![]() MP3 500 'JAZZ'
Posts: 1211 Location: Not on my MP3 ;( - Folsom, CA. - |
Wed, 30 Apr 2014 05:54:29 +0000
quote
Okay, I looked in the manual, and nothing in there. Which way does the muffler gasket go on? I pulled my muffler off, and there was no gasket what so ever! Is that normal? I think it blew the gasket about 1,000 miles back or so
![]() Kymco AK550
Posts: 1163 Location: UK |
Wed, 30 Apr 2014 08:08:21 +0000
quote
If you have a sleeve which has a solid metalic ( or graphite ) coating at one end my view would be that the woven end should be fitted inside the silencer after making sure that the split pipe end is spread enough so that no force is required.
Fit the graphite coated end facing forward so that the sleeve will hold together as you slide it on to the exhaust pipe. Use plenty of copper grease on all parts. This will help it bed together more easily and it will also help if you need to split the joint for tyre changes etc. Regards Roadster |
MP3 250 LML vespa
Posts: 74 Location: Kettering UK |
Wed, 30 Apr 2014 08:19:23 +0000
quote
Just bought a non standard woven type seal off ebay that was advertised for the MP3 but it was not long enough to fully seal the slots so I had to seal them with an extra jubilee clip.
Make sure you get a genuine one although they are quite expensive in comparison. |
Wed, 30 Apr 2014 09:45:26 +0000
quote
Thank you both! I did spring for the original Piaggio gasket. Heinlein dropped off two Yamaha 5PX-14755-00 gaskets, which seem to be the same size as ours at less than half the price. I will take a picture of the both tomorrow and show you then side by side.
Thu, 01 May 2014 02:02:06 +0000
quote
I put the Piaggio gasket in upside down, and I had to use some force to pull it out:9 So.... it is a little elongated. The Yamaha is on the left and the Piaggio is on the right.
Posts: 42294 Location: Pleasant Hill, CA |
Fri, 02 May 2014 05:21:06 +0000
quote
I really had to force and pound the muffler back on today. It's soooo sad to hear the sound of a now scooter again.
Sun, 11 May 2014 07:26:05 +0000
quote
I just looked at the WIKI and it said to put the muffler gasket in with the mesh facing out towards the engine. People here are saying the mesh goes into the muffler. Oy Vey I'm confused.
![]() Sun, 11 May 2014 14:32:43 +0000
Posts: 22186 Location: Harriman, Tennessee, Tn |
quote
mvtroiano wrote: I just looked at the WIKI and it said to put the muffler gasket in with the mesh facing out towards the engine. People here are saying the mesh goes into the muffler. Oy Vey I'm confused. |
Sun, 11 May 2014 15:24:13 +0000
quote
mvtroiano wrote: I just looked at the WIKI and it said to put the muffler gasket in with the mesh facing out towards the engine. People here are saying the mesh goes into the muffler. Oy Vey I'm confused. I'll alter the Wiki. ... Wiki annotated. |
![]() Wed, 30 Dec 2015 01:46:25 +0000
MP3 500
Posts: 270 Location: Columbus OH USA |
![]() MP3 500
quote
Just had another graphite ring blow out. Both times they cracked after riding through water. I'm tempted to use some muffler repair tape to build up the area in front of the graphite ring to protect it from getting wet and blowing out again. Does this sound reasonable?
![]() Kymco AK550
Wed, 30 Dec 2015 09:02:32 +0000
quote
[quote="Buckeye Marksman"]Just had another graphite ring blow out. Both times they cracked after riding through water. I'm tempted to use some muffler repair tape to build up the area in front of the graphite ring to protect it from getting wet and blowing out again. Does this sound reasonable?
[quote] That's puzzling. I've been through several floods and even forded a stream without this happening. Once assembled very little of the collar should be exposed and it should all be clamped up tight. Are you sure that you are inserting it fully in to the silencer? I can only repeat my suggestion that you should use copious amounts of Coppa-slip or similar non-setting copper grease. Put the grease under the clamp and on the screw thread as well. It all helps get a snug fit for a given amount of torque on the clamp. |
![]() Wed, 30 Dec 2015 14:08:40 +0000
MP3 500
![]() MP3 500
quote
roadster wrote: Buckeye Marksman wrote: Just had another graphite ring blow out. Both times they cracked after riding through water. I'm tempted to use some muffler repair tape to build up the area in front of the graphite ring to protect it from getting wet and blowing out again. Does this sound reasonable? |
![]() Wed, 30 Dec 2015 23:28:37 +0000
quote
I never have to replace that exhaust gasket.
just do a AK upgrade. its lighter and sounds better, easier to take off than stock when doing tires and servicing. |
![]() 2016 MP3/500 Sport ABS, 2009 MP3/250, 2012 GTS Super 300ie
Posts: 4296 Location: Marietta, GA |
Thu, 31 Dec 2015 14:53:03 +0000
quote
The first thing I did when I got my New 2016 Home from the Dealer was take that 80 pound weight off the bike for one of these. I love the sound as I don't have any DB Killers Installed, and no gasket to deal with...
https://scooterpartsco.com/piaggio-parts/piaggio-mp3-500-parts/leo-vince-sbk-nero-slip-on-for-piaggio-mp3-400-500?zenid=tkv5pfuahsqsve3u7u7mo1epf1 ![]() |
![]() Thu, 31 Dec 2015 15:54:34 +0000
Posts: 7296 Location: Madison, Wisconsin |
![]() MP3 500, GTS 250 (both 2008 MY), 2013 Piaggio BV 350, 2014 Can Am Spyder RT
quote
23,000 miles on my MP3, taken the muffler off three times I think (maybe four), and still on the original graphite gasket. Got a spare handy, though.
I forget which way I insert the gasket... I want to say I insert it into the muffler, but with the mesh facing out so as not to be damaged by the four wings of the muffler when it is compressed, and wiggles around. I guess I hadn't thought about the end of the downpipe digging in. |
2007 MP3 250(retired) C650GT
Posts: 708 Location: Fredericksburg, VA |
Thu, 31 Dec 2015 19:25:57 +0000
quote
Still had original gasket after 4 tire changes and one brake change. I was the only one to remove the muffler, and was careful. I suspect that dealer mechanics could care less about the poor old gasket. Happy New Year everyone!
Posts: 941 Location: tampa |
Wed, 13 Nov 2019 18:10:35 +0000
quote
there seems to be several styles of gaskets that yamaha sold
this one seems like it would hold up the best. its made of copper. with what looks like asbestos for soft seal. cost to make them must have been higher. 2G2-14714-00 full graphite 3YF-14714-00 3YF-14714-00-00 |
![]() 2008 MP3 500, 2013 BV350, 2020 Vespa Sei Giorni, 2008 Vespa S150
Posts: 8886 Location: Ashburn, Va. Home to the Internet |
Wed, 13 Nov 2019 19:32:51 +0000
quote
Guarantee there is no asbestos if it is sold in the US.
You want the graphite bushing as it lets the pipe slide in and out. |
Wed, 13 Nov 2019 20:14:31 +0000
quote
you do understand what "looks like" means? maybe not.
whatever it is it is there so it can slide. and copper if far more durable and heat resistant to steel wire mesh. so the more intelligent shoppers may see it as a better buy.
Negative
![]() Wed, 13 Nov 2019 23:59:14 +0000
quote
jerryd wrote: you do understand what "looks like" means? maybe not. whatever it is it is there so it can slide. and copper if far more durable and heat resistant to steel wire mesh. so the more intelligent shoppers may see it as a better buy. So I guess I'm not so intelligent, huh? |
Thu, 14 Nov 2019 20:56:32 +0000
quote
There have been several reports on this forum of the downpipe cracking when a brass gasket has been used.
Graphite is a wonderful lubricant - that's why the joint can move even when firmly clamped up so no exhaust gas can escape. |
