BV 350 replace the silly sounding HORN
2019 BV350
Wed May 22, 2019 6:24 pm quote
can anyone tell me in details how to remove the front panel and how much space there is behind it to mount a better sounding horn...? maybe someone here has already done that mod, can you share it..?
I tried to remove all of the pertinent screws and then I started to pull from the bottom but I was applying a lot of force and I chickened out afraid of braking some tabs.
2016 BV350 White
Mon May 27, 2019 8:29 am quote
Here is a youtube video that shows how to do this.
I need to do this on my scooter too. One thing I would add is that breaking the tabs is not a concern for me, but losing the little metal screw holders is an issue. I already lost two of them. I think you need to order extras before you start. They are cheap.
2016 BV350 White
Mon May 27, 2019 8:32 am quote
Okay, it doesn't look like the video posted correctly. Do a search in youtube for "BV350 plastic pannel removal". [/u]
2019 BV350
Mon May 27, 2019 12:00 pm quote
hehee
I have watched that video probably a dozen times and with ALL DUE RESPECT to the guy that posted it, it is very poorly shot and suffers tremendously from lack of DETAILS (the camera is not moving or zooming and sometimes is poorly aimed) when I tried to follow it some things do not match either, so something a lil more in details would be fantastic.
2016 BV350 White
Mon May 27, 2019 9:44 pm quote
Start reading on page 309 of the workshop manual. See the link below.
https://manuals.wotmeworry.org.uk/Beverley/BV350/BV350%20Workshop%20Manual.pdf
If this doesn't help, then I would look at one of the scooter west videos on youtube for how to do it on a GTS. It would work about the same way.
2019 BV350
Tue May 28, 2019 4:50 am quote
Hey Bean, thank you for that link, it will help somewhat and I also posted something in a Youtube video by Scooterwest pleading for a Video showing how to go about this. Unfortunately not beeing very familiar with this scooter does not help and the "Close up" pictures shown in the workshop manual sometime are hard to understand (at least for me), hopefully I'll get another response that will help me even more but your link is definitely a good start.
I watched the GTS videos, unfortunately the GTS is a totally different beast when it comes to panels removal.
2018 Piaggio BV 350
Thu Jun 13, 2019 6:16 pm quote
Bumping!
Same! I called a shop near me and they seem to think that the Stebel “could” fit, but they’re not 100% certain. I’d like to know before plunking down the money for the labor if it is goingt o come to nothing. The horn on the BV is a joke.
2016 BV350 White
Sun Jun 16, 2019 6:54 pm quote
AF1 is advertising a wire kit for the Stebel Nautilus airhorn that would make it plug and play. They list the BV350 as one of the scooters that this works with. So a Stebel Nautilus should fit. However, there are different models of Stebel Nautilus airhorns so you still need to be cauful.
2015 BV 350
Sun Apr 19, 2020 6:26 pm quote
The one I bought came with a relay. You simply put the wires from the horn on the coil of the relay and bring a fused hot typically from the battery to one side of the points on the relay and the other side to the horn. Find a good ground for the other stab on the horn and Bob's your uncle.......
2016 BV350 White
Mon Oct 05, 2020 9:05 pm quote
I haven't done this myself and I can't for the next month are so due to a sprained arm and fractured bone in my elbow (not from a scooter crash), but I don't understand why you would have to do all of that wiring. Why would you not just use the same wiring for the old horn when you take the old horn out?
2015 BV 350
Tue Oct 06, 2020 2:09 am quote
Because the horn switch is designed for the small amperage draw of the tiny horn you use its' wiring to power the relay instead. The points (switch) in the relay is capable of handling higher amperage which a larger louder horn will require.....
BV350
Tue Feb 02, 2021 5:26 am quote
Horn Replacement
Has anyone done a horn replacement on a BV 350?
Tue Feb 02, 2021 5:40 am quote
Re: Horn Replacement
I fit a Fiamm Freeway Blaster in my BV350 in place of the original horn. Here's a picture.
2012 GTS 300 Super (Charlene) 1832cc cruiser (The Lambo)
Tue Feb 02, 2021 6:28 pm quote
[url] https://www.scooterwest.com/nautilus-air-horn-by-stebel-horn-stebelnaut.html
Call these guys and ask if it will fit. I have one installed on my GTS 300 and it is VERY LOUD! Scares the shit out of anyone in ear shot. Very gratifying when honked at cars that pull in front of you or someone texting while driving, etc. [/url]
GTS 300 SS BB
Thu Feb 04, 2021 5:59 pm quote
Or you could go for the Fiamm that it is nearly a straight out of the box replacement and it doesn't required to find a location for the little air compressor.
Sound is not as high as the Stebel Nautilus but pretty close and much easier to install..
Here is a video of it:
https://www.youtube.com/watch?v=BrgO1MS6MCs
Fri Feb 05, 2021 7:31 pm quote
Sorry dude but that Fiamm is not nearly as loud as the Stebel Nautilus horn. Also, there is plenty of room to mount the Stebel which is a single unit (compressor and horn). dB tests are not alll performed the same way. Some at close proximity to the horn and some at a distance. I’ve heard both in person. Not even close.
GTS 300 SS BB
Sat Feb 06, 2021 3:01 am quote
Sorry dude but I can only repeat myself..
Sun Feb 14, 2021 8:14 am quote
Can it set off car alarms? The Stebel Nautilus can! LOL
2016 BV350 White
Sun Mar 21, 2021 4:54 pm quote
https://www.scooterwest.com/horn-wire-kit-for-stebel-nautilus-horn-hornwire-kit.html
This is a link to the wiring kit that ScooterWest sells that works with a BV350 and has a 20 amp fuse in the middle of it. So apparently this works with the Stebel Nautilus horn that they sell. link below.
Wed Mar 24, 2021 9:01 pm quote
Quit counting beans...get the Stebel Nautalus, install it, be impressed, enjoy the thrill of honking at idiots!
  DoubleGood Vespa T-Shirts
[ Time: 0.0339s ][ Queries: 25 (0.0152s) ][ Debug on ][ Thing Two ]
