First pics...
Posts: 3452 Location: Veria, Greece |
Sat, 20 Feb 2021 18:14:11 +0000
quote
I have posted about this before in the smallframe thread (October of 2019), but now it's GAME ON!!! A 1981 V50s we got for 200EUR and will be restored for my brother in law. Lots of nice "Go Fast" parts ordered and we decided to turn it into a "Special" since you don't see any around here. Handlebar was cheap (80EUR) and came from Italy. I had it blasted a while back, new legshield is here with lots of body parts, so as to have it dry built and ready for paint. Shortened PK front fork (one is for a friend), disc brake, etc. etc. etc. I'll keep you guys updated...
First pics... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Positive
Sat, 20 Feb 2021 21:32:13 +0000
parallelogramerist
Posts: 4154 |
Sun, 07 Mar 2021 21:38:59 +0000
quote
Our "Special" project was hiding a "special" surprise. Frame was a bit off. Brought out my hydraulic press, the ruler jig I have for smallies and five minutes later it's done...
Positive
![]() 86 T5, 63 GL, 65 Allstate
Posts: 724 Location: Oak Brook, Illinois |
Sun, 07 Mar 2021 22:51:53 +0000
parallelogramerist
Posts: 4154 |
quote
That's a pretty slick porta-power ram set up for straightening frames!
The Dude
Posts: 1462 Location: PNW from LBC |
Mon, 08 Mar 2021 02:23:26 +0000
quote
Amazing! thanks for sharing. J jig is genius, and the alignment visual check hole is smart. I'd like to know more about that hydraulic ram. I've got a frame or 2 that needs some tweaking... the ram would do better than a long pole and come-along
Posts: 4067 Location: Staten Island, NY |
Mon, 08 Mar 2021 02:35:44 +0000
quote
always some next lvl sh*t from you!
Love it. How'd you make that jig? from an existing straight frame and just sitting there welding metal together? |
The Dude
Mon, 08 Mar 2021 04:19:08 +0000
quote
swiss1939 wrote: always some next lvl sh*t from you! Love it. How'd you make that jig? from an existing straight frame and just sitting there welding metal together? |
Mon, 08 Mar 2021 04:46:29 +0000
quote
GeekLion wrote: swiss1939 wrote: always some next lvl sh*t from you! Love it. How'd you make that jig? from an existing straight frame and just sitting there welding metal together? |
The Dude
Mon, 08 Mar 2021 06:38:09 +0000
quote
108 wrote: Which is the bolt the frame to the ground / long pole trick? Interested in straightening my own frame... Insert steel pole, long, strong, and of appropriate diameter to match the steering column. Leverage on the pole, slowly and gently moving the frame back to position. Really only works if your frame isn't too bad out of whack, Sometimes easier said than done. |
Wed, 05 May 2021 20:05:19 +0000
quote
Time for a small update. After straightening the frame, we welded a brace running the center of the frame to keep it aligned. Cut off the remaining legshield / floor and today we patched up the rotten section of the tunnel. More to come...
![]() Scattered remnants of (two!) 1974 Rallys
Posts: 1722 Location: San Francisco, CA |
Sat, 08 May 2021 21:30:53 +0000
quote
A bit more progress. Rotten part of the tail is done. And... my asshole cat being the asshole he is. Always in our way...
Positive
Sat, 14 Aug 2021 21:24:05 +0000
quote
Time for an update. Preparing the floor / legshield to join the frame. Made me some long reach grip clamps, cause I couldn't find any reasonably priced ones. It's not like I'll be needing them every day, to make me buy new ones, so I "ruined" some old lock grips we had around. Struts and reinforcement plates were spot welded by a friend, but I'll be plug welding the rest of the floor / legshield on the frame. Copper weld through primer is a must (thanks Graig!!). I'll also be using some self drilling screws, along with the grips, to better secure the sheet on the frame before welding...
Positive
Posts: 1504 Location: northern New York |
Tue, 17 Aug 2021 16:14:41 +0000
quote
That's nice work. The first think I did when I got my VBB was look for a legshield replacement. It's battered but not rusty so I started with some metal bumping. It went well so I decided to continue with it. Don't need to weld it just because I can.
The steel on these scooters is really nice to work with. Looks like it's nice to weld too. Nice work on the back end keeping that flange. Bodged body lines just jump out at me when I see them. |
Wed, 08 Sep 2021 20:59:47 +0000
quote
A bit more progress. Main "spine" and tunnel treated with rust stabilizer and welding through primer. Handlebar cut and plate welded for BMS. More to come...
Positive
Sun, 19 Sep 2021 19:24:58 +0000
quote
Frame's ready, few minor things left to do. Handlebars nearly finished too. And the "Special" surprises keep on coming. After power washing the cases I discovered they are scrap. Someone "killed" them and then butcher-welded them. Now on the lookout for "new" cases...
Posts: 6854 Location: San Diego, CA |
Sun, 19 Sep 2021 20:43:20 +0000
quote
Holy crap!! Any you never noticed until now? That had to be a shock.
Tue, 21 Sep 2021 20:11:11 +0000
quote
sdjohn wrote: Holy crap!! Any you never noticed until now? That had to be a shock. |
![]() Vespa
Posts: 1463 Location: California |
Wed, 22 Sep 2021 01:22:51 +0000
quote
wow I missed this the headset is looking great wow the inside of the spine great pics
Wed, 29 Sep 2021 22:32:52 +0000
quote
Update!! Got the PK cases and it's mock-up time before paint. Fork was shortened and also "twisted" to deal with the offset the PX disc carrier brings to the PK fork. This way the wheel is centered to the fork's neck, the shock is vertical to the carrier but it gets moved a bit out. So, a new offset top mount plate is needed (fabricated our own). We had also decided for a low / high beam headlight which is aftermarket, since the "Bilux" headlights were only produced for certain markets back in the day and no NOS to be found anywhere. SIP says "For mounting only, the side plates have to be turned". Yeah, right, as if it's that easy with any scooter part. Had to fab the headset, headlight rim and also make a tab so as to be able to adjust the beam height. Lastly, we decided to go with a Primavera center mat so new holes need to be drilled...
Photos... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Positive
![]() Thu, 30 Sep 2021 04:05:47 +0000
Posts: 3438 Location: california |
quote
SaFiS wrote: Update!! Got the PK cases and it's mock-up time before paint. Fork was shortened and also "twisted" to deal with the offset the PX disc carrier brings to the PK fork. This way the wheel is centered to the fork's neck, the shock is vertical to the carrier but it gets moved a bit out. As a fellow butcher welder - even I was appalled by that crap. Good grief. Glad you found some new cases. Body work is fantastic - but in particular - the work you did on the tail was fantastic. How did you fabricate the tail piece replacement panels? And then there is the fork - the whole offset thing - very nice. If I ever do a fork again - I will modify as you have to rotate it and allow the wheel to be dead nuts center on the scoot. Impressed.
Positive
Thu, 30 Sep 2021 05:57:42 +0000
quote
charlieman22 wrote: How did you fabricate the tail piece replacement panels? https://www.amazon.com/Crimping-ALLOMN-Flanging-Thickness-Operation/dp/B07DNZ2YBT |
![]() Thu, 30 Sep 2021 06:00:28 +0000
quote
F*ck. A Romanian crimping tool. I should have known.
Brilliant! (Seriously - that part was amazing.) |
Posts: 6783 Location: Hustletown, TX |
Mon, 04 Oct 2021 21:23:53 +0000
quote
Had ordered some AN3 banjos and 10m of PTFE high pressure line from Ali for 80€ total. They came in today, took only 15 days...
Positive
![]() Mon, 04 Oct 2021 21:45:13 +0000
quote
Oh man - you're brave.
Im scared if I make my own, I will snatch the brake handle and the banjo will come firing off (into my carb) leaving me still at top speed. |
Tue, 05 Oct 2021 07:36:11 +0000
quote
charlieman22 wrote: Oh man - you're brave. Im scared if I make my own, I will snatch the brake handle and the banjo will come firing off (into my carb) leaving me still at top speed. |
Sun, 14 Nov 2021 18:54:49 +0000
quote
Tiny update. Finished with the mudguard and only a few things left to do before paint...
Positive
The Dude
Sun, 14 Nov 2021 21:46:51 +0000
quote
Nice work on the mudguard. Looks clean.
Do you mind sharing the link for the banjo fittings & line? I'm working on a PX disk fork, and need new lines. TIA! |
Sun, 14 Nov 2021 22:01:40 +0000
quote
GeekLion wrote: Nice work on the mudguard. Looks clean. Do you mind sharing the link for the banjo fittings & line? I'm working on a PX disk fork, and need new lines. TIA! Line... https://www.aliexpress.com/item/4000181690135.html Banjos... https://www.aliexpress.com/item/4000311237686.html |
Sun, 14 Nov 2021 22:15:31 +0000
parallelogramerist
Posts: 4154 |
quote
I always wondered how a person creates that bulge for the shock. Very nice.
So what length shock did you use and how much are you lowering the fork? |
The Dude
Sun, 14 Nov 2021 22:15:48 +0000
quote
SaFiS wrote: Thanks! Line... https://www.aliexpress.com/item/4000181690135.html Banjos... https://www.aliexpress.com/item/4000311237686.html |
Sun, 14 Nov 2021 22:23:27 +0000
quote
whodatschrome wrote: I always wondered how a person creates that bulge for the shock. Very nice. So what length shock did you use and how much are you lowering the fork? Shock is 185mm for ZIP/PK and fork was cut 25mm...
Positive
Mon, 06 Dec 2021 22:34:48 +0000
quote
Almost there. Horn cover moved a tud downwards to deal with the gap the PK fork creates. I've also made two adapters on the lathe to add a bit of height to the center stand. Now the front wheel has an acceptable gap from the ground. All that's left is to drill for the rails and then take everything to my friend for prep...
Positive
Tue, 07 Dec 2021 00:11:24 +0000
parallelogramerist
Posts: 4154 |
quote
Tue, 07 Dec 2021 00:12:54 +0000
parallelogramerist
Posts: 4154 |
