![]() MP3 500 'JAZZ'
Posts: 1209 Location: Not on my MP3 ;( - Folsom, CA. - |
If you have a sleeve which has a solid metalic ( or graphite ) coating at one end my view would be that the woven end should be fitted inside the silencer after making sure that the split pipe end is spread enough so that no force is required.
Fit the graphite coated end facing forward so that the sleeve will hold together as you slide it on to the exhaust pipe. Use plenty of copper grease on all parts. This will help it bed together more easily and it will also help if you need to split the joint for tyre changes etc. Regards Roadster |
Just bought a non standard woven type seal off ebay that was advertised for the MP3 but it was not long enough to fully seal the slots so I had to seal them with an extra jubilee clip.
Make sure you get a genuine one although they are quite expensive in comparison. |
Posts: 40896 Location: Pleasant Hill, CA |
![]() Sun May 11, 2014 6:32 am
Posts: 22038 Location: Harriman, Tennessee, Tn |
mvtroiano wrote: I just looked at the WIKI and it said to put the muffler gasket in with the mesh facing out towards the engine. People here are saying the mesh goes into the muffler. Oy Vey I'm confused. |
mvtroiano wrote: I just looked at the WIKI and it said to put the muffler gasket in with the mesh facing out towards the engine. People here are saying the mesh goes into the muffler. Oy Vey I'm confused. I'll alter the Wiki. ... Wiki annotated. |
![]() Tue Dec 29, 2015 5:46 pm
MP3 500
Posts: 265 Location: Columbus OH USA |
Just had another graphite ring blow out. Both times they cracked after riding through water. I'm tempted to use some muffler repair tape to build up the area in front of the graphite ring to protect it from getting wet and blowing out again. Does this sound reasonable?
[quote="Buckeye Marksman"]Just had another graphite ring blow out. Both times they cracked after riding through water. I'm tempted to use some muffler repair tape to build up the area in front of the graphite ring to protect it from getting wet and blowing out again. Does this sound reasonable?
[quote] That's puzzling. I've been through several floods and even forded a stream without this happening. Once assembled very little of the collar should be exposed and it should all be clamped up tight. Are you sure that you are inserting it fully in to the silencer? I can only repeat my suggestion that you should use copious amounts of Coppa-slip or similar non-setting copper grease. Put the grease under the clamp and on the screw thread as well. It all helps get a snug fit for a given amount of torque on the clamp. |
![]() Wed Dec 30, 2015 6:08 am
MP3 500
roadster wrote: Buckeye Marksman wrote: Just had another graphite ring blow out. Both times they cracked after riding through water. I'm tempted to use some muffler repair tape to build up the area in front of the graphite ring to protect it from getting wet and blowing out again. Does this sound reasonable? |
![]() Wed Dec 30, 2015 3:28 pm
![]() 2016 MP3/500 Sport ABS, 2009 MP3/250, 2012 GTS Super 300ie
Posts: 4295 Location: Marietta, GA |
The first thing I did when I got my New 2016 Home from the Dealer was take that 80 pound weight off the bike for one of these. I love the sound as I don't have any DB Killers Installed, and no gasket to deal with...
https://scooterpartsco.com/piaggio-parts/piaggio-mp3-500-parts/leo-vince-sbk-nero-slip-on-for-piaggio-mp3-400-500?zenid=tkv5pfuahsqsve3u7u7mo1epf1 ![]() |
![]() Thu Dec 31, 2015 7:54 am
Posts: 6939 Location: Madison, Wisconsin |
![]() MP3 500, GTS 250 (both 2008 MY), 2012 Honda NC700 DCT, 2014 Can Am Spyder RT
23,000 miles on my MP3, taken the muffler off three times I think (maybe four), and still on the original graphite gasket. Got a spare handy, though.
I forget which way I insert the gasket... I want to say I insert it into the muffler, but with the mesh facing out so as not to be damaged by the four wings of the muffler when it is compressed, and wiggles around. I guess I hadn't thought about the end of the downpipe digging in. |
2007 MP3 250(retired) C650GT
Posts: 708 Location: Fredericksburg, VA |
there seems to be several styles of gaskets that yamaha sold
this one seems like it would hold up the best. its made of copper. with what looks like asbestos for soft seal. cost to make them must have been higher. 2G2-14714-00 full graphite 3YF-14714-00 3YF-14714-00-00 |
![]() 2008 MP3 500, 2013 BV350, 2020 Vespa Sei Giorni
Posts: 8763 Location: Ashburn, Va. Home to the Internet |
![]() Wed Nov 13, 2019 3:59 pm
jerryd wrote: you do understand what "looks like" means? maybe not. whatever it is it is there so it can slide. and copper if far more durable and heat resistant to steel wire mesh. so the more intelligent shoppers may see it as a better buy. So I guess I'm not so intelligent, huh? |
