![]() Tue Sep 27, 2016 9:25 am
GTS 300 70th Anniversary
Posts: 3360 Location: Bromsgrove, UK |
![]() GTS 300 70th Anniversary
You've got no idea on how much I like that project of yours!!!
Thought about it a while ago but unfortunately don't think is legal in Spain. I would have installed a Tachometer at least... How do you turn on indicators?? Could you show how did you put the license plate? Thanks in advance and keep posting!! |
Thanks for your comments!
No project page set, but this one could serve the purpose. I have browsed many projects on modernvespa.com before starting mine to get some ideas. So I thought I would share back. Happy to give hints and product references if something catches your interest. One thing I am not too happy about is the back. Since these pictures I have shorten the inner rear fender that you can still spot. It looks a bit better but still the wheel is too small and a bit hidden into the frame, which does not look as good as the inspiration - see picture below. In addition, as soon as it rains, I have my shirt full of dirt - not good to go to work. I should have done a "shortening" work of the outer rear fender the same way as the front fender. Just a recommendation if you plan to ride on wet roads. Another thing to avoid, I have changed the front suspension with a low priced one from the brand Carbon as I was going for the color (black body/red spring). Much worse than the Piaggio original. The rebound is terrible. There is a spring but I wonder where is the amortization. Just get the original one re-painted. @ Duane1: Front Fender: I have cut the fender myself with a metal saw, smoothed the edges, and got it painted. I will double check on the measurements to share with you. Got inspired by the project displayed below. Gauges: I only have the oil indicator (originally red) and refill fuel lights (originally orange) left. Did some rewiring and set the little bulbs right in front of the handlebar. I will share a picture over the weekend. All the other gauges are gone. @ mrmarti Tacho: I feel the speed with the heart.... well, that will not fly better with authorities in HK as it would in Spain. Even less actually, much stricter here than in southern Europe being myself from Europe. But well, at some point you have to put the project on the road. I was thinking of setting a bicycle digital tacho to show the speed, but the signal of wireless ones gets messed up/disconnected with the metal frame body and a wheel-to-display distance greater than on a bicycle. I could not find any good designed one with wire. In addition, setting the magnet on the wheel is a little bit challenging but possible - there is little space with the calliper. But if you happen to know about any good looking and simple bicycle wired type tacho, please share the reference. For the story, the cable on my daily commute Vespa LX i.e. 3V got broken after 20kkms, so I also feel the speed with the heart on that one at the moment. The only thing is that authorities still see an original tacho, so it won't get me into trouble if I get checked. I could set a mocked digital on this Urban Scrambler project just to pretend - still the design of the piece has to be simple, raw and discreet. To be continued. In the meantime I will probably set an X RamMount in the center of the handlebar and run a GPS App such as Waze on my smartphone to get the speed. License plate: I have set a 8cm wide piece of rubber that runs from under the seat where the rear rack is originally mounted to the 2 bolts above the rear light that are also normally used to hold the rear rack on the ET4, or the handlebar on the LX. Then the plate is fixed on this bouncy piece of rubber. I can share pictures and dimensions later. Indicators: I have bought a Left Side Switch and rewired. Please see reference in the file attached. I can share the seller later if interested. Yet this part requires very precise and extensive trimming work - on the newly bought part - to nudge it properly with the brake holder collar on the handlebar - pictures to come later will clarify. I have not gone that far yet, it still sits a bit off on the left. ![]() I like the back better here, it was my goal as the rear wheel stands out better and meaner, but it requires to change gearbox with the one a Fly 150 and wheels with 12" from the latest Sprint... ![]() What I started from, actually I should have started from a not so rusty/worn out base ![]() Inspiration for the front fender
Thank you very much for your answer!
Please keep up the good work and keep posting! As an idea, how about a different type of seat? Something a little bit more "Scramblerer" Something like the one in the picture below would look incredible and shouldn't be hard to find someone who could make it for you. I got my seat custom made some time ago, keeping the original shape but was quite cheap and I'm sure they can change the shape without being really expensive! ![]() |
![]() Sun Dec 10, 2017 8:18 pm
GTS 150 3Vie, '95 Excel, LX 150 3Vie
Posts: 31 Location: Indonesia |
![]() GTS 150 3Vie, '95 Excel, LX 150 3Vie
lingkarusak wrote: For the S or LX rear wheel, is it necessary to change some parts to install a bigger size from their standard size? if i want install a 11" or 12" rear wheel on LX. Thanks |
![]() Vespa ET4 125cc , Baotian 70cc rat scooter
Posts: 384 Location: Wales |
