Fri Apr 09, 2021 5:13 am
Vespa 125 VMA, Vespa SS 180
Fri Apr 09, 2021 5:13 am linkquote
I just finished this P125x and have a question on plug color and autolube. When I first put the motor back in, I was premixing. The autolube had been disconnected when I bought it, so I wanted to get things running before connecting and checking the autolube. It's now hooked up and autolube is working. I had about 1/2 tank of premix left in the tank, which I topped off with gas. It's clearly running rich, as it smokes a little. My plug looks lean - does this sound right? Should I worry about it? Or just run it and check the plug on the next tank?
Fri Apr 09, 2021 5:17 am
Fri Apr 09, 2021 5:17 am linkquote
Hello, out of interest, which colour code is that? Is it a Piaggio colour? I just had my PX200E painted in PIA 2/5 (original colour) and it looks identical. Yours looks great.
Cheers
Fri Apr 09, 2021 5:42 am
Fri Apr 09, 2021 5:42 am linkquote
Not exactly. The smoke is the extra oil burning. It's not a sign of "richness".
Your plug looks lean because the extra oil from the pre-mix is displacing fuel and leaning the mix - it's not making it richer.
If the autolube's working, drain what's left of the pre-mix and go with fuel only, or upjet. Otherwise you risk heat-seizing.
Fri Apr 09, 2021 6:27 am
Fri Apr 09, 2021 6:27 am linkquote
Thanks SoCal, that's what I needed to know.
Probably just drain it to be on the safe side.
Fri Apr 09, 2021 6:35 am
Fri Apr 09, 2021 6:35 am linkquote
Couldn't tell you. That's the way I got it. Original color was silver. The red does look good. How about a picture of your PX200?
Fri Apr 09, 2021 6:58 am
Fri Apr 09, 2021 6:58 am linkquote
Cheers Langolson. That is a nice red. Whoever painted it liked it so much they sprayed the trim piece on the mudguard.
Fri Apr 09, 2021 8:45 am
Fri Apr 09, 2021 8:45 am linkquote
Yep. The legshield trim, the speedo trim and a few other things, too. The good/bad is that they used a quality paint - it doesn't come off with acetone or other solvents...
Fri Apr 09, 2021 9:40 am
Fri Apr 09, 2021 9:40 am linkquote
It looks great. Any reason the it has that style of rear light on a stem? I've seen this type of stem on the us rally. What year was this px made.?
.lovely scooter , congrats
Fri Apr 09, 2021 10:07 am
Fri Apr 09, 2021 10:07 am linkquote
Could be some warped eclectic individual like myself who likes the tractor and tuna fish can lights. Thinking about putting one of them on Stella, if I can figure out how to cover up the extra holes.
If you just fill it up, that should get the premix diluted to 100:1, should help the lean issue if that is the cause.
Post up any modifications you've made such as exhaust and air filter. Along with your current jetting and someone with a similar setup can help with jetting if needed.
Fri Apr 09, 2021 12:51 pm
Fri Apr 09, 2021 12:51 pm linkquote
I think this tail light was on all of the US P series Vespas. At least the ones I've seen.
It's a 1980.
Fri Apr 09, 2021 1:16 pm
Fri Apr 09, 2021 1:16 pm linkquote
Christopher, I replaced all seals, bearings, o rings, clutch plates, cruciform, put a Polini 177 kit on it (thanks Scoot.net), no matching/porting was done, 22 tooth clutch, stock gears, drilled heart air filter, ScooterMercato economy P125/150 exhaust, stock 20/20 carb, jets right now are 40-120 idle jet, 160 air, BE3, 114 main. Timing is at 19 degrees. I had a 110 main jet in it before the autolube got hooked up and it seemed just about perfect. Think I'm in the ballpark?
Fri Apr 09, 2021 1:24 pm
Fri Apr 09, 2021 1:24 pm linkquote
Whats the impact of that 22 tooth cog on top end? How many extra mph?
Fri Apr 09, 2021 1:58 pm
Fri Apr 09, 2021 1:58 pm linkquote
Scooterhelp's gearing calculator said 55mph at 6000rpms. I've had it up to 46mph but didn't want to push it until I was sure all the kinks were worked out (and it wasn't going to seize). Also all the roads nearby are 30mph speed limit...
Fri Apr 09, 2021 3:39 pm
Fri Apr 09, 2021 3:39 pm linkquote
I'm not familiar with a Polini 177, or the exhaust pipe, hopefully someone else will come along that is. Rich shouldn't hurt anything, lean can leave you walking home with a seized cylinder.
Do you have a cylinder head temperature gauge? Nice to see how hot your running, another tool to see if your close.
Polini 177 kit, no matching/porting was done,
Drilled heart air filter
stock 20/20 carb, jets right now are 40-120 idle jet, 160 air, BE3, 114 main.I had a 110 main jet in it before the autolube got hooked up and it seemed just about perfect. Think I'm in the ballpark?
[ Time: 0.0289s ][ Queries: 7 (0.0058s) ][ Debug on ][ 211 ][ Thing One ]
