes even better ... and Polinizzano widening at the base as the Polini ... everyone says that scampanella because tolerance is wrong ... but then they light a money and scampanella a Polini and even that cold ... everyone says that the booster exhaust serve to increase the maximum power at high rpm ... but he always has the torque at low .... then who has a Polini and test says he did not do it low ... high and those with a lml says it's better the original cylinder of lml 150 (partly true because the lml has decanting larger base) but then talking to a mechanic and a friend who has tried told me that even on the lml is better than 150 original and pulled like a mule ... (and it has not changed the jets do not even removed from the filter pre-filter and white jersey he made ​​holes) as the Polini has many different opinions and no one knows her, those who have it say it is a splinter ... but thanks to the cax ... those who have it or assembled it to him that is a 16 year old father or Mechanical or is accustomed to a 150 pooped ... or is it a passionate reading various guides and after having optimized the melgar also has made ​​a Polini because maybe the recalculated I squish ... he basettato below and expanded the boosterini and exhaust ... basic things that are wanting to say it takes a while ... but it is actually worth if sti one if it makes them work alone and then you have the satisfaction of doing to try the wasp to friends and tell ... I only have a dr ... what do you want to be ... and make the road one-wheel acceleration in 1 ... * ------------ ------------------------------ I hope I have made ​​happy who has just bought a Vespa and reads this post, I also first I tried to know vesparesources opinions left and right, and there sleep at night ..... I tried to put in a post, that I have read and understood in a month of reading research, comments, graphics, video and photos. .. this post is not addressed to the members of the forum who know the cylinders one by one, but only to those who want to change the cylinder and do not know what to put or do not want to make a fool of by some clever mechanic that wants to give him such a dr telling him that is the same because it's always a polini 177 or malossi which is even better than the 166 ... just for that, I tried to be as impartial and objective as possible ... if you believe that the PARMAKIT aluminum and are the best of the Polini malossi is fine with me, I know that there is a difference in mount p & p and making all the work around ... but I think the ranking is just this ... maybe if you have the data in hand or you want to have your say we will not do that good to all readers who like me will follow you as passionate as I do every day ... I rilassandomi!
[img]http://gallery.amsterdamvespaclub.com/var/albums/members/roo/top%20ends/polini%20177/portmap%20typaco%20177%20b.jpg?m=1299681385[/img]
Fri, 21 Nov 2014 12:47:40 +0000
150 GLx, Rally 200
150 GLx, Rally 200
Fri, 21 Nov 2014 12:47:40 +0000 quote
The AmsterdamVespaClub one in the post above:
Fri, 21 Nov 2014 15:56:27 +0000
Fri, 21 Nov 2014 15:56:27 +0000 quote
Re: One man's comparison of different kits
Ginch wrote:
It's not really a tip or a trick but this is a handy place to keep it visible. I wanted to put this up as a bit of a resource, it makes very interesting reading....
Ow. My head hurts.... to recap, sounds like I need to be sure to boost the basetta and expand the boosterini, and remember to optimize the melgar, so I can rezlizzerebbe like a proto Rotax. Got it!
Fri, 21 Nov 2014 20:35:51 +0000
PX232 Lambretta li s3, Vespa cross, Vespa cross prototype, Honda NS400r....
Fri, 21 Nov 2014 20:35:51 +0000 quote
spare time
I made these at work during lunch break from leftover nylon parts. Bearing dummies. Easy to dry mount everything and check your port timings, transfers and etc...
Sara
the white ones are in 2 sizes, with bearing bush and without.
Fri, 21 Nov 2014 21:42:02 +0000
Fri, 21 Nov 2014 21:42:02 +0000 quote
Wow! Great idea Sara.
Sat, 22 Nov 2014 02:44:45 +0000
Mr. Clean
P,SUPER,V90, 50 Special
Mr. Clean
Sat, 22 Nov 2014 02:44:45 +0000 quote
Re: spare time
Sara
You're much handier that I.. I've got a full set from SIP and they are invaluable.. Nice work Sara.. you never cease to amaze.
Sat, 22 Nov 2014 08:35:04 +0000
Sat, 22 Nov 2014 08:35:04 +0000 quote
Forgot to make a second one for a sprint engine
Sara
Sat, 22 Nov 2014 16:22:47 +0000
Sat, 22 Nov 2014 16:22:47 +0000 quote
dummy bearings, etc. would be a perfect project for a 3D Printer.
Now I just need to figure out which of my friends has one...
Sat, 22 Nov 2014 19:05:13 +0000
Sat, 22 Nov 2014 19:05:13 +0000 quote
N°2 made.
Sun, 23 Nov 2014 03:00:30 +0000
SawStop
SawStop
Sun, 23 Nov 2014 03:00:30 +0000 quote
One of my favorite tools - comes in handy on so many occasions!
Sun, 23 Nov 2014 03:10:10 +0000
VNB VSC o9c VMA vbc vmb VSX
Sun, 23 Nov 2014 03:10:10 +0000 quote
Stoner. 8)
Sun, 23 Nov 2014 03:11:37 +0000
Sun, 23 Nov 2014 03:11:37 +0000 quote
I don't know if LML cases are different, but a metal, not plastic, 1 1/4" conduit "knock out" plug for electrical junction boxes will work to plug up the hole for the electric start if you remove the motor. Be careful though, because the hole is just slightly smaller than the plug and you have to use nuts on the studs to force the plug in. If you don't tighten the nuts evenly, you can bend the fingers of the plug. You also have to file small notches to fit the studs.
Sun, 23 Nov 2014 19:27:52 +0000
ET3
ET3
Sun, 23 Nov 2014 19:27:52 +0000 quote
I've found the Motion pro quick disconnect fuel coupler on a smallie indispensable when removing the fuel tank for maintenance/jetting swaps.
My fuel line is short so hanging the tank sideways puts too much strain on the hose. I'm using the 1/4" type straight connect but they do come with 1 or 2 way valves and 5/16" versions. No problems with fuel starvation when coupled with BGM fast flow tap. I'm not sure of any benefit with the lardys since the carb is way easier to access.
Sun, 23 Nov 2014 19:35:16 +0000
Sun, 23 Nov 2014 19:35:16 +0000 quote
Those are nice. I used them on my Stella build which is running a 221 Rally based motor and a Dellorto 28mm VHST Carb. The carb has to come off for main jet changes and it sure made tuning the bike less complicated. Mark @ Scooter-Speed turned me onto these.
Sun, 23 Nov 2014 21:12:43 +0000
Sun, 23 Nov 2014 21:12:43 +0000 quote
Looks like just the thing for my long range tank.
Sun, 23 Nov 2014 21:17:17 +0000
Sun, 23 Nov 2014 21:17:17 +0000 quote
Quick Disconnects
BGM has them too and only $12 at Jet200 vs $17.50 at Motion Pro.
From page 4 of this thread:
I have a quick coupling on the fuel line, much easyer to take out the tank. When apart they are closed, dual shut-off, so no fuel leaking down your sleeve Find them in motorcycle-stores. +/- 20EUR
Sara
sorry no pics
I use on all mine.. great for carb swapping, tuning etc.. I put 'em on the carb and on the fuel tank.
Jet200 sells them.
http://jet200.com/catalog/product_info.php?products_id=1854
[ Time: 0.0336s ][ Queries: 6 (0.0063s) ][ Debug on ][ 277 ][ Thing Two ]
