Sat Jun 07, 2008 6:17 pm
Sat Jun 07, 2008 6:17 pm linkquote
Created article Loud Turn Signals Save Lives
Mon Jun 09, 2008 4:44 pm
Destroyer of Worlds
LML Star 125, Vespa GT200
Destroyer of Worlds
Mon Jun 09, 2008 4:44 pm linkquote
I connected mine in parallel with the pilot lamp (in the headset). The buzzer itself hangs by the wires outside the headset top. It's hard to hear over wind noise (through earplugs) at top speed, but around town it's more than adequate.
Sun Sep 13, 2009 2:36 pm
ET4
ET4
Sun Sep 13, 2009 2:36 pm linkquote
Buzzers!
Fabulous. Works like a charm. Didn't cut and splice at all, the wires connected right to the signal lights nicely.
⬆️    About 3 years elapsed between posts    ⬇️
Thu Jan 17, 2013 1:26 am
GT 200L 2005
GT 200L 2005
Thu Jan 17, 2013 1:26 am linkquote
Thank you for this....
yes thanks for this- will have a crack at doing it as the panel flash lights are very dim on my GT200 and i like the beeping on my mate's LML (the right one on the dash doesn't even flash or go on- so next will be to figure out how to get that working too so it flashes- and beeps ) Don't fancy going over a car bonnet again 8)
Wed Dec 25, 2013 4:20 pm
LX150
LX150
Wed Dec 25, 2013 4:20 pm linkquote
As cheap as the piezo buzzers are at Radio Shack, instead of any complicated wiring, why not just use 2 buzzers, one for left and one for right?
Cary
Fri Dec 27, 2013 9:48 am
Fri Dec 27, 2013 9:48 am linkquote
If you have two buzzers without diodes, you can't used the brakelight switch output as the buzzers' grounding point, as one or both of the buzzers would be on all the time. If you're going to add diodes to allow this, why use two buzzers in the first place?
Why use the brakelight output as the grounding point? Simples, even with the turn signal on, the buzzers go silent when the brake lights are on, which saves considerable annoyance both to the rider and passers-by when waiting at traffic lights etc. It also performs the useful check that each brake light switch is working, and that the brake light bulb(s) are functional.
Sun May 28, 2017 5:32 pm
2015 Sprint 150ABS
2015 Sprint 150ABS
Sun May 28, 2017 5:32 pm linkquote
Where are parts available!
Any suggestions on where to get parts now that Radio Shack is gone?
Mon May 29, 2017 2:13 am
Mon May 29, 2017 2:13 am linkquote
Frys for a walk-in shop, or any online electronic component supplier such as RS or Farnell. e.g.:
http://www.alliedelec.com/icc-intervox-brp4016l-12-cp/70115793/
http://www.alliedelec.com/hvca-1n4001/70015967/
Fri Jul 10, 2020 8:41 am
2018 Sprint 150
2018 Sprint 150
Fri Jul 10, 2020 8:41 am linkquote
Another alternative for those of us with an unused antitheft device plug is to wire the buzzer into to the mating cap. On my 2018 Sprint 150 that's a TE AMP Multilock .070 8-position cap; the part number is 174931. I got mine from Digikey. The part number for the pins to crimp to the wires is 345210-1.
You can then slip this onto the antitheft plug and the job is done. Easily removed if you or a future owner decide you don't want it anymore.
The antitheft plug does not offer a convenient way to wire the buzzer into the brake light as jimc recommends, however.
[ Time: 0.0314s ][ Queries: 5 (0.0111s) ][ Debug on ][ 209 ][ Thing One ]
