12v ac Conversion - 1975 VBC with turn signals
VBC
Mon Apr 05, 2021 3:05 pm quote
For anyone else out there like me who is electronically challenged, I thought I would share my success of my wiring diagram I created with a BGM 12v electrical conversion (BGM stator and BGM Wiring loom).
This is a 70's American Market scooter with original switches: 3 stage main switch, right side handle bar switch(Hi/Low headlight, horn) and left side handle bar turn signal switch.
I hope this helps anyone else who is making the upgrade.
12v ac wiring diagram VBC
VNB VSC VBC VSX
Mon Apr 05, 2021 4:13 pm quote
This is great!
I actually have a 74 VBC on deck for my next project. This will help for sure.
Thanks for sharing.
Mon Apr 05, 2021 4:46 pm quote
Good diagram.
The worst thing about turn signals from AC power is they are sometimes not bright when at idle or low revs like sitting at a light ready to turn. Piaggio solved this problem on the PK's with no battery and added an AC to DC rectifier for the turn signals and the horn. Similar to this: https://www.sip-scootershop.com/en/product/horn-rectifier-sip_99260200?cr=e993ab67-6807-4109-bbed-f6374ebf9f9b&gpc_origin=shopping&gpc_feed_alias=de&gpc_pid=99260200&gclid=CjwKCAjw6qqDBhB-EiwACBs6xyh5V7isrQZsMFR23GJF6ByIhGB0VVBF2xKkpOWi6OlIwNuGyjgc5xoC-ZkQAvD_BwE
Since the voltage is low you can add almost any outdoor AC to DC rectifier between the regulator wire and the turn signal flasher relay to get bright turn signal light. Some are even made for led if someone decides to go that route with led bulbs and flasher.
VBC
Mon Apr 05, 2021 4:47 pm quote
attached is the PDF for download
VBC_12V CONV_wBGM KIT_2021_Classic switches.pdf
 Description:
Download
 Filename:  VBC_12V CONV_wBGM KIT_2021_Classic switches.pdf
 Filesize:  3.61 MB
  DoubleGood Vespa T-Shirts
[ Time: 0.0543s ][ Queries: 27 (0.0258s) ][ Debug on ][ Thing Two ]
