Thu, 04 Jun 2015 20:47:38 +0000
2003 ET4, 2005 LX 150, 1964 GS 160
Thu, 04 Jun 2015 20:47:38 +0000 quote
Hey everyone!
I changed front fork oil on other scooters no problem but this fly's fork design is different and the manual didn't show very well on how to change the oil... wondering if y'all have something to show me?
This fork is driving me crazy
Thu, 04 Jun 2015 20:55:32 +0000
2007 250 GTS, 1980 P200E, 2010 ThunderFly 190 (SOLD) 2015 Yamaha SMax
Thu, 04 Jun 2015 20:55:32 +0000 quote
Mic - I don't have an answer for you, but will be watching this thread closely.
Still looking for a new rear shock that might be better then OEM that'll work.
Thu, 04 Jun 2015 21:11:06 +0000
Thu, 04 Jun 2015 21:11:06 +0000 quote
Yeah replace rear shock would help a better ride...
I made many fly tutorial videos and will post them on my youtube channel soon and planning to make fork video but I'm stuck haha
Hopefully someone will come in and help
Fri, 05 Jun 2015 00:20:18 +0000
09 190s taormina
09 190s taormina
Fri, 05 Jun 2015 00:20:18 +0000 quote
From the exploded diagram in the parts book looks like no removable cap at top of tube, is this what you mean? Looks like only disassembly possible is lower leg removal.
http://www.af1racing.com/store/ProdImages/st3/ese4000us3.pdf
Fri, 05 Jun 2015 01:30:05 +0000
lx150
lx150
Fri, 05 Jun 2015 01:30:05 +0000 quote
Many forks today have to be removed opened up and turned upside down to remove the oil. Service needed is so infrequent but a complete PITA when it has to be done
Fri, 05 Jun 2015 19:43:11 +0000
Fri, 05 Jun 2015 19:43:11 +0000 quote
picture of fork
This is what it looks like on the top...
Fri, 05 Jun 2015 19:54:52 +0000
Fri, 05 Jun 2015 19:54:52 +0000 quote
other picture
Fri, 05 Jun 2015 20:02:13 +0000
Fri, 05 Jun 2015 20:02:13 +0000 quote
ahh yes I found out that have to push top down really hard then able to remove the ring clip!
Fri, 05 Jun 2015 22:14:09 +0000
Fri, 05 Jun 2015 22:14:09 +0000 quote
Are you planning to just change the oil? different weight? Different Springs?
Fri, 05 Jun 2015 22:53:36 +0000
Fri, 05 Jun 2015 22:53:36 +0000 quote
Yes just changing oil with same weight
Fri, 05 Jun 2015 23:17:56 +0000
Fri, 05 Jun 2015 23:17:56 +0000 quote
What inspired you to change the oil? I've only ever done that when the fork seals needed replacing - which in a used-all-year-round and winter salted roads environment is every two years or so.
Normally fork oil isn't under any mechanical stress - so do you ask for your car shocks to have oil replaced? I can't think of any reason to change fork oil on a PTW unless there's some other problem.
Sat, 06 Jun 2015 02:26:20 +0000
Sat, 06 Jun 2015 02:26:20 +0000 quote
Someone said they needed to put thicker oil in their Fly's forks, so it would seem possible.
Sat, 06 Jun 2015 02:32:53 +0000
Sat, 06 Jun 2015 02:32:53 +0000 quote
http://www.scooterclube.com.br/download/Kasinski-fly150-servico.pdf
There's a diagram on page 223, which is the very last page.
It would seem that you can take it apart. It has the bolt on the bottom that keeps it all together, so there must be a way to put oil in.
Sat, 06 Jun 2015 02:35:41 +0000
Sat, 06 Jun 2015 02:35:41 +0000 quote
Old discussion here: FLY 150 Suspension options..Any thoughts?
Sat, 06 Jun 2015 02:42:20 +0000
[ Time: 0.0383s ][ Queries: 6 (0.0159s) ][ Debug on ][ 276 ][ Thing Two ]
