my x9 manual says like@ 8000 miles, should'nt they last longer?
never had any problems so far and never rode a scoot that had them in need of changing, what will the scooter act like when this happens?
![]() Sat, 12 Nov 2005 06:01:43 +0000
Posts: 1139 Location: Whittier, CA |
![]() Joined: Thu, 10 Nov 2005 23:42:08 +0000
quote
never had any problems so far and never rode a scoot that had them in need of changing, what will the scooter act like when this happens? |
![]() Consume Less & Share More
Posts: 3130 Location: New Jersey, USA |
Sat, 12 Nov 2005 12:14:27 +0000
quote
Variator rollers are consumable items. The rollers have had a long and hard life at 8,000 miles of service. Although its possible your scoot seems to be okay, CVT performance has been compromised over the rollers lifetime. Its prudent to replace the rollers. They're inexpensive (around $25 per set), and not hard to replace.
![]() Nazgul
Posts: 1985 Location: North Chesterfield, VA |
Sat, 12 Nov 2005 20:02:28 +0000
quote
At 6000+ miles one of my GT's rollers had developed a flat spot.
Posts: 14201 Location: The state of insanity, SoCal |
Sun, 13 Nov 2005 04:24:53 +0000
quote
Re: Roller weights, when to change
ramrezz425 wrote: my x9 manual says like@ 8000 miles, should'nt they last longer? never had any problems so far and never rode a scoot that had them in need of changing, what will the scooter act like when this happens? when the rollers go you get a shuddering at take off and in the lower rpm range. best, -greasy |
Sun, 13 Nov 2005 04:26:05 +0000
quote
jrsjr wrote: At 6000+ miles one of my GT's rollers had developed a flat spot. usually you'll see flat spots starting to develope anywhere between 2800~3500. best, -greasy |
![]() Sun, 13 Nov 2005 05:10:28 +0000
quote
i do alot of highway driving, is threre any difference in roller life from driving alot of stop and go driving?
greasy125 wrote: jrsjr wrote: At 6000+ miles one of my GT's rollers had developed a flat spot. usually you'll see flat spots starting to develope anywhere between 2800~3500. best, -greasy |
![]() Black '06 Piaggio BV500; Black '05 Vespa GT200 (sold)
Posts: 350 Location: Flushing, NY |
Sun, 13 Nov 2005 05:13:26 +0000
quote
greasy125 wrote: when the rollers go you get a shuddering at take off and in the lower rpm range. greasy125 wrote: usually you'll see flat spots starting to develop anywhere between 2800~3500. It's been working fine since then (though it's only been a week). |
Sun, 13 Nov 2005 19:13:34 +0000
quote
Oooookay. This would probably explain why I noticed a shuddering when accelerating from a standstill on my ET4. (It seems to diminish after the scooter is warmed up and on the road for a while, though.) Started about a month or so ago. I have a little over 4,000 miles on it.
Otherwise, everything seems to be working fine. With the colder weather arriving, this would be a good time to teach myself a bit more about do-it-yourself scooter maintenance. Is there a blow-by-blow description of how to do replace the rollers anywhere? |
Mon, 14 Nov 2005 16:12:08 +0000
quote
the GT200 shop manual gives you the specifications for the min roller diameter. You measure them with calipers and replace if they have reached minimum diameter. I pulled mine at 8,000 miles and they were well within the tolerance level. I drive mostly highway though, with very little stop and go. I plan on replacing them regardless at my next service at 12,000.
![]() Nazgul
Mon, 14 Nov 2005 16:15:39 +0000
quote
ataritron wrote: the GT200 shop manual gives you the specifications for the min roller diameter. You measure them with calipers and replace if they have reached minimum diameter. I pulled mine at 8,000 miles and they were well within the tolerance level. I drive mostly highway though, with very little stop and go. I plan on replacing them regardless at my next service at 12,000. |
