Sat, 30 May 2015 03:08:04 +0000
GTV 300 ABS
GTV 300 ABS
Sat, 30 May 2015 03:08:04 +0000 linkquote
I can not get a Samsung Note 2 to run the software or pair with my scooter.
The dealer is useless, I am very disappointed, has anyone used the application or been able to pair their phone?
Sat, 30 May 2015 10:10:24 +0000
Sei Giorni II
Sei Giorni II
Sat, 30 May 2015 10:10:24 +0000 linkquote
You do have the optional module installed on the scooter do you?
Just in case you thought it was standard.
Sat, 30 May 2015 14:06:24 +0000
GTV 300 ABS
GTV 300 ABS
Sat, 30 May 2015 14:06:24 +0000 linkquote
It comes installed standard on the GTV-300 ABS.
Sat, 30 May 2015 14:44:17 +0000
Rocket Man
GTS 300 ABS 'Drake', GTS 250 (sold), LX 150 and Delta IV rocket. ( Retired. Not my problem anymore)
Rocket Man
Sat, 30 May 2015 14:44:17 +0000 linkquote
That I haven't heard. Suggest you remove the left knee pad and see if the module is there. It's a 4" x 4" black box mounted immediately to the left of the ABS unit.
The pic shows what's under the knee pad prior to the PMP install. This is where you'd find the module. Note the ABS unit and the the white wiring loom end. The ABS mount is used for the module mount with wiring to this loom.
Also, make sure you download the PMP app, not the VMP. The Vespa VMP app is no longer factory supported for the GTS / GTV.
Sat, 30 May 2015 21:32:46 +0000
GTV 300 ABS
GTV 300 ABS
Sat, 30 May 2015 21:32:46 +0000 linkquote
This is a 2016 GTV-300 ABS, the bike some times broadcast but never will pair with the phone.
The app does not display properly on two of my Samsung Phones, Note 2 and galaxy S5, the entire bottom doesn't show. Also there is no support from the software developer. I downloaded it from the Google Play Store.
Sat, 30 May 2015 21:55:57 +0000
Rocket Man
Rocket Man
Sat, 30 May 2015 21:55:57 +0000 linkquote
What app are you using?
Sat, 30 May 2015 23:39:54 +0000
GTV 300 ABS
GTV 300 ABS
Sat, 30 May 2015 23:39:54 +0000 linkquote
Piaggio Multimedia Platform, PMP 2.0
I can't see the Exit on the bottom or top menu bar in the app
Sun, 31 May 2015 00:05:35 +0000
Rocket Man
Rocket Man
Sun, 31 May 2015 00:05:35 +0000 linkquote
Trying to follow your issue here. Not sure if your're asking about an app issue or a Bluetooth problem.
Just a guess, but I'd say the app is having an issue with your phone. I've seen this issue before with an Android.
The app is made by an independent contractor for Piaggio. Their application was designed for an Apple iPhone.
To save you some frustration, find someone with an iphone and download the PMP app. If it works that will solve your problem.
Your scoot is the first that I've heard of having the module as standard equipment. Interesting. Again, did you remove the left knee pad cover to determine if the module has been installed? I'd recommend doing that before going any further.
Sun, 31 May 2015 00:41:19 +0000
GTV 300 ABS
GTV 300 ABS
Sun, 31 May 2015 00:41:19 +0000 linkquote
When I scan for new devices on my phone sometimes I see it, when I try to connect through the PMP it never conects.
I am going to remove the knee pad tomorrow morning, and take a look.
I sent 2 notes to the PMP software developers with no response.
There are several complaints about the most recent update braking the app.
I think I can find an iPhone to test.
Thank you
Sun, 31 May 2015 00:55:19 +0000
Rocket Man
Rocket Man
Sun, 31 May 2015 00:55:19 +0000 linkquote
Understand. Trying to communicate with the app support group is next to impossible.
Most of us working with the PMP device have gone through quite the learning curve. I too was told by my dealer that the module came with my scoot, which it did not. Lots of confusion in regards to this with many dealers. Not their fault. Just a lack of info from Vespa.
Sun, 31 May 2015 16:19:31 +0000
GTV 300 ABS
GTV 300 ABS
Sun, 31 May 2015 16:19:31 +0000 linkquote
Surprise no module!
The dealer told me it comes standard so let's see if he make good on it.
Any idea roughly what the unit costs?
Sun, 31 May 2015 16:40:20 +0000
Rocket Man
Rocket Man
Sun, 31 May 2015 16:40:20 +0000 linkquote
Yup. No surprise.
The kit requires two parts. The mount with wiring adapter that's about $100. The module is about $200.
Most dealers have sold these to customers at cost, plus install thrown in for free. About a 20 minute job.
If dealer covers all costs, great. If not, suggest you watch my very amateur video on the PMP with review prior to purchase.
Sun, 31 May 2015 17:21:20 +0000
GTV 300 ABS
GTV 300 ABS
Sun, 31 May 2015 17:21:20 +0000 linkquote
Thank you again.
I found the other Bluetooth device to be my daughter's helmet set.
What's the odds of that happening. LOL
Fri, 05 Jun 2015 20:39:25 +0000
GTV 300 ABS
GTV 300 ABS
Fri, 05 Jun 2015 20:39:25 +0000 linkquote
Installing Bluetooth module
I am waiting for the parts to come in, any tips or tricks on installing the bracket, Harness and module.
I noticed in the video that the harness has 3 connectors, I see a round one, one to the module, but where does the 3rd one go?
Fri, 05 Jun 2015 22:00:17 +0000
Rocket Man
Rocket Man
Fri, 05 Jun 2015 22:00:17 +0000 linkquote
Re: Installing Bluetooth module
Instructions are very straight forward. Really an easy install. The most difficult part is installing the mounting bracket. Anticipate some swearing. I found that removing the horn cover gives better access for tightening down the bracket.
Things do get somewhat cramped behind that knee pad. Also, note the protective adhesive tape. That comes with the mounting kit. Holds and protects the wiring. Hope this helps.
Fri, 05 Jun 2015 23:46:48 +0000
GTV 300 ABS
GTV 300 ABS
Fri, 05 Jun 2015 23:46:48 +0000 linkquote
Thank you again.
[ Time: 0.0267s ][ Queries: 6 (0.0032s) ][ Debug on ][ 237 ][ Thing Two ]
