Wed, 03 Jun 2015 00:04:50 +0000
Posts: 903 |
quote
Lye will also react with aluminum, but be careful with both muriatic acid or lye, both can react violently with certain metals like aluminum or chromium (chrome plating). They react very slowly with iron, so they'll be say to leave in the bore for minutes or hours, but don't leave it in for days or it will pit. Both work great for removing chrome plating, too.
![]() 74 Super, 75 Super, PX project, LML off-roader and new to 2018, '66 Blue Badge Smallframe
Posts: 8180 Location: Victoria, Australia |
Wed, 03 Jun 2015 02:56:25 +0000
quote
Neurotic-Hapi-Snak wrote: Both work great for removing chrome plating, too. |
Wed, 03 Jun 2015 04:13:53 +0000
Posts: 903 |
quote
Small parts you can dip into a container, larger parts you can wipe the solution on. Just be careful, read how to do it online, and dilute the lye/muriatic. Make sure to wear rubber gloves and goggles, and have some water (bucket or hose) or baking soda or mild alkali for muriaic or vinegar or other mild acid for lye. Lye usually comes as a powder/pellets and creates an exothermic reaction when mixed with water, so if you put it in too quickly it can cause the water to violently flash boil and spray liquid onto you. When you put the part into the liquid (lye or muriatic) or wipe the solution on, it can also react violently react and spray liquid onto you. If it gets on your skin either will cause painful burns, but can easily cause blindness or severe vision damage if it gets in your eye.
Sat, 13 Jun 2015 08:38:02 +0000
quote
Removing rattle-can paint
Totah wrote: ... I've had luck with using mineral spirits and acetone to gently remove spray paint from original 1960's paint .... |
![]() '74 50s x3 '78 P200 E '84 Cosa '91 PK50XL2 '58 AllState '68 Sprint '80 50special and a '66(?) Super125
Posts: 8909 Location: seattle/athens |
Mon, 15 Jun 2015 07:41:42 +0000
quote
Idle jet chart
icloudfiles wrote: I run a 40/130 for idle and its nearly perfect. I do wanna try 42/140 to see if it gets any better. ![]() |
Sat, 27 Jun 2015 23:59:41 +0000
quote
Bicycle cables
SubEtherBASS wrote: I found the ends on bicycle cables were too big for use as gear cables, i used to grind back the knob... Now i simply drilled out the holder... So if a cable breaks its easy to replace at any bike shop. ![]() |
Sun, 28 Jun 2015 01:14:19 +0000
quote
Fitting exhaust gas probe
hobospeed wrote: I've been told the way that a lot of racers choose the position of their probe is to use some cheap BBQ spray paint on the header and go for a fast ride. The spot where the paint starts to burn/blister first is where you want to position your probe as that's the hottest part of the header. |
Sat, 04 Jul 2015 01:05:36 +0000
quote
DIY carb jets made easy
Here's the full meal deal, what to do, where to get stuff & how to know what you did.
Thank you, gentlemen. Warhorse wrote: joshzingzing wrote: how does the drill bit measurement go say i want to turn my 116 into a 120 what size drill bit is that? xx I jet my 150 like this. I've got lots of jets that are too small to be useful to me, so I take a 1mm drill but and ream them out till it's just right. With the simo pipe I'm guessing it's between 105 and 110. I'm a cheap bastard. TrumpyScooter wrote: josh you can buy a set of micro drills for this purpose, for example... http://www.ebay.com/itm/20-Titanium-coated-mini-Micro-HSS-drill-bit-set-0-3-1-6MM-in-dispencer-Case-/361296095255?pt=LH_DefaultDomain_3&hash=item541eece817 not exactly a reamed hole but they work Ginch wrote: I've drilled jets before. If you really want to know exactly what size you have drilled, get a tapered needle like the one below. It's for some kind of knitting or something, I can't remember just now. Anyway you draw black on it with a texta/sharpie/permanent marker, then put it into the jet and twirl it a bit. Pull it out and you'll see a ring where the hole has rubbed the black off. Get your verniers and measure the diameter at that point. ![]() |
Wed, 08 Jul 2015 21:22:17 +0000
quote
how to gas up
Can be challenging at first and that quickie drawing really is first class. Also noted, pull back the vapor collar if needed, then do as shown.
astromags wrote: scooterace wrote: Okay I've read a couple threads regarding this... I've never had a problem with any of my vintage bikes. Just do as the others suggested... Gooooo slooooooow. Try to find a gas station with slow pumps. ![]() Bored at work today. |
![]() '81 and '80 p200e
Posts: 78 Location: California |
Sat, 11 Jul 2015 19:17:08 +0000
quote
Found a wench
Found a wrench for 7/8mm cable adjustments on my p200e. It is very thin so you can tighten easily. Look for AMF 51391 Thin double open end metric wrench.
Sun, 02 Aug 2015 10:30:15 +0000
quote
broken cable adjuster
Me today -> The adjuster broke off in the cast lug on the front brake! What to do? No guarantees, but here's a way to get the broken piece out w/o buggering the threads if you don't have a tiny EZ-Out. If you grind a masonry nail to a sharp taper just bigger than the hole, you can hammer it in & unscrew the broken piece out.
You may need to sneak up on the taper & size, I went back to the grinder a couple of times making the taper longer & sharper. I ground it roughly triangular, but it's not fussy as long as you have some sharp edges to cut & grip. Grind 2 flats on the head as well to turn it - visegrips are useless on these. Must be hardened alloy concrete or brick nails, normal nails won't do it. Grab a handful next time you're at the hardware store, they make dandy center punches and are good as small normal punches w/ the tip ground flat plus anytime you need something hard & strong. ![]() ![]()
Positive
![]() Vespa GS150, Messerschmitt GS150
Posts: 1062 Location: Glasgow |
Tue, 04 Aug 2015 14:25:08 +0000
quote
^^ fcking pain in the arse when that happens, I guess we need to put a little copper grease on them to stop this from happening. used a similar method with a small screw driver.
![]() Tue, 04 Aug 2015 14:31:34 +0000
1966 Bluebadge, 1974 Super 150
Posts: 1117 Location: New York City |
![]() 1966 Bluebadge, 1974 Super 150
![]() '80 P200E, '76 Primavera 125 ET3. '59 Vespa 150
Posts: 6894 Location: GT, Texas |
Tue, 04 Aug 2015 16:01:26 +0000
quote
I have a set of these screw extractors. The small one does the job perfectly.
Tue, 04 Aug 2015 21:44:02 +0000
quote
Choosing a main jet
oopsclunkthud wrote: The butt-dyno method: you will need a section of road that is flat or slightly up hill and long enough to redline in 3rd. Lets say you are starting from a main jet of 120 get sizes 122, 124, 126, 128, 130 put in the 130 and try to max it out in 3rd. If it does not cough and sputter you need to go bigger (140) and start over. If it does cough and sputter you now know that is too big, so go half way down to where you were (126) and repeat. The goal is to find the largest jet that will rev out cleanly. that jet is likely safe to ride WOT all day long. moving to a smaller jet than this would give more power but adds risk. Without gauges or experience this risk is not worth it. here's a hypothetical example of the process: 120 runs great but it seized 130 still runs great, crap I was way lean 140 boggy as hell 136 revs out fine, try larger 138 boggy, but not as bad at 140 136 is the jet!
Positive
Thu, 06 Aug 2015 21:16:14 +0000
quote
evolution
xkrebstarx wrote: I use an Allen Wrench and bang it in there. Little screwdrivers can work on easy ones, but mine just started reaming the hole on this last one. The screw extractors are nice and all my bigger ones are still unbroken. They are really hard(brittle) and sometimes the little ones snap off when there's a problem or if you're clumsy. But Torx drive bits are perfect, hard enough but tuff for the torque you need. I tried a T-10 and ground a small taper on the tip. I grabbed a T-15 too for bigger ones, still need to taper that one(put in drill & hold lightly against grinder while spinning). On the left you can see an adjuster I ground a couple of spiral grooves in. I use it to chase out the threads like a tap. PS Thinking about 'reconstituting' this thread, a condensed version w/ only the actual valid tips included. I like the comments, compliments & even the nonsense if it's funny too, but it's wrecking the thread & you can't find shit anymore. It would just be a 'new' thread w/ a buttload of quoted posts to start, maybe rough sorted, then whatever you guys make of it . OK? ![]() |
Fri, 14 Aug 2015 10:17:29 +0000
quote
GLscoot wrote: ^^ whats the benefits of this. *with thanks to the inventor of StudSleeves! |
Tue, 18 Aug 2015 19:03:49 +0000
quote
Ginch wrote: GLscoot wrote: ^^ whats the benefits of this. had a look, surely retapping the threads to M8 would be just as good. *with thanks to the inventor of StudSleeves! |
Posts: 6716 Location: So Cal |
Tue, 18 Aug 2015 19:31:38 +0000
quote
Dowels allow for *slightly* more precise alignment tolerances. But I agree, the actual payoff vs the amount of work involved is debatable. At some point it's diminishing returns..
![]() '76 Vespa Rally 200
Posts: 617 Location: Melbourne |
Wed, 19 Aug 2015 04:54:01 +0000
quote
Ginch wrote: Handy information! |
![]() Wed, 19 Aug 2015 09:09:55 +0000
px244gs, cosa221LX, sprint177, gilera runner 180, triumph tiger 955
Posts: 83 Location: vienna/austria (the other one, w/o kangaroos) |
![]() px244gs, cosa221LX, sprint177, gilera runner 180, triumph tiger 955
quote
thx mike for sharing
![]() hope it saves nerves for some guys some more video tips out of my workshop: checking the crankshaft i guess how to check a crankshaft is already known here here is a video how to do it 1) pressfit 2nd one is a LML crank perfect for exercising 2) runout alignment 3) stump check good old t5 crank: all new piaggio cases are crap and cause sucking gearbox oil --> si carb cant be set right. blowback probs etc. simply compare a good old case with the new one it really hits the eyes. quality got worse around 2001 with px millenium and is continued with px125:2011 which is even worse qualityvise (the crank is asian and crap) they stopped working properly on the sealing surfaces: ![]() malossi case italian style! only vine, pasta and AMORE in mind ![]() |
Thu, 20 Aug 2015 10:02:52 +0000
quote
Great video for anyone thinking about replacing their legshields. This guy makes it look like it's dead easy.
![]() Thu, 20 Aug 2015 10:08:56 +0000
Posts: 5109 Location: west aus |
![]() px200 cutdown,px180,px150. Puch SR. Puch scooterette
Thu, 20 Aug 2015 10:17:53 +0000
quote
Re: inox mx3
joshzingzing wrote: i want a spot welder like that |
![]() Thu, 20 Aug 2015 10:25:52 +0000
quote
Re: inox mx3
Ginch wrote: joshzingzing wrote: i want a spot welder like that |
![]() Thu, 20 Aug 2015 13:59:53 +0000
MV Santa
Posts: 4603 Location: Sedgwick, Kansas |
MV Santa
![]() GTS250, 1960 VBA, 1975 VBC, 1980 P200E cutdown
quote
Re: inox mx3
joshzingzing wrote: Ginch wrote: joshzingzing wrote: i want a spot welder like that |
![]() Thu, 20 Aug 2015 14:00:00 +0000
MV Santa
MV Santa
Thu, 20 Aug 2015 22:05:34 +0000
quote
Thanks VRM. No we don't have HF here. Couldn't find anything in that sort of price range, the cheapest one ($329) in a quick search was this... not so far from Josh as it happens.
http://graemesworkshop.com/shop/other-tools/spot-welder-1-5mm-1-5mm.html |
![]() '79 P200E, '77 Rally, '76 V90, '74 Rally
Posts: 143 Location: San Francisco |
Thu, 20 Aug 2015 23:04:17 +0000
quote
Ginch wrote: Great video for anyone thinking about replacing their legshields. This guy makes it look like it's dead easy. That spot welder is sick! |
Sat, 24 Oct 2015 23:30:02 +0000
What we were hoping to see Try again, perhaps? |
![]() '70 Super 150, Aprilia SR MT 125, Moto Guzzi Bellagio
Posts: 2422 Location: Sydney, Australia |
Sun, 25 Oct 2015 00:50:42 +0000
quote
Re: grow business?
Vader19 wrote: Hi, I understand you are no doubt very busy; however, I am just following up on the previous email I sent you. We provide email marketing service and we can generate you new business leads and increase your sales. Please reply today so we can go over options for you. Yours, Dennis Lewis Contact: jaewisd@sina.com |
Mr. Clean
![]() P,SUPER,V90, 50 Special
Posts: 10205 Location: This is't my locker! |
Sun, 25 Oct 2015 02:35:21 +0000
quote
Bobo wrote: Vader19 wrote: Hi, I understand you are no doubt very busy; however, I am just following up on the previous email I sent you. We provide email marketing service and we can generate you new business leads and increase your sales. Please reply today so we can go over options for you. Yours, Dennis Lewis Contact: jaewisd@sina.com Hey moderators!! Hack alert! Serious.. No joke! |
Mr. Clean
![]() 1974 V90
Posts: 1403 Location: Rhode Island USA |
Sun, 25 Oct 2015 22:34:23 +0000
quote
Sitting the scooter on puppy pads before I unplug the fuel line from the carb and remove the tank.
Tue, 03 Nov 2015 06:05:03 +0000
![]() Tue, 03 Nov 2015 07:18:46 +0000
Mr. Clean
