![]() LXV 150 3v ie. Midnight Blue (Sold) Now Honda Zoomer X
Posts: 3779 Location: Kingdom of Lanna |
Thu Nov 29, 2018 3:34 am
Posts: 3766 Location: East Anglia, UK |
Mike, digital is always more accurate, but I take the point that it's easier to see the analogue type. Even the digitally driven analogue read-outs are not as accurate as the full digital screen type because of the introduction of a mechanical swing needle to indicate the revs. There is always some lag. We measured this in the workshop and found as much as 1/7th of a second! In engineering terms that's massive and means you can already be in the red zone for you engine before the tacho tells you. No good if it's a racing bike. But probably not important on a road bike.
![]() Thu Nov 29, 2018 3:53 pm
Posts: 8733 Location: Annapolis, MD, USA |
![]() 2007 Vespa LX 190, 2011 LXV150ie
![]() Thu Nov 29, 2018 3:59 pm
Posts: 5641 Location: Home of the Alamo |
![]() '07 LX150 (Sold), '17 GTS300, '16 BV350, '15 EN650, '09 FXDF
Re: Just curious. Analogue or digital tach.?
waspmike wrote: I am concerned that the digits on a digital tach will change too quickly to be useful vs a "conventional" analogue tach. where the graduations are quit close so the real minimum accuracy would be about 250 rpm |
On another forum I frequent there is occasional near-hysteria about the readings of digital temperature gauges which show alarmingly big numbers, but nowhere near the same level of concern about a coolant temperature gauge which occasionally gets near the red.
For a critical measurement (e.g. speed where inattention can gain a speeding ticket) I'd rather have digital; for things where I'm looking for an indication of abnormality, I am happy with an analogue needle. |
![]() 2015 GTS 300 Super (Melody: 2015-2021, RIP) 2022 GTS SuperTech (Thelonica)
Posts: 3604 Location: Asbury Park, NJ |
Being somewhat expert in throwing the proverbial spanner in a thread: I've long wondered about the relevance of a tach on/in any vehicle not possessing a manual transmission, besides possibly sprucing up an otherwise-dull instrument panel (e.g., Le Wife's Honda CR-V). As a reminder that the engine's running? Tell me what I'm missing here.
![]() Thu Nov 29, 2018 11:55 pm
Posts: 1740 Location: Lancaster, U.K. |
![]() GTS 300ie Touring 2013 - Signora D'argento & GTS 300ie HPE 2022 - Regina Arancione.
amateriat wrote: I've long wondered about the relevance of a tach an any vehicle not possessing a manual transmission, Downside is that is might be more difficult to do the tach wiring than fit the weights. But yes I see your point. I don't think I'll ever get to the red line, given the traffic here! On-line shopping sounds eay but as we are finding here most stuff "advertised" is not in stock. The two tachs. $8.50 each i bought from a bricks and mortar motorcycle accessory shop LXV has proper handle bars so easy to mount clamped to the bars. |
![]() Triumph Bonneville 2022, Triumph Street Scrambler 2018 (sold), Suzuki VanVan200 (sold), 2015 Sprint 125 (sold)
Posts: 2855 Location: Finland |
I was just going to ask what you'll use the tach for
For tuning purposes a digital tach with data transfer/recording capability would be super....but maybe a tad extreme just to test different weights. I'll actually challenge the need of a tach also for the bikes with gears, if it's not for racing. If a new to me bike has a tach, I do use it. But only in the beginning to see where the peak torque figures are vs. speed & gears and also how this sounds. When I've learned this, I just play it by the ear and don't watch the tach. I really like the set-up of my current bike: there's an electric tacho meter in a display, that can be switched to show other things too (like the remaining distance with fuel available). So it's there if I'll ever need it, but don't normally use it anymore. |
The linear type of pseudo-analogue tacho is not much use either. The one on a KTM Duke was not readable when moving because it was small and jumped too quickly. You had to change gear using the engine noise as a guide but hitting the rev-limiter in bottom was all too easy.
The one on my present scooter is similar but arranged in a curve of progressively lit LEDs. Less important with CV transmission but it provides some information when cruising at steady speed. Some modern Triumph twins have no tacho whatsoever and this can cause difficulty if preparing to overtake or trying to extract the last ounce of performance during acceleration. I can't see much use for a fully numerical tacho except to check idle speed or cruising steady RPM. If you want to change pulley weights I think a tacho is essential to avoid confusion about the actual effect. |
Fri Nov 30, 2018 1:44 am
Silver Streak wrote: Stromrider wrote: Mike, digital is always more accurate, There are three principle types of digitally driven tacho's, leaving aside the old mechanically driven systems. Optically driven, electromagnetic, and electronic. Some combine elements of all three types, some elements of just two types. All have to take a reading from the crank sensor either electromagnetically, or optically. But anything that introduces a mechanical swing arm at the display to indicate the revs introduces quite some lag on a higher revving bike engine. On racing engines that I developed we used optical whenever possible. Easier and faster, and by far the most accurate. The engines revved out to 17,000rpm +. We displayed this in an analogue format but using an HD digital LCD screen. So no lag! It's the best of both worlds. When using digital with analogue readout, actual anologue readouts often could be out by 1k to 1.2k revs by which time the engine is in the red. Mechanical systems simply can't compete either. Typically they could be 2-3k revs out compared to even the most basic electronic digital system. There is not much built in engine strength redundancy due to lightness of components in most purpose built racing engines. Therefore avoiding the red zone is critical. |
RRider wrote: For tuning purposes a digital tach with data transfer/recording capability would be super....but maybe a tad extreme just to test different weights. i am just curious what the difference will be. Not racing, unless you count my Karting instincts coming to the fore when negotiating slow moving traffic queues. Max speed here only occasionally 80 kph. Most of time squirting between 40 and 60. there is a lot of slow moving traffic on narrow road interspersed with speed bumps. |
waspmike wrote: amateriat wrote: I've long wondered about the relevance of a tach an any vehicle not possessing a manual transmission, Downside is that is might be more difficult to do the tach wiring than fit the weights. But yes I see your point. I don't think I'll ever get to the red line, given the traffic here! On-line shopping sounds eay but as we are finding here most stuff "advertised" is not in stock. The two tachs. $8.50 each i bought from a bricks and mortar motorcycle accessory shop LXV has proper handle bars so easy to mount clamped to the bars. RRider wrote: I was just going to ask what you'll use the tach for For tuning purposes a digital tach with data transfer/recording capability would be super....but maybe a tad extreme just to test different weights. I'll actually challenge the need of a tach also for the bikes with gears, if it's not for racing. If a new to me bike has a tach, I do use it. But only in the beginning to see where the peak torque figures are vs. speed & gears and also how this sounds. When I've learned this, I just play it by the ear and don't watch the tach. I really like the set-up of my current bike: there's an electric tacho meter in a display, that can be switched to show other things too (like the remaining distance with fuel available). So it's there if I'll ever need it, but don't normally use it anymore. |
![]() Sat Dec 01, 2018 11:08 am
Stromrider wrote: Silver Streak wrote: Stromrider wrote: Mike, digital is always more accurate, There are three principle types of digitally driven tacho's, leaving aside the old mechanically driven systems. Optically driven, electromagnetic, and electronic. Some combine elements of all three types, some elements of just two types. All have to take a reading from the crank sensor either electromagnetically, or optically. But anything that introduces a mechanical swing arm at the display to indicate the revs introduces quite some lag on a higher revving bike engine. On racing engines that I developed we used optical whenever possible. Easier and faster, and by far the most accurate. The engines revved out to 17,000rpm +. We displayed this in an analogue format but using an HD digital LCD screen. So no lag! It's the best of both worlds. When using digital with analogue readout, actual anologue readouts often could be out by 1k to 1.2k revs by which time the engine is in the red. Mechanical systems simply can't compete either. Typically they could be 2-3k revs out compared to even the most basic electronic digital system. There is not much built in engine strength redundancy due to lightness of components in most purpose built racing engines. Therefore avoiding the red zone is critical. Sure, the best digital tachs have virtually no latency, but I've seen plenty of cheapos with a very slow display refresh rate that even a mediocre analog tach will beat the pants off. In reality though, for a scooter with a CVT, the only real utility of a tach is for diagnosing problems with the CVT and for tuning the CVT. For those purposes, just about anything will do. Overreving is not really a concern. |
![]() Sat Dec 01, 2018 11:22 am
Posts: 22098 Location: Harriman, Tennessee, Tn |
Mon Dec 03, 2018 9:25 am
Silver Streak wrote: Stromrider wrote: Silver Streak wrote: Stromrider wrote: Mike, digital is always more accurate, There are three principle types of digitally driven tacho's, leaving aside the old mechanically driven systems. Optically driven, electromagnetic, and electronic. Some combine elements of all three types, some elements of just two types. All have to take a reading from the crank sensor either electromagnetically, or optically. But anything that introduces a mechanical swing arm at the display to indicate the revs introduces quite some lag on a higher revving bike engine. On racing engines that I developed we used optical whenever possible. Easier and faster, and by far the most accurate. The engines revved out to 17,000rpm +. We displayed this in an analogue format but using an HD digital LCD screen. So no lag! It's the best of both worlds. When using digital with analogue readout, actual anologue readouts often could be out by 1k to 1.2k revs by which time the engine is in the red. Mechanical systems simply can't compete either. Typically they could be 2-3k revs out compared to even the most basic electronic digital system. There is not much built in engine strength redundancy due to lightness of components in most purpose built racing engines. Therefore avoiding the red zone is critical. Sure, the best digital tachs have virtually no latency, but I've seen plenty of cheapos with a very slow display refresh rate that even a mediocre analog tach will beat the pants off. In reality though, for a scooter with a CVT, the only real utility of a tach is for diagnosing problems with the CVT and for tuning the CVT. For those purposes, just about anything will do. Overreving is not really a concern. |
![]() Mon Dec 03, 2018 9:42 am
GTS 300 Super
Posts: 998 Location: West Sacramento, CA |
![]() Mon Dec 03, 2018 10:26 am
Stromrider wrote: Silver Streak wrote: Stromrider wrote: Silver Streak wrote: Stromrider wrote: Mike, digital is always more accurate, There are three principle types of digitally driven tacho's, leaving aside the old mechanically driven systems. Optically driven, electromagnetic, and electronic. Some combine elements of all three types, some elements of just two types. All have to take a reading from the crank sensor either electromagnetically, or optically. But anything that introduces a mechanical swing arm at the display to indicate the revs introduces quite some lag on a higher revving bike engine. On racing engines that I developed we used optical whenever possible. Easier and faster, and by far the most accurate. The engines revved out to 17,000rpm +. We displayed this in an analogue format but using an HD digital LCD screen. So no lag! It's the best of both worlds. When using digital with analogue readout, actual anologue readouts often could be out by 1k to 1.2k revs by which time the engine is in the red. Mechanical systems simply can't compete either. Typically they could be 2-3k revs out compared to even the most basic electronic digital system. There is not much built in engine strength redundancy due to lightness of components in most purpose built racing engines. Therefore avoiding the red zone is critical. Sure, the best digital tachs have virtually no latency, but I've seen plenty of cheapos with a very slow display refresh rate that even a mediocre analog tach will beat the pants off. In reality though, for a scooter with a CVT, the only real utility of a tach is for diagnosing problems with the CVT and for tuning the CVT. For those purposes, just about anything will do. Overreving is not really a concern. When I am talking about display refresh rates on cheap digital tachs, I'm talking about the type that display actual digits. I have sitting on the bench in my shop right now a cheap Chinese digital tach of this type that I use to tune the CVTs on my scoots. It certainly appears to me to update its display only every 20ms or so. Perfectly adequate for this use, but slow for registering instantaneous over-revving. Regardless, my point in principal is that I don't think your use of the term "always" is defensible. The accuracy of a measuring system is a function of many factors -- including calibration and resolution -- and when it comes to measuring a rapidly varying parameter, it is the overall time constant of the system from sensors to display that is critical, not just the display technology. When it comes to more slowly changing parameters, calibration and resolution are more critical. Our brains seem to be coming at this from different points of view. You appear to be basing your determinations on empirical experience with specific commercial products. Coming from a metrology background, I'm basing mine on the general principals of measurement. |
![]() 2010 PIAGGIO BV 500ie Tourer
Posts: 4644 Location: Lakeshore, ON, CANADA-Capestang,FR |
Mon Dec 03, 2018 1:47 pm
[quote="Silver Streak] our brains seem to be coming at this from different points of view. You appear to be basing your determinations on empirical experience with specific commercial products. Coming from a metrology background, I'm basing mine on the general principals of measurement.[/quote]
No, I've already covered what you are saying. As you say analogue covers different types of tachometer and their displays. Maybe I should have quantified those further at the start of my posts. Please bear in mind my statement in my first post was about accuracy which has two elemenst in this thread. Accuracy of information recorded and information displayed. Digital is always the most accurate. How it's displayed can be another matter. Leaving aside the old mechanically driven analogue systems that are way too slow for modern engines, you are left with digital, or other electronically driven systems. The display can be of an analogue type with either a mechanical pointer needle, or LED/LCD digital readout, or an LCD Portrayal of an analogue display. The latter type was the fastest and most accurate at displaying information for everyday use on high revving engines. And of course, as you rightly say, digital tachos vary in latency as I previously pointed out in other posts. So of course you use the one that's right for the job. Your tacho is clearly right for what you are using it for. But it clearly has latency issues for you, but will be near 100% accurate in the way it records it's information, even if it doesn't display all in totality in the blocks you would wish for. Thats because it uses a simple double cyclic algorithm on a cheap chip. It is very accurate for most road engines in lower powered bikes and better than analogue mechanical systems. Remember, accuracy and latency are in fact different issues as you will know. It's the information display that's important which is the point the OP is querying and that you are pointing out too. I'm saying that all the digital tachos tested by us were near 100% accurate and far far better at displaying that information than plain old analogue tachos and far more accurate than any digitally drivenl mechanical analogue pointer system. Didn't mean to confuse you but I'm quite good at doing that when I'm tired!...lol. |
![]() Tue Dec 04, 2018 6:47 pm
Stromrider wrote: [quote="Silver Streak] our brains seem to be coming at this from different points of view. You appear to be basing your determinations on empirical experience with specific commercial products. Coming from a metrology background, I'm basing mine on the general principals of measurement. Stromrider wrote: No, I've already covered what you are saying. As you say analogue covers different types of tachometer and their displays. Maybe I should have quantified those further at the start of my posts. Please bear in mind my statement in my first post was about accuracy which has two elemenst in this thread. Accuracy of information recorded and information displayed. Digital is always the most accurate. How it's displayed can be another matter. Leaving aside the old mechanically driven analogue systems that are way too slow for modern engines, you are left with digital, or other electronically driven systems. The display can be of an analogue type with either a mechanical pointer needle, or LED/LCD digital readout, or an LCD Portrayal of an analogue display. The latter type was the fastest and most accurate at displaying information for everyday use on high revving engines. And of course, as you rightly say, digital tachos vary in latency as I previously pointed out in other posts. So of course you use the one that's right for the job. Your tacho is clearly right for what you are using it for. But it clearly has latency issues for you, but will be near 100% accurate in the way it records it's information, even if it doesn't display all in totality in the blocks you would wish for. Thats because it uses a simple double cyclic algorithm on a cheap chip. It is very accurate for most road engines in lower powered bikes and better than analogue mechanical systems. Remember, accuracy and latency are in fact different issues as you will know. It's the information display that's important which is the point the OP is querying and that you are pointing out too. I'm saying that all the digital tachos tested by us were near 100% accurate and far far better at displaying that information than plain old analogue tachos and far more accurate than any digitally drivenl mechanical analogue pointer system. Didn't mean to confuse you but I'm quite good at doing that when I'm tired!...lol. My point: There is no justification for your statement that digital tachs are ALWAYS more accurate than analog tachs. Your arguments are based on your empirical experience with a finite group of instruments that you have tested. It's fine to conclude that the digital tachs you tested were all better than the analog ones you tested, but you cannot logically extrapolate that conclusion to all tachs. It is certainly possible for a digital tach to be wildly inaccurate, and it is just as possible for an analog tach to be extremely accurate. It all depends on the quality of the design of the entire system and its calibration. True, it is easier to design a digital tach to be accurate, especially for rapidly varying revs where meter ballistics limit the dynamic response of an analog/mechanical system, but that doesn't mean that there aren't some digital designs that are worse. I'm basing my viewpoint on my past 34-year career as a metrologist, culminating in 15 years as the chief of the research group at a major US government laboratory. My viewpoint is grounded in the basic principles of scientific measurement and logic. OK, I've had my say. I'll stop beating this dead horse. |
