Fri Jan 24, 2020 11:47 pm
300 gts
300 gts
Fri Jan 24, 2020 11:47 pm linkquote
New project , Just to see if it can be done really, seems to going pretty good, got some frame reinforcments to make as yet, but up to know things are looking workable.
Sat Jan 25, 2020 10:55 am
Gilera Runner 500cc.
Sat Jan 25, 2020 10:55 am linkquote
Go for it!
If you want a dual front disk, but not a verry expensive 13 inch front wheel.
Or a big 16 inch Beverly wheel.
You can also use a 14 inch Peugeot Satelis 500 front wheel.
Piaggio delivered the Master engine to Peugeot, and they installed it on the Satelis.
The rear wheel of the satelis is also 14 inch.
Sat Jan 25, 2020 10:58 pm
300 gts
300 gts
Sat Jan 25, 2020 10:58 pm linkquote
front wheel
Front forks wont take a bigger wheel, however a mte has a twin front disc specially designed for scomadi race scoots.
Sat Jan 25, 2020 11:15 pm
300 gts
300 gts
Sat Jan 25, 2020 11:15 pm linkquote
Mounts on
engine mounts now fitted and tensioner bar almost ready to be fitted.
Sat Jan 25, 2020 11:17 pm
300 gts
300 gts
Sat Jan 25, 2020 11:17 pm linkquote
loop tried
all fits nicley under the loop
Sun Jan 26, 2020 3:32 am
Sun Jan 26, 2020 3:32 am linkquote
Cool!
Sun Jan 26, 2020 11:46 pm
300 gts
300 gts
Sun Jan 26, 2020 11:46 pm linkquote
engine all mounted
engine mounts are now fitted, i still have a little fabrication to do as yet . will post more as i go.
Mon Jan 27, 2020 4:37 am
Vespa Gt 200 '03, PX 150 '00
Mon Jan 27, 2020 4:37 am linkquote
incredible crazy and funny
go go go and please keep taking pictures
thank you
Mon Jan 27, 2020 5:11 am
Kawasaki Z1000, Yamaha R1, Honda SH300i
Mon Jan 27, 2020 5:11 am linkquote
Top stuff
Mon Jan 27, 2020 5:34 am
Mon Jan 27, 2020 5:34 am linkquote
Just a question.
why don't you use a Scomadi TL125, and convert that to a 500cc.
Then you can get that registered as a heavy bike, because it already is a small bike.
This way it is road legal.
Here in the Netherlands that is the way to go.
Don't know exact how it works in your country.....
Mon Jan 27, 2020 8:20 am
300 gts
300 gts
Mon Jan 27, 2020 8:20 am linkquote
125
A tl 125 frame and a tl 50 frame are exactly the same, the difference between a tl 125 scooter and a tl 50 scooter is about £1,200. plus the 50cc scooter has twin shock mounts and the tl125 only has 1. most of the bigger engines use 2 shocks, not a mono shock, so for me a 50cc is a no brainer.
Mon Jan 27, 2020 8:34 am
Mon Jan 27, 2020 8:34 am linkquote
Re: 125
But never road legal then?
In holland you cant go from a 50cc to a 125 or more.
From a 125cc to more is possible and legal.
Fri Jan 31, 2020 10:19 pm
300 gts
300 gts
Fri Jan 31, 2020 10:19 pm linkquote
Road Legal
I have converted many 50cc into 300,s all have been registered with no problems what so ever, ive built a 400 burgman based scomadi , and several lambretta series 2 with gts engines also fitted. The last lambretta done was adapted for a guy who only has one arm, so hydraulic rear brake lhs throttle and switches etc.
Extreme mod
Sun Feb 02, 2020 10:38 pm
300 gts
300 gts
Sun Feb 02, 2020 10:38 pm linkquote
fabrication near the end
most of the fabrication is done now, just mounts for regulator ecu etc. I have a small problem with the throttle body catching the frame work, I have ordered a mp3 500 intake which is made from alloy, so it can be cut and welded.
Wed Feb 19, 2020 11:34 am
piaggio hexagon
piaggio hexagon
Wed Feb 19, 2020 11:34 am linkquote
Very impressive work.
⬆️    About 27 days elapsed between posts    ⬇️
Tue Mar 17, 2020 10:18 pm
300 gts
300 gts
Tue Mar 17, 2020 10:18 pm linkquote
resumed work.
Had to put the 500 on hold while i built a lambretta auto for some one, but back on it again now. been busy modding parts to work in this frame, ie the throttle body was catching the frame,and being made from hard rubber could not be altered, i found an alloy mp3 one which allowed me to cut shape and weld.
Tue Mar 17, 2020 10:20 pm
300 gts
300 gts
Tue Mar 17, 2020 10:20 pm linkquote
Tank
i have also modded the alloy fuel tank,and put a tunnel in it so the throttle body is clear of it, also welded a threaded ring in it for the fuel pump. will post some more pics when ive fitted it.
Tue Mar 17, 2020 11:04 pm
Tue Mar 17, 2020 11:04 pm linkquote
Derby. Must be a RR man?
Wed Mar 18, 2020 10:12 pm
300 gts
300 gts
Wed Mar 18, 2020 10:12 pm linkquote
RR Man
I am self employed builder, this is my hobby.
Thu Mar 19, 2020 5:11 am
Thu Mar 19, 2020 5:11 am linkquote
Do like your work
Thu Mar 19, 2020 7:39 am
300 gts
300 gts
Thu Mar 19, 2020 7:39 am linkquote
My work
Many thanks, i enjoy it, keeps me out the way of the grankids.lol
Thu Mar 19, 2020 9:59 pm
300 gts
300 gts
Thu Mar 19, 2020 9:59 pm linkquote
Fuel tank
Fuel tank is ready to be fitted now, As you cure one problem another occures lol, i need to mod the battery box so it still fits.
Thu Mar 19, 2020 11:17 pm
Thu Mar 19, 2020 11:17 pm linkquote
I am using a mutch smaller Lifepo 4 battery for my build.
And you can mount it any way you want.
Fri Mar 20, 2020 8:15 am
300 gts
300 gts
Fri Mar 20, 2020 8:15 am linkquote
Battery
I could use a lion but no need i still have room fro a mottobat i have to move it to the rhs slightly , If need be i cold mount in the toolbox also, but thanks any way.
Sun Mar 22, 2020 4:51 am
skipper st125
skipper st125
Sun Mar 22, 2020 4:51 am linkquote
I like to read and look at your projects.
Great work as ever.
Robbie
Tue Mar 24, 2020 10:24 pm
Vespa GTS 150 3v SUPER. Vespa V100 x 1. Lambretta Li150 x 1. Px 125 x 2. Px 200 x 1 (red bull special) T5 Classic x 1. Vespa Cosa x 2.CF moto 650mt
Tue Mar 24, 2020 10:24 pm linkquote
Quality....
Amazing skills and abilities. Can't wait to see the finished result. Kudos to you having the balls to take on such a project.
Mon May 04, 2020 10:53 pm
300 gts
300 gts
Mon May 04, 2020 10:53 pm linkquote
wiring harness
Quick update on progression. due to the current situation, the fromt wheel is still waiting to be machined , the rad is waiting to be made, these guy,s have closed shop until they can get back to work. I have also been struggling to get the correct wiring loom for the ecu and decoder, I managed to locate one in france, and that took a life time to turn up, arrived last week, so i have been altering it to fit the scomadi frame, ie location of relays coils fan etc, then removing helmet box switches and unnecessary wires incd electric stand wires, And making sure i do not cut any necessary circuits in the process.
I will post some more pics as soon as the loom is finished, and the fuel tank is back in. Hope every one is keeping safe.
Sun May 10, 2020 5:12 am
P Series / Li / LML / Motobi
Sun May 10, 2020 5:12 am linkquote
Thats some excellent work
what does it take to get on your list? I have a silver special that could really use an auto conversion
Sun May 10, 2020 10:22 am
300 gts
300 gts
Sun May 10, 2020 10:22 am linkquote
on my list
When all this madness is all over and we can actually meet and discuss things. I have a few waiting but only quick conversions.
You can message me from my fb page.
https://www.facebook.com/groups/355677854963746/
Fri Aug 21, 2020 9:32 am
Fri Aug 21, 2020 9:32 am linkquote
Any news about the build?
⬆️    About 6 months elapsed between posts    ⬇️
Mon Feb 15, 2021 10:52 pm
300 gts
300 gts
Mon Feb 15, 2021 10:52 pm linkquote
Final build about to start
I have a project on the bench this week that should be complete tomorrow, then the final 500 build will start.The frame is now back from being blasted and powder coated
Powder coted fame
powder coat frame 2
Mon Feb 15, 2021 10:55 pm
300 gts
300 gts
Mon Feb 15, 2021 10:55 pm linkquote
Not had the time
This build has been put on hold several times to work on other peoples projects for them, i dont like to turn people away or let them down, So mine has taken a bit of a back seat, but once its on the bench this week, That is where it will stay until complete.
Mon Feb 15, 2021 10:58 pm
300 gts
300 gts
Mon Feb 15, 2021 10:58 pm linkquote
scootering magazine.
The red lambretta i built last year is now complete and its story is in the scootering magazine this month.
Fri Feb 26, 2021 9:35 pm
300 gts
300 gts
Fri Feb 26, 2021 9:35 pm linkquote
Coming together
Started the final assembly, And doing a few tweaks.
Fri Feb 26, 2021 9:37 pm
300 gts
300 gts
Fri Feb 26, 2021 9:37 pm linkquote
Exhaust has to go
Thinking of using a carbon can on this build, the stainless exhaust is so heavy, Not to mention ugly.
Fri Feb 26, 2021 11:19 pm
Fri Feb 26, 2021 11:19 pm linkquote
A mivv exhaust is lighter, smaller, and sounds better.
Leovince Granturismo is also a quality exhaust.
Fri Apr 16, 2021 9:44 pm
300 gts
300 gts
Fri Apr 16, 2021 9:44 pm linkquote
end result.
end result.
x9.500
Fri Apr 16, 2021 9:47 pm
300 gts
300 gts
Fri Apr 16, 2021 9:47 pm linkquote
twin disc
twin disc system
Fri Apr 16, 2021 11:03 pm
Fri Apr 16, 2021 11:03 pm linkquote
Looks might fine
Fri Apr 16, 2021 11:14 pm
300 gts
300 gts
Fri Apr 16, 2021 11:14 pm linkquote
end result.
Thanks, i am pleased with the end result, A lot of time and working things out went into its development, but all worth it.
[ Time: 0.2854s ][ Queries: 7 (0.2627s) ][ Debug on ][ 211 ][ Thing One ]
