Gts 300
Thu, 11 Jan 2018 22:47:44 +0000
quote
Will post more pics as i progress. Fitted plenty into scomadi's but first time in a lammy.
![]() 2005 et4
Posts: 508 Location: oshawa ontario canada |
![]() Mon, 15 Jan 2018 02:35:35 +0000
GTS 150 3Vie, '95 Excel, LX 150 3Vie
Posts: 31 Location: Indonesia |
![]() GTS 150 3Vie, '95 Excel, LX 150 3Vie
quote
lambretta body? this is gonna be interesting. im waiting for the next progress
Vespa Sprint 150
Posts: 24 Location: Santa Clara, CA |
Mon, 15 Jan 2018 03:33:48 +0000
quote
Interesting project. Can't wait to see how this will work out. Goodluck bro.
![]() 2005 et4
Wed, 31 Jan 2018 16:59:10 +0000
quote
A bit more done, ive got another project on the go for a couple of weeks , so be back on it when thats done
![]() Progress |
Wed, 31 Jan 2018 19:12:14 +0000
skipper st125
Posts: 53 Location: York,uk |
skipper st125
quote
Nice project.
I am looking at trying to fit a gt engine or lx engine into an ld frame. Do you have any pictures of the engine mounting fabrication. Have you widened and extended the front forks to accept the gts wheel? It looks like you have widened the frame loop slightly to accept the engine. What do you plan to do with the radiators? Robbie |
GTS 250,P-200,Rally-200,Honda CB160,Ninja Rabbit
Posts: 41 Location: Campbell, CA |
Thu, 01 Feb 2018 06:51:42 +0000
quote
Wow! This is my kind of project. Looks great so far. Can't wait to see more. Thanks for sharing.
scooterless
Posts: 2085 Location: Googleville |
![]() Sun, 18 Feb 2018 05:24:55 +0000
Stella, GTS 300, Vespa p200e
Posts: 147 Location: Portland usa |
![]() Stella, GTS 300, Vespa p200e
Tue, 20 Feb 2018 17:37:59 +0000
quote
wreckless robbie
i have widened he forks to take a gillera runner wheel and anti dive brake system, it has a gillera runner wheel on the rear too, radiator will be under the floor in a scoop. same way i do the gts to scomadi conversion.
![]() Rad goes in here |
Sun, 04 Mar 2018 15:50:24 +0000
quote
Rad fitted
piaggio runner 180 rad fitted piped up and bled, works very well.
![]() Sun, 04 Mar 2018 19:12:58 +0000
Posts: 3406 Location: pacifica,ca. |
![]() Joined: Fri, 14 Jul 2006 04:04:00 +0000
![]() 2023 Arancia Impulsivo Vespa GTS300 HPE , 2022 BMW R1250GSA 40th Anniversary, 2019 Ural Gear Up
Posts: 8508 Location: Toronto |
![]() 74 Super, 75 Super, PX project, LML off-roader and '66 Blue Badge Smallframe
Posts: 8375 Location: Victoria, Australia |
Sun, 04 Mar 2018 21:00:41 +0000
quote
Re: wreckless robbie
tige wrote: ...radiator will be under the floor in a scoop. same way i do the gts to scomadi conversion. Does the fan suck or blow? Does it turn on with the thermostat or run all the time? Great project! |
Tue, 06 Mar 2018 01:36:58 +0000
quote
reply
i have fitted a front mud guard to stop stones and mud, And the fan works with the sensor as it does on the gts, other than reverse wire so it sucks. the method works very well, I use the same one on scomadi to gts conversions.
Vespa Sprint 150
Mon, 12 Mar 2018 11:33:19 +0000
quote
close to completion.
Just the brake holding cones to do and then the head set and final wiring to finish.
Positive
GTS250
Posts: 507 Location: Trowbridge - England |
scooterless
![]() Mon, 26 Mar 2018 19:47:57 +0000
2003 ET4, 2005 LX 150, 1964 GS 160
Posts: 1508 Location: Maui Hawaii |
![]() 2003 ET4, 2005 LX 150, 1964 GS 160
Mon, 26 Mar 2018 20:23:02 +0000
quote
paint
going to match the paint and touch in the grey primer, the rest is staying as it for a while at least.
Vespa GTS 250ie
Posts: 1229 Location: San Francisco Bay Area |
Vespa GTS 250
Posts: 92 Location: Atlanta |
Fri, 06 Apr 2018 17:21:08 +0000
quote
MOD
WOW! Can you find a front wheel that looks more retro?
That's a great looking scooter. |
Fri, 06 Apr 2018 17:54:16 +0000
quote
front wheel
Not really but maybe at some point make a cover that bolts through the spokes , the rear wheel is 13 so the front needs to be, It one of the things you have to sacrifice in the process of bring new to old.
Tue, 24 Apr 2018 05:33:28 +0000
quote
All finished.
All finished and gone to its new owner, will be run as is for now to make sure there are no problems or niggles.
![]() finished pic |
Vespa GTS 250
Wed, 25 Apr 2018 14:18:07 +0000
quote
Finished? No report on run condition ride etc? More pictures? Sold?
Thu, 26 Apr 2018 06:07:33 +0000
quote
report
I built it for a client, Not for my self, i only tried it for a short run ,And it rode very well, but i will come back with information i receive from him,and updates on seat choice etc. The engine was checked on my diagnostic before it was collected,and all was good, The better test will be when it goes on some road runs, Like i say i will come back with info.
Sat, 16 Feb 2019 06:54:48 +0000
quote
No.2
After building the lambretta series 2 fitted with a gts 300 engine last year, i got asked to do another,This time for a nice chap who only had one arm,His left. so that in its self added challenges to the this build i had not faced in the previous one, but i got there in the end,
![]() second one
Positive
Sat, 16 Feb 2019 07:01:02 +0000
quote
rear hydraulic foot brake
used the gts rads , With a hydraulic foot brake. i had to make the grp air scoop wider,And baffle any air routes other than through the rads, This build also has a left hand throttle & front brake.
Wed, 20 Feb 2019 20:53:33 +0000
skipper st125
skipper st125
quote
Your work is outstanding.
Looking at the silver one..the rear end sits up high. I realise its on its stand. Is it not possible to use shorter shock absorbers..or is the wheel size the problem. Robbie |
Thu, 21 Feb 2019 08:09:00 +0000
quote
sits up high
its sits perfect when its off the stand, all gts stands throw the rear up when on them, when its sat on its own weight ,Its bob on.
Fri, 22 Feb 2019 10:00:56 +0000
skipper st125
skipper st125
quote
My comment was definitely not meant as a criticism.
As i said before i think your work is excellent and the scooters look very well done. Robbie |
