Sat Aug 21, 2010 7:22 pm
Moderatus Rana
MP3 250 and 2 MP3 500s
Moderatus Rana
Sat Aug 21, 2010 7:22 pm linkquote
I figured I may as well remove the evap and roll over. Posting this mainly so I can link to them for a wiki I will do on this.
Sat Aug 21, 2010 8:10 pm
2009 MP3 500, Red. Had MP3 250, Barron 150 Retro
Sat Aug 21, 2010 8:10 pm linkquote
so why??
I have the 250. Why would you do this?
What is that thing under the seat?
I've had mine a part like that once. Pretty easy.
Just wonder why do it?
Great pics.
Sun Aug 22, 2010 3:29 am
RIP: MP3 500 - Brutto Moto
Sun Aug 22, 2010 3:29 am linkquote
The evap canister is a known culprit for stalling out and other oddball issues... on all models I might add.
Sun Aug 22, 2010 3:37 am
Bracketmeister
Bracketmeister Emeritus (retired)
Bracketmeister
Sun Aug 22, 2010 3:37 am linkquote
Fuzzy EDIT: (I meant Sticky, dammit I hate when I do that), the can and its bracket look identical to the one in the 500. If so, that bracket just happens to exactly fit the mini air compressors that have been posted about.
Just sayin'.
Sun Aug 22, 2010 4:01 am
Sun Aug 22, 2010 4:01 am linkquote
rjeffb wrote:
Fuzzy, the can and its bracket look identical to the one in the 500. If so, that bracket just happens to exactly fit the mini air compressors that have been posted about.
Just sayin'.
My bracket went in the trash a year ago. No regrets.
Sticky, pay attention to where the vent line ends up. A full gas tank on a hot day (not that those happen often in Florida ) will push some gas through the tube. Don't want it venting around hot exhaust. On one occasion after over filling my gas tank I had some gas hitting the ground before I finished getting my gear back on to leave. The vent hose still goed up just under the seat bucket so the gas was pushed up and over. Also with a filter on the vent line, will it still work when it becomes saturated with gas?
If this subject is new to others, be advised that only North American Piaggios have the evap canisters and roll over valve installed. Others just have an unfiltered, open vent line on the gas tank. Many here and on general forum have reported solving problems by eliminating the canister. If your gas tank is under pressure or vacumn when you remove the gas cap then you have a cloged canister and or malfunctioning roll over valve. One member reported enough pressure that when unscrewing the cap it blew off past his head and over to the next pump.
Sun Aug 22, 2010 5:00 am
Moderatus Rana
Moderatus Rana
Sun Aug 22, 2010 5:00 am linkquote
@Bikemor
The black thing under the seat is a charcoal, evaporative canister and is there to take gas vapor vented from the fuel tank and send it to the intake to be burned when the engine is running or vent it after it goes through the charcoal thus keeping it out of the environment. Or at least that is my basic understanding.
There are a few reasons to get rid of it.
1. The bike was designed without this system and it is only added to US models because of environmental laws in California. Some feel that it can have negative effect on performance of the engine and many times it is the first system disconnected when troubleshooting to rule it out.
2. Increases under seat storage area.
3. It has been reported that overfills of the gas tank can cause issues with evap canister (though I don't quite understand how the gas gets past the rollover valve) and the canister causes stalling and rough idling issues. This has also been reported in some scooters that have been tipped over.
4. In my experience the system (i think mostly the rollover valve) causes a negative pressure in gas tank. Some report positive pressure. From what I understand there is supposed to be zero pressure.
So I figured since I have the side panel off to fix my voltage regulator I may as well get rid of the evap system.
Sun Aug 22, 2010 5:13 am
Moderatus Rana
Moderatus Rana
Sun Aug 22, 2010 5:13 am linkquote
Just sayin'.
I was also thinking extra fuel, fire extinguisher, water of maybe even a can of fix a flat.
@fuzzy
I put the vent line forward of the exhaust pipe so it should be safe. Not sure about the inline filter performance if it gets soaked with gas. I will be watching it and will report if it causes a problem. I am thinking that I may use this as a feed from an aux tank maybe from the pet carrier or somewhere. I would need to figure out a new way to vent.
Sun Aug 22, 2010 6:32 am
'09 Mp3-500 - Gone Now
Sun Aug 22, 2010 6:32 am linkquote
stickyfrog wrote:
Just sayin'.
I was also thinking extra fuel, fire extinguisher, water of maybe even a can of fix a flat....
Nice series of photos, sticky. Will be great in the wiki.
Actually the bracket on the 500 is very different - but the concept is the same using that bracket to support something of ~real~ value in the per carrier makes a lot of sense! The bracket on the 250 looks to mount in square and level, as opposed to the oddball angle on the 500. Pic below.
Link to my thread on air compressor install using evap canister bracket.
Evap Can Bracket in Mp3 500 Pet Carrier
Sun Aug 22, 2010 2:20 pm
2007 Piaggio MP3 250 (sold) and 2009 MP3 400 (sold) 2011 CanAm Spyder RSS
Sun Aug 22, 2010 2:20 pm linkquote
Question - if you remove the rollover valve, what would keep the scoot from leaking gas in the event of a rollover? Not that I plan on rolling over any time soon....
Sun Aug 22, 2010 3:13 pm
Sun Aug 22, 2010 3:13 pm linkquote
Just a note - a hot exhaust won't make petrol liquid or vapour ignite - it's not nearly hot enough! It'll just boil or dissipate. Zero problem.
Sun Aug 22, 2010 5:12 pm
Moderatus Rana
Moderatus Rana
Sun Aug 22, 2010 5:12 pm linkquote
Yeah I wasn't as worried about gas on the exhaust as much as keeping it off the tupperware or and other parts that may not like it.
Holly. No not too worried about gas escaping if the bike goes over. I believe roll over valves are put in to keep the charcoal in the cannister safe.
Seriously though I don't think much spillage occurs so it really doesn't worry me much. I have and bikes going back to the 70's that I have dropped and the only gas issue I can remember is flooded carbs.
Sun Aug 22, 2010 7:39 pm
Sun Aug 22, 2010 7:39 pm linkquote
me thinks a small flask of whiskey will strap right in the old evap can spot. very important when going camping having the proper fuel.
Sun Aug 22, 2010 8:16 pm
Sun Aug 22, 2010 8:16 pm linkquote
That makes much more sense!
Mon Aug 23, 2010 4:01 am
Moderatus Rana
Moderatus Rana
Mon Aug 23, 2010 4:01 am linkquote
Another great idea Doug! Tennessee or Kentucky?
Mon Aug 23, 2010 4:15 am
Mon Aug 23, 2010 4:15 am linkquote
some that good stuff you get from BEHIND the counter
Mon Aug 23, 2010 10:09 am
Moderatus Rana
Moderatus Rana
Mon Aug 23, 2010 10:09 am linkquote
Unlabeled no doubt.
Ok I did a evap removal wiki. MP3 250: Removal of the evap canister and roll over valve
Probably needs lots of edits and help but it is a start.
Mon Aug 23, 2010 10:28 am
Mon Aug 23, 2010 10:28 am linkquote
stickyfrog wrote:
Unlabeled no doubt.
I'll have some samples for us in sept
Mon Aug 23, 2010 12:07 pm
Moderatus Rana
Moderatus Rana
Mon Aug 23, 2010 12:07 pm linkquote
Looking forward to it. I am gonna need it I think. Just ordered over $500.00 in parts to change the VR and do all of the 12,000 mile service stuff plus replace the belt + rollers. Whew, it ain't cheap but is sure is worth it.
Gonna be down for awhile though...where did I put that pesky battery conditioner.
⬆️    About 5 years elapsed between posts    ⬇️
Thu Jul 23, 2015 1:26 pm
2016 BV350
2016 BV350
Thu Jul 23, 2015 1:26 pm linkquote
On the 400, Is that same canister under the cover in the very front of the storage area (same cover has a cig lighter power port)?
I don't have that setup on my 400, but what looks to be the same black box up at the front. Same procedure?
Thnx!
Thu Jul 23, 2015 1:34 pm
2016 BV350
2016 BV350
Thu Jul 23, 2015 1:34 pm linkquote
Just found this thread for the 400 evap:
Where is Evap Canister on 400 -- Pics Added Below
⬆️    About 6 years elapsed between posts    ⬇️
Wed Sep 15, 2021 5:44 pm
Florida Man
MP3 500 HPE Sport Advanced
Florida Man
Wed Sep 15, 2021 5:44 pm linkquote
Yes, Great pics, and an Air Compressor is a fantastic idea !!!
[ Time: 0.0285s ][ Queries: 7 (0.0069s) ][ Debug on ][ 209 ][ Thing One ]
