Fri Jul 17, 2020 7:25 am
BV-350T, Malaguti 150
Fri Jul 17, 2020 7:25 am linkquote
Following the service interval Wiki for 6K miles. Says to check the throttle lever. What am I checking for and how does it get adjusted?
The OEM rollers last longer that 6K so I'll stretch it to 12K and do it when I replace the belt. IS that too much mileage for the rollers?
Fri Jul 17, 2020 5:45 pm
Fri Jul 17, 2020 5:45 pm linkquote
Greetings:
It might be worth inspecting the rollers and perhaps measuring for flat spots. If you have the belt cover off and the pulley lock tool, it doesn't take very long and might improve performance from mile 6001 to 12,000. I'd put a caliper on the belt too.
Sun Jul 19, 2020 3:01 pm
Sun Jul 19, 2020 3:01 pm linkquote
I have a micrometer. What are the values to hit or am I only rotating the rollers to check for flats?
Do you prefer OEM of DrRoller?
[ Time: 0.0242s ][ Queries: 5 (0.0052s) ][ Debug on ][ 211 ][ Thing One ]
