Mon, 22 Jun 2020 10:08:30 +0000
Mon, 22 Jun 2020 10:08:30 +0000 quote
Greetings,
i'm thinking of replacing the stock pipe on my sprint to an aftermarket one but i'm kind of confused which one should i get. My local shop has these brands in stock :
-Spark
-Polini
-Akrapovic
-Malossi
-Arrow
Of all the brands above which one offers the best performance?, or the performance gains are so miniscule that i should just choose by the looks of the pipe?. Thanks.
Mon, 22 Jun 2020 10:27:43 +0000
2006 Vespa GT (Rocket): 2005 Vespa GT (Razzo): 2007 Vespa GT (Vanessa): 2009 Yamaha Zuma 125 (Zoom): 2018 Yamaha Xmax (Big Ugly)
Mon, 22 Jun 2020 10:27:43 +0000 quote
The one that Piaggio put on at the factory is my favorite
Mon, 22 Jun 2020 19:10:00 +0000
Mon, 22 Jun 2020 19:10:00 +0000 quote
I'm using a Malossi pipe with a red malossi filter. I also recently installed a TC O2 lambda controller and the scooter pulls a lot better than stock. It's a bit noisier too even with the silencer on so it's something to consider.
Aftermarket exhausts are generally a lot lighter than the stock and are made with stainless steel, titanium and CF which resists rust. I think the brands you mentioned (at least polini, Malossi, akrapovic and arrow) are pretty much similar in terms of build quality.. its really more of choosing the look you prefer.
Tue, 23 Jun 2020 00:35:45 +0000
Tue, 23 Jun 2020 00:35:45 +0000 quote
Thanks for the opinion!, i think i will go with the akra, after watching soundclips i prefer the sound, it has a deep tone to it and it's not obnoxiously loud. By the way is the o2 manipulator mandatory?, or the stock ecu is enough for the job?.
Tue, 23 Jun 2020 12:46:05 +0000
Tue, 23 Jun 2020 12:46:05 +0000 quote
I did quite some research on the O2 lambda sensor and it just felt that it would complement the exhaust and red air filter well. Basically it alters the signal the O2 sensor produces to improve the A/F mixture which tends to lean out when you change exhausts. This works basically on lower RPMs but gets negated when you're doing WOT. It's not mandatory but I just felt that it would complete the system hence I got it.
The scooter felt a bit stronger accelerating which I appreciate especially when overtaking in urban traffic.
[ Time: 0.0289s ][ Queries: 4 (0.0054s) ][ Debug on ][ 276 ][ Thing Two ]
