Wed Mar 14, 2018 8:09 am
Vespa PX200/Bajaj Chetak/GS150 VS5
Wed Mar 14, 2018 8:09 am linkquote
Hi,
Does anyone have a tried and tested setup for an iron Pinasco 177 with Si 20/20 carb, standard 57mm crank and SIP road2 exhaust?
Thu Mar 22, 2018 11:42 am
VLB1T
VLB1T
Thu Mar 22, 2018 11:42 am linkquote
So far, this has worked for me
Hi Rogscoot,
Full disclosure, I had a trusted mechanic dial my bike in. I didn't test and try these jets myself. That being said, I am very happy with the result.
Pinasco 177 2-port kit
(Standard crank)
Timing 20 degrees
SIP fast flow tap 2.0
SIP Road 2.0
Carb. SI 20/20
Idle jet: 55-160
Air corrector: 160
Mixer: BE3
Main jet: 108
Plug NGK B8HS (as recommended by Pinasco)
Altitude 46 feet.
I'm still breaking the cylinder in. Mixture is 2.5%. Plug looks dry black.
So far, no hiccups.
Good luck!
Fri Mar 23, 2018 5:31 am
Fri Mar 23, 2018 5:31 am linkquote
Thank you very much rustyandtrusty, that's a ball park for me to work to and is roughly what I was going to start with as a jetting baseline.
I'll let you know how I get on
Fri Mar 23, 2018 1:01 pm
Fri Mar 23, 2018 1:01 pm linkquote
I don't recall the exact jetting off the top of my head, but I had to run a BE1 atomizer with my 2-port 177 and I think a 112 main.
Thu Jun 23, 2022 2:53 pm
'64 VBB, '74 BMW 750, Bultaco Alpina 250, Lambrettas
Thu Jun 23, 2022 2:53 pm linkquote
I'll use this useful old thread even tho its's a few years old -- the kit's still the same...
Pinasco's terse instructions say that if you're upjetting a SI 20/20 carb, one needs to drill a 5mm hole in the heart section below which the main jet stack sits. Is this required?
Just want to confirm that it's necessary before I modify this original air filter. Have folks successfully done this, and how were your results?
Btw, I'm installing the iron cylinder Pinasco 177 kit on a '64 VBB2 motor I just rebuilt. I've got a dell'orto 20/20D carb and exhaust is a Malossi Power Classic (big box type).
For jets I have on hand a 106 and a 110 at the moment, plus lower increments. Might pick up a 108 also. Thanks
[ Time: 0.0329s ][ Queries: 7 (0.0117s) ][ Debug on ][ 211 ][ Thing One ]
