Oil nipple on Rally tank
'74 Rally 200, '05 PX150
Sat May 23, 2020 8:10 am quote
Greetings. I’m using my all steel, one piece fuel & oil tank on a Rally 200. I ordered the only oil filter nipple that I could find for the bottoms of the oil tank and the thread pitch doesn’t seem to fit the tank and the filter looks crazy tall for the application. Am I crazy or is there another fitting out there? I came across the pic on the left in the NSM forum, is that banjo fitting legit? I’d hate to just “drive it home” and f*ck up the tank altogether.
Sat May 23, 2020 9:42 am quote
The oil taps for Rallys are 2 part systems. They are super hard to come by. The bolt is hollow and then the tap can spin 360 degrees around the bolt. There’s two o rings that seal the gaps in the 2 parts. Looks like the tap you have on the right is for a P series. You definitely dont want to force it in there.
I’d try posting something on scoot.net. If not, hopefully someone on here can tell you a workaround.
P Series / Li / LML / Motobi
Sun May 24, 2020 7:56 am quote
i can give you a workaround....
speak to your local hydraulic engineer supplier
get a hydraulic bango connector and bolt as you would for hydraulic brake setup and drill a few extra oil inlet holes for the oil to seep into the bolt. connect and enjoy
warning - you may need to retap the thread in your tank - but its better that than an ornamental piece unseen
P200E custom
Tue Apr 06, 2021 8:34 am quote
The size for the oil filter banjo bolt seals is M10 x 14 x 1 you can get copper seals in that size at any decent auto parts store or online. The original plastic seals were 1.5mm thick but all I could ever find was 1mm any metric copper seal washer assortment will have them included.
  DoubleGood Vespa T-Shirts
[ Time: 0.0476s ][ Queries: 27 (0.0257s) ][ Debug on ][ Thing Two ]
