Wed, 03 Jun 2015 00:04:50 +0000
Wed, 03 Jun 2015 00:04:50 +0000 quote
Lye will also react with aluminum, but be careful with both muriatic acid or lye, both can react violently with certain metals like aluminum or chromium (chrome plating). They react very slowly with iron, so they'll be say to leave in the bore for minutes or hours, but don't leave it in for days or it will pit. Both work great for removing chrome plating, too.
Wed, 03 Jun 2015 02:56:25 +0000
Wed, 03 Jun 2015 02:56:25 +0000 quote
Perfect, thanks!
Wed, 03 Jun 2015 04:13:53 +0000
Wed, 03 Jun 2015 04:13:53 +0000 quote
Small parts you can dip into a container, larger parts you can wipe the solution on. Just be careful, read how to do it online, and dilute the lye/muriatic. Make sure to wear rubber gloves and goggles, and have some water (bucket or hose) or baking soda or mild alkali for muriaic or vinegar or other mild acid for lye. Lye usually comes as a powder/pellets and creates an exothermic reaction when mixed with water, so if you put it in too quickly it can cause the water to violently flash boil and spray liquid onto you. When you put the part into the liquid (lye or muriatic) or wipe the solution on, it can also react violently react and spray liquid onto you. If it gets on your skin either will cause painful burns, but can easily cause blindness or severe vision damage if it gets in your eye.
Sat, 13 Jun 2015 08:38:02 +0000
Sat, 13 Jun 2015 08:38:02 +0000 quote
Removing rattle-can paint
Totah wrote:
... I've had luck with using mineral spirits and acetone to gently remove spray paint from original 1960's paint ....
Mon, 15 Jun 2015 07:41:42 +0000
Mon, 15 Jun 2015 07:41:42 +0000 quote
Idle jet chart
icloudfiles wrote:
I run a 40/130 for idle and its nearly perfect. I do wanna try 42/140 to see if it gets any better.
Ah yes, thanks! I knew that was around...
Sat, 27 Jun 2015 23:59:41 +0000
Sat, 27 Jun 2015 23:59:41 +0000 quote
Bicycle cables
SubEtherBASS wrote:
I found the ends on bicycle cables were too big for use as gear cables, i used to grind back the knob... Now i simply drilled out the holder... So if a cable breaks its easy to replace at any bike shop.
Sun, 28 Jun 2015 01:14:19 +0000
Sun, 28 Jun 2015 01:14:19 +0000 quote
Fitting exhaust gas probe
hobospeed wrote:
I've been told the way that a lot of racers choose the position of their probe is to use some cheap BBQ spray paint on the header and go for a fast ride. The spot where the paint starts to burn/blister first is where you want to position your probe as that's the hottest part of the header.
From Scooterotica.
Sat, 04 Jul 2015 01:05:36 +0000
Sat, 04 Jul 2015 01:05:36 +0000 quote
DIY carb jets made easy
Here's the full meal deal, what to do, where to get stuff & how to know what you did.
Thank you, gentlemen.
Warhorse wrote:
joshzingzing wrote:
how does the drill bit measurement go say i want to turn my 116 into a 120 what size drill bit is that? xx
They are infractions of a mm, so you'd need a 1.2mm drill bit.
I jet my 150 like this. I've got lots of jets that are too small to be useful to me, so I take a 1mm drill but and ream them out till it's just right. With the simo pipe I'm guessing it's between 105 and 110. I'm a cheap bastard.
TrumpyScooter wrote:
josh you can buy a set of micro drills for this purpose, for example...
http://www.ebay.com/itm/20-Titanium-coated-mini-Micro-HSS-drill-bit-set-0-3-1-6MM-in-dispencer-Case-/361296095255?pt=LH_DefaultDomain_3&hash=item541eece817
not exactly a reamed hole but they work
Ginch wrote:
I've drilled jets before. If you really want to know exactly what size you have drilled, get a tapered needle like the one below. It's for some kind of knitting or something, I can't remember just now.
Anyway you draw black on it with a texta/sharpie/permanent marker, then put it into the jet and twirl it a bit. Pull it out and you'll see a ring where the hole has rubbed the black off. Get your verniers and measure the diameter at that point.
Wed, 08 Jul 2015 21:22:17 +0000
Wed, 08 Jul 2015 21:22:17 +0000 quote
how to gas up
Can be challenging at first and that quickie drawing really is first class. Also noted, pull back the vapor collar if needed, then do as shown.
astromags wrote:
scooterace wrote:
Okay I've read a couple threads regarding this...
You must have been in the Modern section. Some of those things are notorious for spewing gas.
I've never had a problem with any of my vintage bikes. Just do as the others suggested... Gooooo slooooooow. Try to find a gas station with slow pumps.
Bored at work today.
Sat, 11 Jul 2015 19:17:08 +0000
'81 and '80 p200e
'81 and '80 p200e
Sat, 11 Jul 2015 19:17:08 +0000 quote
Found a wench
Found a wrench for 7/8mm cable adjustments on my p200e. It is very thin so you can tighten easily. Look for AMF 51391 Thin double open end metric wrench.
Sun, 02 Aug 2015 10:30:15 +0000
Sun, 02 Aug 2015 10:30:15 +0000 quote
broken cable adjuster
Me today -> The adjuster broke off in the cast lug on the front brake! What to do? No guarantees, but here's a way to get the broken piece out w/o buggering the threads if you don't have a tiny EZ-Out. If you grind a masonry nail to a sharp taper just bigger than the hole, you can hammer it in & unscrew the broken piece out.
You may need to sneak up on the taper & size, I went back to the grinder a couple of times making the taper longer & sharper. I ground it roughly triangular, but it's not fussy as long as you have some sharp edges to cut & grip. Grind 2 flats on the head as well to turn it - visegrips are useless on these.
Must be hardened alloy concrete or brick nails, normal nails won't do it. Grab a handful next time you're at the hardware store, they make dandy center punches and are good as small normal punches w/ the tip ground flat plus anytime you need something hard & strong.
Tue, 04 Aug 2015 14:25:08 +0000
Vespa GS150, Messerschmitt GS150
Tue, 04 Aug 2015 14:25:08 +0000 quote
^^ fcking pain in the arse when that happens, I guess we need to put a little copper grease on them to stop this from happening. used a similar method with a small screw driver.
Tue, 04 Aug 2015 14:31:34 +0000
1966 Bluebadge, 1974 Super 150
Tue, 04 Aug 2015 14:31:34 +0000 quote
I use an Allen Wrench and bang it in there.
Tue, 04 Aug 2015 16:01:26 +0000
Tue, 04 Aug 2015 16:01:26 +0000 quote
I have a set of these screw extractors. The small one does the job perfectly.
Tue, 04 Aug 2015 21:44:02 +0000
Tue, 04 Aug 2015 21:44:02 +0000 quote
Choosing a main jet
oopsclunkthud wrote:
The butt-dyno method:
you will need a section of road that is flat or slightly up hill and long enough to redline in 3rd.
Lets say you are starting from a main jet of 120
get sizes 122, 124, 126, 128, 130
put in the 130 and try to max it out in 3rd. If it does not cough and sputter you need to go bigger (140) and start over.
If it does cough and sputter you now know that is too big, so go half way down to where you were (126) and repeat.
The goal is to find the largest jet that will rev out cleanly. that jet is likely safe to ride WOT all day long. moving to a smaller jet than this would give more power but adds risk. Without gauges or experience this risk is not worth it.
here's a hypothetical example of the process:
120 runs great but it seized
130 still runs great, crap I was way lean
140 boggy as hell
136 revs out fine, try larger
138 boggy, but not as bad at 140
136 is the jet
Thu, 06 Aug 2015 21:16:14 +0000
Thu, 06 Aug 2015 21:16:14 +0000 quote
evolution
OH thanks That's a good one and you gave me an idea.
Little screwdrivers can work on easy ones, but mine just started reaming the hole on this last one.
The screw extractors are nice and all my bigger ones are still unbroken.
They are really hard(brittle) and sometimes the little ones snap off when there's a problem or if you're clumsy.
But Torx drive bits are perfect, hard enough but tuff for the torque you need. I tried a T-10 and ground a small taper on the tip. I grabbed a T-15 too for bigger ones, still need to taper that one(put in drill & hold lightly against grinder while spinning). On the left you can see an adjuster I ground a couple of spiral grooves in. I use it to chase out the threads like a tap.
PS Thinking about 'reconstituting' this thread, a condensed version w/ only the actual valid tips included. I like the comments, compliments & even the nonsense if it's funny too, but it's wrecking the thread & you can't find shit anymore. It would just be a 'new' thread w/ a buttload of quoted posts to start, maybe rough sorted, then whatever you guys make of it .
OK?
Fri, 14 Aug 2015 03:03:37 +0000
Fri, 14 Aug 2015 03:03:37 +0000 quote
Cylinder and head doweling.
Fri, 14 Aug 2015 09:31:40 +0000
Fri, 14 Aug 2015 09:31:40 +0000 quote
^^ whats the benefits of this.
Fri, 14 Aug 2015 10:17:29 +0000
Fri, 14 Aug 2015 10:17:29 +0000 quote
Have a read of the link Gary. For instance someone told me that fitting the dowels (or stud sleeves*) cured his pinging.
*with thanks to the inventor of StudSleeves!
Tue, 18 Aug 2015 12:38:31 +0000
Tue, 18 Aug 2015 12:38:31 +0000 quote
Handy information!
Tue, 18 Aug 2015 19:03:49 +0000
Tue, 18 Aug 2015 19:03:49 +0000 quote
had a look, surely retapping the threads to M8 would be just as good.
Tue, 18 Aug 2015 19:31:38 +0000
Tue, 18 Aug 2015 19:31:38 +0000 quote
Dowels allow for *slightly* more precise alignment tolerances. But I agree, the actual payoff vs the amount of work involved is debatable. At some point it's diminishing returns..
Wed, 19 Aug 2015 04:54:01 +0000
'76 Vespa Rally 200
'76 Vespa Rally 200
Wed, 19 Aug 2015 04:54:01 +0000 quote
Ginch wrote:
Handy information!
Wish I had known this before I did my rebuild, I never checked this clearance. Next time...
Wed, 19 Aug 2015 09:09:55 +0000
px244gs, cosa221LX, sprint177, gilera runner 180, triumph tiger 955
Location: vienna/austria (the other one, w/o kangaroos)
Wed, 19 Aug 2015 09:09:55 +0000 quote
thx mike for sharing
hope it saves nerves for some guys
some more video tips out of my workshop:
checking the crankshaft
i guess how to check a crankshaft is already known here
here is a video how to do it
1) pressfit
1st is a mazzu 57 crank
2nd one is a LML crank
perfect for exercising
2) runout alignment
3) stump check
good old t5 crank:
brandnew polini crank...
check your crankcases to avoid oilsucking!
all new piaggio cases are crap and cause sucking gearbox oil
--> si carb cant be set right. blowback probs etc.
simply compare a good old case with the new one
it really hits the eyes.
quality got worse around 2001 with px millenium
and is continued with px125:2011 which is even
worse qualityvise (the crank is asian and crap)
they stopped working properly on the sealing surfaces:
malossi case
piaggio case:
unfortunately also the new pinasco cases look the same..
italian style!
only vine, pasta and AMORE in mind
Thu, 20 Aug 2015 10:02:52 +0000
Thu, 20 Aug 2015 10:02:52 +0000 quote
Great video for anyone thinking about replacing their legshields. This guy makes it look like it's dead easy.
Thu, 20 Aug 2015 10:08:56 +0000
Thu, 20 Aug 2015 10:08:56 +0000 quote
inox mx3
i want a spot welder like that
Thu, 20 Aug 2015 10:17:53 +0000
Thu, 20 Aug 2015 10:17:53 +0000 quote
Re: inox mx3
You create a distraction and I'll stick it up my jacket.
Thu, 20 Aug 2015 10:25:52 +0000
Thu, 20 Aug 2015 10:25:52 +0000 quote
Re: inox mx3
I wonder if they are somewhere near affordable. .. Google
Thu, 20 Aug 2015 13:59:53 +0000
MV Santa
MV Santa
Thu, 20 Aug 2015 13:59:53 +0000 quote
Re: inox mx3
I don't know if you have Harbor Freight there. They sell cheap, mostly Chinese tools. Not great quality but usually acceptable for occasion use. They have them for ~$200 USD. Not too bad but still quite a bit for something you will use very seldomly. You could drill holes and use a MIG welder.
Thu, 20 Aug 2015 14:00:00 +0000
MV Santa
MV Santa
Thu, 20 Aug 2015 14:00:00 +0000 quote
Duplicate post deleted.
Thu, 20 Aug 2015 22:05:34 +0000
Thu, 20 Aug 2015 22:05:34 +0000 quote
Thanks VRM. No we don't have HF here. Couldn't find anything in that sort of price range, the cheapest one ($329) in a quick search was this... not so far from Josh as it happens.
http://graemesworkshop.com/shop/other-tools/spot-welder-1-5mm-1-5mm.html
Thu, 20 Aug 2015 23:04:17 +0000
'79 P200E, '77 Rally, '76 V90, '74 Rally
Thu, 20 Aug 2015 23:04:17 +0000 quote
That's pretty amazing. That he just smoked all the way through this. No problemo...jeez. I won't be attempting that, thank you very much!
That spot welder is sick!
Sat, 24 Oct 2015 23:30:02 +0000
This post was not quite
What we were hoping to see
Try again, perhaps?
Sun, 25 Oct 2015 00:50:42 +0000
Sun, 25 Oct 2015 00:50:42 +0000 quote
Re: grow business?
Vader19 wrote:
Hi,
I understand you are no doubt very busy; however, I am just following up on
the previous email I sent you.
We provide email marketing service and we can generate you new business
leads and increase your sales.
Please reply today so we can go over options for you.
Yours,
Dennis Lewis
Contact: jaewisd@sina.com
Good tip.
Sun, 25 Oct 2015 02:35:21 +0000
Mr. Clean
P,SUPER,V90, 50 Special
Mr. Clean
Sun, 25 Oct 2015 02:35:21 +0000 quote
Bobo wrote:
Vader19 wrote:
Hi,
Yours,
Dennis Lewis
Good tip.
What the hell? That's not me!! I've been hacked here on MV!
Hey moderators!! Hack alert!
Serious.. No joke!
Sun, 25 Oct 2015 02:46:41 +0000
Mr. Clean
Mr. Clean
Sun, 25 Oct 2015 02:46:41 +0000 quote
I changed my password.. Damn spammer/hackers..
Sun, 25 Oct 2015 22:34:23 +0000
1974 V90
1974 V90
Sun, 25 Oct 2015 22:34:23 +0000 quote
Sitting the scooter on puppy pads before I unplug the fuel line from the carb and remove the tank.
Tue, 03 Nov 2015 06:05:03 +0000
Try again, perhaps?
Tue, 03 Nov 2015 07:18:46 +0000
Tue, 03 Nov 2015 07:18:46 +0000 quote
from russia with love
youve got bugs mate
Tue, 03 Nov 2015 16:08:54 +0000
Mr. Clean
Mr. Clean
Tue, 03 Nov 2015 16:08:54 +0000 quote
Muther f'ers!
I changed my password after the last hack WTH?
[ Time: 0.0490s ][ Queries: 6 (0.0226s) ][ Debug on ][ 277 ][ Thing Two ]
