Wed, 18 Nov 2020 17:32:44 +0000
parallelogramerist
Posts: 4156 |
quote
Then I used my big 220v welder for gluing the two 1/4" pieces together. It has very good penetration, so I'm very confident with the strength of the whole switch housing now.
![]() Last edited by whodatschrome on Tue, 22 Dec 2020 23:36:50 +0000; edited 2 times |
Wed, 18 Nov 2020 17:34:33 +0000
parallelogramerist
Posts: 4156 |
Wed, 18 Nov 2020 17:36:45 +0000
parallelogramerist
Posts: 4156 |
quote
And then grinding down the plate to match the contour to match the same shape as the M/C.
Wed, 18 Nov 2020 17:37:37 +0000
parallelogramerist
Posts: 4156 |
Posts: 3450 Location: Florence, OR |
Wed, 18 Nov 2020 17:39:54 +0000
parallelogramerist
Posts: 4156 |
Wed, 18 Nov 2020 17:45:03 +0000
parallelogramerist
Posts: 4156 |
quote
And mounted up on the headset, this is what it looks like. By far, the most difficult part was just making sure that I had the M/C in the exact position that I wanted it. I made it so that it has the exact same offsets and (fore/aft, up/down, and side to side as a standard PX disc lower headset.
Posts: 4067 Location: Staten Island, NY |
Wed, 18 Nov 2020 17:49:39 +0000
parallelogramerist
Posts: 4156 |
quote
Sharp eyes will notice that I rotated the 1/4" plate before I welded it in. By doing that, it makes WAY better ergonomics for the wrist. I didn't measure the exact degree that I rotated it forwards and down, but probably 15~20 degrees? I'll have to measure it at some point.
![]() Last edited by whodatschrome on Tue, 22 Dec 2020 23:38:03 +0000; edited 1 time |
Wed, 18 Nov 2020 17:59:11 +0000
parallelogramerist
Posts: 4156 |
quote
And with it finish up, i think it came out great. My goal it to have it nice enough that I don't have to use any sort of filler to hide any scratches before it gets painted.
The whole master cylinder mounting project was pretty fun. Nothing was difficult, except that I like to have locked in a game plan before I start fabricating stuff, but there was no game plan on this. I couldn't find any sort of documentation online about anyone doing the same thing to an Allstate headset, but I'm sure that at some point over the years there has been some crazy European who has done something like that before. But here in the US, those type of mods aren't as common. ![]() Last edited by whodatschrome on Sun, 06 Nov 2022 06:26:42 +0000; edited 1 time |
![]() Vespa
Posts: 1463 Location: California |
Posts: 3454 Location: Veria, Greece |
Wed, 18 Nov 2020 19:05:56 +0000
quote
Mad Skillz!!! I was going to suggest giving an angle to the plate but you already beat me to it. Did the same on my P. I always found the stock PX B.M.C. position very strenuous on the wrist and that's probably why you get a "wooden" feeling from the brake. I guess they did it this way for the levers to be symmetrical with each other...
The Dude
Posts: 1462 Location: PNW from LBC |
Thu, 19 Nov 2020 00:51:28 +0000
quote
That is some fine work WDC! Good to see something like this done a different model with the split headset. Unique and cool!
![]() Thu, 19 Nov 2020 02:47:03 +0000
Posts: 3441 Location: california |
Thu, 19 Nov 2020 06:48:15 +0000
parallelogramerist
Posts: 4156 |
quote
SaFiS wrote: Mad Skillz!!! I was going to suggest giving an angle to the plate but you already beat me to it. Did the same on my P. I always found the stock PX B.M.C. position very strenuous on the wrist and that's probably why you get a "wooden" feeling from the brake. I guess they did it this way for the levers to be symmetrical with each other... ![]() |
Thu, 19 Nov 2020 06:54:39 +0000
parallelogramerist
Posts: 4156 |
quote
Also, thanks you everyone else for the compliments. Perhaps it will give others inspiration and ideas for their projects as well?...because I only got motivated to work on my Allstate again after seeing everyone else here wrenching in their Allstate's. So if it wasn't for all the Allstate projects happening on MV, mine could still be under a cover for the next 7 years!
Thu, 19 Nov 2020 06:58:16 +0000
parallelogramerist
Posts: 4156 |
quote
So I couldn't stand looking at the PX's hydro lever. It's just way too out of place on the old scooter. The old lever is in the left, the PX on the right.
Thu, 19 Nov 2020 06:59:46 +0000
parallelogramerist
Posts: 4156 |
quote
I cut about an 1" off the end, sanded down the profile a bit, then polished it up a bit. It's a much better shape now.
Thu, 19 Nov 2020 07:01:59 +0000
parallelogramerist
Posts: 4156 |
quote
I didn't want to have too sharp of a point at the end of the lever, just some that didn't look too out of place. So this is close enough for me.
Thu, 19 Nov 2020 07:10:27 +0000
parallelogramerist
Posts: 4156 |
quote
I'm not kinda switching gears and an hoping to sort out the front fender. The blue one was on it when I got the scooter, but it needed to be shimmed to get it to fit over the PK fork. That shimming caused the fender to not be centered over the wheel. I was planning on "going the easy route", so I bought a PLC fiberglass fender that is design to fit the PK fork, and it kinda looks like crap from the front....
Thu, 19 Nov 2020 07:14:38 +0000
parallelogramerist
Posts: 4156 |
quote
....and the view from the rear rhymes with "fleece of spit". I'm not really sure how that it's even possible to build a fender so poorly.
Thu, 19 Nov 2020 07:21:08 +0000
parallelogramerist
Posts: 4156 |
quote
...so I bought a another (different) fender from SIP. I wanted to start fresh with a bare steel fender so that I wouldn't have to sand any paint (and or filler?). My plan is to create a bulge (for shock clearance) on the PK fork so that I can have the fender completely centered over the wheel.
![]() 74 Super, 75 Super, PX project, LML off-roader and new to 2018, '66 Blue Badge Smallframe
Posts: 8176 Location: Victoria, Australia |
Fri, 20 Nov 2020 01:46:41 +0000
quote
That lever will go through your thigh now with almost no effort at all!!
![]() Seriously nice job. I looked a Craig's PLC mudguard on the weekend (though his was for a Zip fork in a smallframe), and you're right. It's horrible. It's made from fibreglass, so how damn hard is it to make sure the seam molding looks like a proper seam?! He said it was hard to rub down for paint because it flexed a lot, and that painting actually stiffened it up! Does make me question their other products. |
![]() Fri, 20 Nov 2020 02:32:10 +0000
quote
Quote: "fleece of spit". Uh huh. All looking good and nice work on the brake lever. Much better looking, and dangerous. Perfect. Not sure the plan for getting it sprayed - but I had some good luck with one of those custom color match spray cans for some touch up recently. $20 for a can. Not bad. Enjoying watching u bring this into ur own. |
Fri, 20 Nov 2020 03:05:58 +0000
parallelogramerist
Posts: 4156 |
quote
Ginch wrote: That lever will go through your thigh now with almost no effort at all!! ![]() Seriously nice job. I looked a Craig's PLC mudguard on the weekend (though his was for a Zip fork in a smallframe), and you're right. It's horrible. It's made from fibreglass, so how damn hard is it to make sure the seam molding looks like a proper seam?! He said it was hard to rub down for paint because it flexed a lot, and that painting actually stiffened it up! Does make me question their other products. |
Fri, 20 Nov 2020 03:20:47 +0000
parallelogramerist
Posts: 4156 |
quote
charlieman22 wrote: Quote: "fleece of spit". Uh huh. All looking good and nice work on the brake lever. Much better looking, and dangerous. Perfect. Not sure the plan for getting it sprayed - but I had some good luck with one of those custom color match spray cans for some touch up recently. $20 for a can. Not bad. Enjoying watching u bring this into ur own. I did get a small can of touch up paint from the previous owner. It's PPG "Concept" single stage paint. I think there's enough there for a few touchups. I don't know if there's enough to spray a fender as well though. In fact, I don't even know if PPG still sells a catalyst for that line of paint. |
The Dude
Fri, 20 Nov 2020 07:57:45 +0000
quote
Hope you DONT MIND asking, where abouts in OR? I'm in
South Oregon, perhaps we can coordinate paint schemes? Im flexibles, working on a Rally 200. Your're doing good work!!! |
Fri, 20 Nov 2020 08:37:32 +0000
parallelogramerist
Posts: 4156 |
quote
GeekLion wrote: Hope you DONT MIND asking, where abouts in OR? I'm in South Oregon, perhaps we can coordinate paint schemes? Im flexibles, working on a Rally 200. Your're doing good work!!! |
Fri, 20 Nov 2020 16:02:38 +0000
Posts: 1285 Location: Philadelphia |
quote
Every time I see a pic of an Allstate in that blue in that condition I want to repaint my 58. I love the patina, but I also love that shade of blue. It just looks so good.
Posts: 3650 Location: London UK |
Fri, 20 Nov 2020 19:16:15 +0000
quote
Excellent work with the m/c. The dropped lever look is a bit (a lot) Lambretta. Don't not like it.
The Dude
Mon, 23 Nov 2020 06:31:02 +0000
quote
whodatschrome wrote: GeekLion wrote: Hope you DONT MIND asking, where abouts in OR? I'm in South Oregon, perhaps we can coordinate paint schemes? Im flexibles, working on a Rally 200. Your're doing good work!!! |
![]() Tue, 24 Nov 2020 11:57:58 +0000
P Series / Li / LML / Motobi
Posts: 510 Location: UK - 3rd Rock From the Sun |
![]() P Series / Li / LML / Motobi
quote
whodatschrome wrote: Ginch wrote: That lever will go through your thigh now with almost no effort at all!! ![]() Seriously nice job. I looked a Craig's PLC mudguard on the weekend (though his was for a Zip fork in a smallframe), and you're right. It's horrible. It's made from fibreglass, so how damn hard is it to make sure the seam molding looks like a proper seam?! He said it was hard to rub down for paint because it flexed a lot, and that painting actually stiffened it up! Does make me question their other products. |
Wed, 25 Nov 2020 03:32:25 +0000
parallelogramerist
Posts: 4156 |
quote
Jack221 wrote: Excellent work with the m/c. The dropped lever look is a bit (a lot) Lambretta. Don't not like it. |
Wed, 25 Nov 2020 05:55:30 +0000
parallelogramerist
Posts: 4156 |
quote
Gravelrash2004 wrote: whodatschrome wrote: Ginch wrote: That lever will go through your thigh now with almost no effort at all!! ![]() Seriously nice job. I looked a Craig's PLC mudguard on the weekend (though his was for a Zip fork in a smallframe), and you're right. It's horrible. It's made from fibreglass, so how damn hard is it to make sure the seam molding looks like a proper seam?! He said it was hard to rub down for paint because it flexed a lot, and that painting actually stiffened it up! Does make me question their other products. ![]() |
Sun, 13 Dec 2020 20:50:48 +0000
parallelogramerist
Posts: 4156 |
quote
It's been a little while since I've messed with my Allstate project. I was busy prepping another brand of motorcycle for a long thanksgiving weekend dirt bike ride...and now my ribs are still REALLY, REALLY sore two weeks later.
I did buckle down and installed a pair of TD-Customs luggage loops and a TD-Custom floor support. I've used them both before in the past and have been pleased with their products, and the latest design of their luggage loops have a taller loop, so it's now easier to fish a strap through it. ![]() |
Sun, 13 Dec 2020 20:53:15 +0000
parallelogramerist
Posts: 4156 |
quote
And what the reinforcement plate looks like. It's made out of stainless steel, so it won't rust.
![]() Sun, 13 Dec 2020 21:20:14 +0000
Posts: 3238 Location: Rochester, Minnesota |
![]() 2007 Stella 225
quote
whodatschrome wrote: It's been a little while since I've messed with my Allstate project. I was busy prepping another brand of motorcycle for a long thanksgiving weekend dirt bike ride...and now my ribs are still REALLY, REALLY sore two weeks later. I did buckle down and installed a pair of TD-Customs luggage loops and a TD-Custom floor support. I've used them both before in the past and have been pleased with their products, and the latest design of their luggage loops have a taller loop, so it's now easier to fish a strap through it. That plate is what I was thinking of a thicker version of for taller tires, so the center stand would reach the ground. |
Sun, 13 Dec 2020 21:29:52 +0000
quote
I like that reinforcement plate for the stand. Didn't know someone made one for that. Both are definitely on my list now as the floor warps a little if I load the bike up too much and put it on center stand. Great stuff!
Sun, 13 Dec 2020 21:34:10 +0000
quote
Very nice luggage loops. I might have to check them out for the P200.
And ribs - bummer. Was this on the 640? My kidneys used to take a beating, even with a kidney belt. But this was back in the day in the Mojave desert on an XR500R. |
Sun, 13 Dec 2020 22:13:57 +0000
parallelogramerist
Posts: 4156 |
quote
Christopher_55934 wrote: whodatschrome wrote: It's been a little while since I've messed with my Allstate project. I was busy prepping another brand of motorcycle for a long thanksgiving weekend dirt bike ride...and now my ribs are still REALLY, REALLY sore two weeks later. I did buckle down and installed a pair of TD-Customs luggage loops and a TD-Custom floor support. I've used them both before in the past and have been pleased with their products, and the latest design of their luggage loops have a taller loop, so it's now easier to fish a strap through it. That plate is what I was thinking of a thicker version of for taller tires, so the center stand would reach the ground. |
