Fri Nov 11, 2005 10:01 pm
Fri Nov 11, 2005 10:01 pm linkquote
my x9 manual says like@ 8000 miles, should'nt they last longer?
never had any problems so far and never rode a scoot that had them in need of changing, what will the scooter act like when this happens?
Sat Nov 12, 2005 4:14 am
Consume Less & Share More
Sat Nov 12, 2005 4:14 am linkquote
Variator rollers are consumable items. The rollers have had a long and hard life at 8,000 miles of service. Although its possible your scoot seems to be okay, CVT performance has been compromised over the rollers lifetime. Its prudent to replace the rollers. They're inexpensive (around $25 per set), and not hard to replace.
Sat Nov 12, 2005 12:02 pm
Nazgul
Nazgul
Sat Nov 12, 2005 12:02 pm linkquote
At 6000+ miles one of my GT's rollers had developed a flat spot.
Sat Nov 12, 2005 8:24 pm
Sat Nov 12, 2005 8:24 pm linkquote
Re: Roller weights, when to change
you might be able to get 10~12 out of them but given the risk of damaging the variator components with bad rollers i'd opt for the 8K option or just roll it to 10 and do the belt at the same time....
when the rollers go you get a shuddering at take off and in the lower rpm range.
best,
-greasy
Sat Nov 12, 2005 8:26 pm
Sat Nov 12, 2005 8:26 pm linkquote
that's freekin' awesome mileage for a roller!
usually you'll see flat spots starting to develope anywhere between 2800~3500.
best,
-greasy
Sat Nov 12, 2005 9:10 pm
Sat Nov 12, 2005 9:10 pm linkquote
i do alot of highway driving, is threre any difference in roller life from driving alot of stop and go driving?
best,
-greasy
Sat Nov 12, 2005 9:13 pm
Black '06 Piaggio BV500; Black '05 Vespa GT200 (sold)
Sat Nov 12, 2005 9:13 pm linkquote
and:
greasy125 wrote:
usually you'll see flat spots starting to develop anywhere between 2800~3500.
That's exactly what my dealer said was causing my "shudder". That and dust. They cleaned stuff out and said to come back at 6000 for replacement.
It's been working fine since then (though it's only been a week).
Sun Nov 13, 2005 11:13 am
Sun Nov 13, 2005 11:13 am linkquote
Oooookay. This would probably explain why I noticed a shuddering when accelerating from a standstill on my ET4. (It seems to diminish after the scooter is warmed up and on the road for a while, though.) Started about a month or so ago. I have a little over 4,000 miles on it.
Otherwise, everything seems to be working fine.
With the colder weather arriving, this would be a good time to teach myself a bit more about do-it-yourself scooter maintenance.
Is there a blow-by-blow description of how to do replace the rollers anywhere?
Mon Nov 14, 2005 8:12 am
GT200
GT200
Mon Nov 14, 2005 8:12 am linkquote
the GT200 shop manual gives you the specifications for the min roller diameter. You measure them with calipers and replace if they have reached minimum diameter. I pulled mine at 8,000 miles and they were well within the tolerance level. I drive mostly highway though, with very little stop and go. I plan on replacing them regardless at my next service at 12,000.
Mon Nov 14, 2005 8:15 am
Nazgul
Nazgul
Mon Nov 14, 2005 8:15 am linkquote
That's true, but the problem a lot of folks are seeing at fairly low miles is rollers with flat spots, which cause problems and should be replaced.
[ Time: 0.0298s ][ Queries: 5 (0.0081s) ][ Debug on ][ 211 ][ Thing One ]
