Sat, 12 Mar 2016 03:46:19 +0000
Lambretta GP200, Vespa P200e
Sat, 12 Mar 2016 03:46:19 +0000 quote
The problem with this type of conversion is easier to do with a lambretta due to centralized location of motor. Then you have issue of Vespa being a monocoque body/frame design. Even then it's not a plug and play solution.
Sat, 12 Mar 2016 12:47:40 +0000
Sat, 12 Mar 2016 12:47:40 +0000 quote
I'm sure it won't be long till someone is building and selling complete engines using the Pinasco case as a base. I think there is a place for a blueprinted/rubber stamped combination of OEM and aftermarket parts, all buttoned together by people with the correct skills and workshop equipment.
The problem with kits, cranks, exhausts, carbs, gearing etc. is that you never truly know what you're going to end up with. SIP attempts to partially address this with their touring and sports combination kits, but even then, you might be starting with compromised cases, sub-standard sealing pads and varying type, quality and condition of bearings and seals.
I can build a good engine over time, but being able to buy an off-the-shelf engine that is built for touring or street racing, with 18bhp, 24bhp or 30bhp (examples) has a certain appeal. Throw in a power (but not speed) guarantee, a warranty, and after sales service and it has some real appeal for those people that just want to ride. Owners of brand new PX125s in the UK spring to mind.
Sat, 12 Mar 2016 14:14:20 +0000
Sat, 12 Mar 2016 14:14:20 +0000 quote
That's actually a great idea. Just like Rimini Lambretta Center is selling complete SS200/225 motors ready to go - plug and play
Sun, 13 Mar 2016 00:50:15 +0000
Sun, 13 Mar 2016 00:50:15 +0000 quote
Even the Pinasco case has it's problems - which should not happen with a brand new case. Apparently on the rotary cases the clearance from the crank to the rotary pad is twice what the Piaggio or Malossi cases are.
Also they left out the o-ring groove for the kick start... maybe these things will be fixed in subsequent productions.
Yes I'm sure there would be a market for complete engines. Difficult to guarantee them as there's no telling if they would be run in correctly or run with the right jets, fuel or oil. But at least things could be optimised properly... not many of us have the cash to go through all the combinations of parts until it's perfect.
Just thought - S&S have their engine configurator and sell you the kit of parts. That's probably as close as it gets.
Mon, 28 Mar 2016 17:43:14 +0000
Mon, 28 Mar 2016 17:43:14 +0000 quote
Ginch wrote:
Can an Italian reader here please translate what they are saying? I think maybe it's a less expensive version? Cast instead of CNC?
https://www.facebook.com/bsgcorse.it/posts/961788540571262
Here is the answer
https://www.facebook.com/bsgcorse.it/posts/988820511201398
Mon, 28 Mar 2016 20:05:51 +0000
Mon, 28 Mar 2016 20:05:51 +0000 quote
The BSG Corse stuff is very special, but too far removed from a 'proper' Vespa engine for my liking. I know it's precision engineered, very powerful, very imaginative and all that, but the quirks, the unknowns, the often limited budgets and the risks associated with making an old Vespa go fast(er) are all part of the challenge and the fun.
Tue, 29 Mar 2016 01:50:51 +0000
Tue, 29 Mar 2016 01:50:51 +0000 quote
Here is the answer
Sweet! Look how chunky the transfer area is. It'll be interesting to see what price they come in at.
Swa45, I see what you're saying but it's hard not to be overwhelmed by the promise of more power...
Tue, 29 Mar 2016 02:34:57 +0000
Tue, 29 Mar 2016 02:34:57 +0000 quote
Supposed to be affordable like the new Casa Case for Lambretta with big ass spigot area and bullet 305 ready. And price on that is supposed to be silly cheap below £500.
I've been riding scorer with tuned motors 30 plus years. The only way to fly.
Always nice to have power at your disposal.
Tue, 29 Mar 2016 17:44:32 +0000
Tuk Tuk.
Tuk Tuk.
Tue, 29 Mar 2016 17:44:32 +0000 quote
if they can get this far with a standard PX fit, why not ad a VB1 fit?
and an aluminum x magnesium alloy is the standard for high heat.
Tue, 29 Mar 2016 18:31:50 +0000
Tue, 29 Mar 2016 18:31:50 +0000 quote
PX & VB1 cases nearly identical in size. The size of 305 cylinder is gonna get in way of things along with intake setup. I wouldnt waste time, money and energy putting into a VB1 period.
Tue, 29 Mar 2016 20:55:39 +0000
Tue, 29 Mar 2016 20:55:39 +0000 quote
Yep. You can go just as slow with 20hp as you can with 3 if you want to!
Sun, 03 Apr 2016 15:19:46 +0000
Allstate 1963
Allstate 1963
Sun, 03 Apr 2016 15:19:46 +0000 quote
Translation for you my friend
We are yet to decide to start casting. We have lined up suppliers. We have all the drawings.
We have casted some PX crankcases with the aluminum we had.
Keeping in mind the need of 70 Kg of aluminum per set this process is quite expensive.
The cases you see in the photos have all been fitted with commercially available kit for PX 125/150 and (by relocating the holes) PX 200; 30-62-16 bearings, external seals, 60 crankshaft, 110 piston rod with 55mm wide shoulders and 102mm flywheel.
Alternatively we can fit our 305cc kit, 64 crankshaft with a 78mm piston and a top quality 68mm reed valve (goodbye SI).
The motor as well as the carburetor (VHSB) seats under the belly.
What are your thoughts?
Should we start casting a few sets?
Sun, 03 Apr 2016 21:58:41 +0000
Sun, 03 Apr 2016 21:58:41 +0000 quote
Fabio, you're a star! Don't know why I didn't think of you sooner... cheers for that!
Sun, 03 Apr 2016 23:04:50 +0000
Allstate 1963
Allstate 1963
Sun, 03 Apr 2016 23:04:50 +0000 quote
Always a pleasure mate.
Sat, 23 Dec 2017 03:30:07 +0000
Sat, 23 Dec 2017 03:30:07 +0000 quote
I've just read some comments on Facebook saying that BSG (now BFA Motori) ended up selling only 6 of the 305 motors and are not going to do any more. Not sure if that's correct.
Sat, 23 Dec 2017 07:29:51 +0000
Sat, 23 Dec 2017 07:29:51 +0000 quote
I don't think it's true. They stopped making cnc cases and started casting them to drop the costs down. Check their latest photos...
Tue, 02 Jan 2018 00:11:29 +0000
Tue, 02 Jan 2018 00:43:08 +0000
parallelogramerist
parallelogramerist
Tue, 02 Jan 2018 00:43:08 +0000 quote
All that tech is super cool...but come on, no 5 (reliable) speed yet? All that time, trouble, and money going into making those cases and no 5 speed? I would have hoped that BFA and DRT could have gotten together to make it happen. Or maybe a 5 speed isn't really needed because the engine has enough torque making a close ratio transmission not needed?
Tue, 02 Jan 2018 01:43:22 +0000
Tue, 02 Jan 2018 01:43:22 +0000 quote
Cheers Safis! I was quoted £9000 for a complete motor with Parmakit ignition and (I assume) carb - it was described as "plug & play".
This does seem like the logical answer. Also if they were building it to only fit into these cases, there would be no cost advantage from bigger production runs. A (reliable) 5 speed setup that could fit into standard cases you would have to think would sell very well... maybe one day!
The intake is nice... right at the base of the cylinder, with no crank to get in the way.
Oh, and I noticed the price on the Malossi cases, wonder if this is a mistake? Seems incredibly expensive for basically standard cases!
https://www.sip-scootershop.com/en/products/crankcase+malossi+standard_57144930
⬆️    About 23w elapsed between posts    ⬇️
Sat, 09 Jun 2018 02:53:07 +0000
Sat, 09 Jun 2018 02:53:07 +0000 quote
Today I saw this motor being advertised. 7555 euro for delivery outside of the EU.
https://www.vespmoto.de/bfa-motori-306/english/
The thing that grabbed my attention was this video. The thing sounds like it's hardly working at all!
https://youtu.be/g7DzSJwJuo0
Sat, 09 Jun 2018 07:28:47 +0000
'74 Rally, '72 Sprint
Sat, 09 Jun 2018 07:28:47 +0000 quote
Did you put down your deposit??
Sat, 09 Jun 2018 07:46:23 +0000
Sat, 09 Jun 2018 07:46:23 +0000 quote
It's down the back of the couch!
Sat, 09 Jun 2018 10:54:54 +0000
Sat, 09 Jun 2018 10:54:54 +0000 quote
At the beginning of the video, I was a little, "Meh, this isn't all that impressive."
When he shifted from 3rd up to 4th at about 30 seconds was when my jaw dropped.
Sat, 09 Jun 2018 14:12:47 +0000
Sat, 09 Jun 2018 14:12:47 +0000 quote
"V-max at this setup about > 160 km/h"
Sun, 10 Jun 2018 02:00:41 +0000
Sun, 10 Jun 2018 02:00:41 +0000 quote
Yeah that thing sounds like it's hardly trying. And I don't want to do 160 but just knowing you could, that would be really something.
Check out his site, the Quattrini 260 (!) is half the price and almost as quick.
Wed, 13 Jun 2018 12:47:47 +0000
Wed, 13 Jun 2018 12:47:47 +0000 quote
Finished saving?
Has anyone (most likely a single person) saved enough yet to to buy one of these?
Wed, 13 Jun 2018 14:02:16 +0000
GS160
GS160
Wed, 13 Jun 2018 14:02:16 +0000 quote
Yeah, some owner's reviews would be nice. How long does the crucifiorm last..?
Wed, 13 Jun 2018 14:44:13 +0000
Wed, 13 Jun 2018 14:44:13 +0000 quote
In miles or minutes?
Fri, 09 Oct 2020 02:10:53 +0000
Fri, 09 Oct 2020 02:10:53 +0000 quote
BFA 244.
No it's not a 306, but should be way more affordable and no doubt go like stink. What I find impressive is the solution to tiny (compared to motorcycle) transfers with an adaptor plate that changes stud location. Loving the port layout.
It's for a standard 200 case and uses a 127mm rod.
Fri, 09 Oct 2020 10:31:00 +0000
Fri, 09 Oct 2020 10:31:00 +0000 quote
So this is all about getting the exhaust port wider and/or auxiliary ports added with a stock 200 case, and getting that extra 10-15 hp that Jack always refers to, in order to go beyond the max ~40hp that is achievable with a highly tuned MHR setup?
How would this compare to a Quattrini 260 setup, which uses a 64mm stroke and 127mm rod? I guess this is still limited to the stock 200 stud spacing?
Fri, 09 Oct 2020 10:38:58 +0000
Fri, 09 Oct 2020 10:38:58 +0000 quote
Not really. The adaptor plate is bolted to the cases, and the cylinder is bolted to the adaptor plate... so in theory, the cylinder studs/bolts can go wherever they want to put them.
You would have to think that this will produce a lot more hp than the Quattrini because the porting design is much more aggressive for a start. Also the Q was designed as a tourer with fairly mild timings I believe. Whereas the BFA 306's "stock" exhaust is an expansion chamber. Think that says something about their design intent.
We'll have to wait for a while to see actual numbers, but I imagine this is going to be a good 20% more powerful than the Quattrini.
Fri, 09 Oct 2020 10:55:47 +0000
2012 GTV 300, 2005 Genuine Stella w/ hack, 1974 Rally 200
Fri, 09 Oct 2020 10:55:47 +0000 quote
My 306 is currently being built.
Fri, 09 Oct 2020 10:59:39 +0000
Fri, 09 Oct 2020 10:59:39 +0000 quote
Thanks Ginch. Sorry, I was referring to the Quattrini being limited to the stock stud spacing.
Fri, 09 Oct 2020 14:20:53 +0000
Fri, 09 Oct 2020 14:20:53 +0000 quote
Looks like someone at BFA reads our forum.
Remember this thread? Cylinder Stud Patterns from 2 years ago?
If someone would just make a P200 cylinder that had short base studs like a small frame 50. Then the cylinder could be anything you wanted it to be. No limits. Not sure the rest of the scooter could handle it though.
Certainly looks like they actually made it. When can I buy one?
Sat, 10 Oct 2020 01:45:02 +0000
Sat, 10 Oct 2020 01:45:02 +0000 quote
swa45 wrote:
How would this compare to a Quattrini 260 setup?
Yeah think I mistook your point! At Vespmoto (who sells complete motors) he's saying the 260 has around 31hp using a PipeDesign box, and that the 306 has about 46 using his own box exhaust.
So for this new 244, that has very similar looking aggressive porting to the 306 (but is a little more restricted in the case transfer area compared to the 306), you'd have to think it would put it in the high 30's at least? And more with an expansion.
They've done that with the 306 but not this new cylinder Jack. Not that it will hold them back I think!
Nice! Are you building it yourself?
Sat, 10 Oct 2020 06:50:24 +0000
Sat, 10 Oct 2020 06:50:24 +0000 quote
Made more sense reading our whole thread. Getting away from the stock 200 stud pattern was the point.
Don't get too hung up on the base transfer size. It's always the exhaust port that's the issue but that's fixed on this.
If this BFA244 becomes widely available it could easily be the most powerful for the stock cases.
Sat, 10 Oct 2020 07:00:29 +0000
Sat, 10 Oct 2020 07:00:29 +0000 quote
No I get what you mean, it's not the separately bolted base flange that's important, it's the pattern itself. Which as you say is fixed.
There's certainly no reason it won't be widely available as SIP are their manufacturer/sales partner now. It's only cost that will hold us back... the Quattrini cylinder at SIP is 576 euro, and the BFA 225 (probably the closest comparison currently) is 1162 euro.
Sat, 10 Oct 2020 14:02:53 +0000
Sat, 10 Oct 2020 14:02:53 +0000 quote
Someone should make that adapter plate to put a Malossi 210 on the smaller 150 case. I wonder how it would run. It wouldn't be perfect but you could port the 150 case out a reasonable amount and get better air flow than a factory 200.
Sat, 10 Oct 2020 14:55:24 +0000
Sat, 10 Oct 2020 14:55:24 +0000 quote
Sun, 11 Oct 2020 00:42:52 +0000
Sun, 11 Oct 2020 00:42:52 +0000 quote
Been done, but not on the market yet I believe. At least, an adapter plate is the only way I can imagine it would work given the clues he's dropped.
https://scooterlab.uk/jg-vespa-200-cylinder-conversion-for-the-px125-feature/
200 cylinder for 150 case
[ Time: 0.0698s ][ Queries: 6 (0.0435s) ][ Debug on ][ 283 ][ Thing Two ]
